Tri-Carb Project
Healey Nut
Healey Nut
It’s all in the details
Healey Nut
Healey Nut
Slow n steady wins the race , bit by bit shes coming together .
New box of bits courtesy of Autofarm arrived today so more progress to come .
I put the exhaust back on this evening and added all the little rubber bumpers for the boot lid stop and the bonnet support etc .
Hood is not latched in the frontal shot .
Healey Nut
Healey Nut
Ticking the boxes off .
Carpets from Coverdale in the UK . Custom made , I supplied paper templates so I could have one piece floor carpets , no holes for jump seats plus the extra section of carpet for the sloping rear panel .
Rally style seat belt anchors are in , seat rails next .
Healey Nut
Healey Nut
This afternoons job was seat rails and frames etc . Another box checked off .
John Turney
You need a rally shift knob with the OD switch on the knob. Then put the headlight dip switch in place of the OD switch on the dash.
Healey Nut
Healey Nut
I thought about that and if it was a centre shift gearbox I would have done it but as it’s side shift and the gear lever is at the funky angle I think it would make using the switch on the knob awkward .
Yup, I love mine. But, I prefer the dip switch on the floor; I'll go to my grave disliking the ones on the turn signal stalk.
Healey Nut
Healey Nut
Yes but yours is a top loader not side shift. Also I didnt want the exposed wire down the side of the gear lever shaft .
Too long of a wire run, but otherwise doable. Don't some with side shifters shorten the shaft (IIRC, the 100s had a couple versions of shaft).
Healey Nut
Healey Nut
I guess I could and it’s something to consider , easy to just cut the shaft then Re thread it .
I have never driven a side shift so once she’s on the road it maybe something I will do depending on my driving position, reach and how I feel in the car .
Rob Glasgow
Healey Nut. First, that’s the best fitting tunnel carpet I’ve ever seen. I see no puckers or loose bulges. Brilliant. Second, I recommend you change your current gear shift to the later ‘double bend‘ style they used on the last 3500 or so 3000 Mk1. Ive owned my BT7 for 60 years and changed to the double bend style 3 years ago. A completely different and much improved shifting experience. The later style come up on eBay occasionally or you can post a want ad on the forums. That’s how I found mine.
John Turney
Not awkward at all. Makes shifting from 4 O/D to 3rd a one-hand operation. Put the switch on the top, with "on" forward, and it's just like shifting from 4th to 5th.
Having it on the dash allows a dead pedal for your left foot.
Healey Nut
Healey Nut
Let there be light , and rally race number roundels .
So Ive got all the electrical stuff reconnected and working only exception is the indicator warning lamp on the dash , it’s lit up all the time even without ignition on so I’m trying to figure out what that issue is . And no it doesn’t flash with the indicators which all work good .
Need to do some more checks and testing , any ideas anyone ?
Healey Nut
Healey Nut
Time to give this job the boot 😁
She has a cute rear to 😉
Healey Nut
Healey Nut
Things are really beginning to mesh together (I’ll see myself out 😁)
The front edge of the scuttle scoop has a brass edge strip . I’m going to get to some more from somewhere , maybe a stained glass shop as they use it for glass edge .
I will put a piece of it on the edges of the mesh where it sits on the aluminum rally scoop . That will cover the ends of all those sharp stainless wires .
Healey Nut
Healey Nut
A day of getting all those little jobs done , fixing the boot latch so it closes properly . Trimming fling and shaping that little trim filler piece for the aluminum cockpit surround . Getting kick panels in and secure .Ashtray installed , not that I need it .
Door trim panels mostly done , one quarter panel in .Need to figure out the position of the side screen support plate on the door next .
Haven’t solved my indicator warning light issue yet but I think it’s the flasher relay itself that’s the problem . Will have to try a new one .
Healey Nut
Healey Nut
Getting close now .
Rob Glasgow
Healey Nut, where did you purchase your interior? You have the same arm rest with the rounded corners like I mine. I purchased mine from Sports and Classics but the kit may have been made by someone else. Most of the kits from others I have seen, have arm rests with square corners.
Healey Nut
Healey Nut
Carpets from Coverdale in the UK , interior panel kit from AH Spares via Autofarm in Canada .
Seat Covers and armrest are the full leather option from AH Spare ordered direct .
Zitch SOLD!! SOLD - Tri-Carb Exhaust manifold for a 3000 Austin Healey Classifieds 0
T Air Filter Recommendations for My Tri-Carb Austin Healey 7
HealeyPassion For Sale Tri-Carb Complete Set including manifolds Austin Healey Classifieds 13
Healey Nut Tri-Carb Throttle Controls Austin Healey 4
D Tri carb: order of installation question. Austin Healey 5
CLB62 1962 BT7 Tri-Carb for sale on BaT Austin Healey 2
D 62 tri-carb upper fulcrum pins Austin Healey 4
M engine stutter of rebuild BT7 engine [tri-carb] above 2500 rpm Austin Healey 27
lbcspinners 1962 Austin-Healey 3000 Mk II BN7 Tri-Carb 2-Seat Roadster: for sale on BaT Austin Healey 2
D Grose valves / Tri-carb Austin Healey 11
D Tri-carb PCV valve Austin Healey 61
D 62 tri-carb fuel line connection Austin Healey 10
C Tri carb Austin Healey 7
T Tri-carb questions. Austin Healey 10
J BT7 [Tri-Carb] Restoration Upgrades Austin Healey 2
D 62 tri-carb tuning question Austin Healey 8
D BT7 Tri-Carb Distributor Cap Austin Healey 9
D BT7 tri-carb linkage set up Austin Healey 23
D BT-7 tri-carb Two more questions Austin Healey 18
D BT-7 tri-carb ring gap Austin Healey 10
D BT7 tri-carb installing my crank Austin Healey 4
D 62 / BT7 tri-carb engine Austin Healey 16
D 62 tri-carb wiring harness Austin Healey 10
HealeyPassion Tri-carb intake manifold balance tube size Austin Healey 10
steveg Rare colored tri-carb BT7 on eBay Austin Healey 13
davidb AH 3000 tri-carb throttle shafts Austin Healey 13
W Barrett Jackson Auction 62 2 Seater Tri-carb only brings 48k Austin Healey 19
Norman Tri carb - overheating issue ???? Austin Healey 10
K Tri-carb help Austin Healey 11
K Tri-carb help please Austin Healey 0
AH67 62 MKII Tri Carb, done with some pictures Austin Healey 9
M WTB: Tri Carb Choke Linkage Parts Austin Healey 8
BoyRacer What are MK II [tri-carb] 2 seaters selling for? Austin Healey 12
D BT7 Tri carb Backfire Austin Healey 2
M Tri Carb Camshaft Austin Healey 4
B tri carb problems Austin Healey 17
B Gas mileage Tri-Carb Austin Healey 2
A tri carb on ebay Austin Healey 14
C Cold air box for Tri Carb 3000 BT7 ??? Austin Healey 9
G tri carb vapor lock Austin Healey 30
J Seeking tri carb help Austin Healey 16
M 100-6/ 3000 tri carb set up Austin Healey 13
Patrick67BJ8 Ruddspeed Tri-Carb Set-up Austin Healey 9
6 BN7 tri-carb will not start Austin Healey 7
6 BJ8-BT7 Tri-carb Conversion? Austin Healey 7
B PCV Valve Tri Carb Austin Healey 11
C Tri - Carb assistance ! Austin Healey 5
Dave Richards WOW! a "RARE" tri-carb Austin Healey 12
C AH 3000 Tri-Carb conversion. Austin Healey 4
V Choke cables for tri-carb Austin Healey 5
