TR6 Worn Thrust Bearings TR6
TR6oldtimer
Guess which bearing took the thrust from the clutch and the fan.
If you guessed the lower right, you were right. Over all end play was .016, and yes that thing is worn down to the bronze, and chunks came off on the ends.
Ray any idea how many miles are on them? what clutch assy are you running?
I've seen 'em a LOT worse, Ray. Good ya found most of the things in THAT condition.
Then they fall out, and you find them in the oil pan. Then you find a new block.
It's peculiar how some engines/ drivers wear those things down and some don't/
I have 2 sets that I've removed from engines. One set had over 100k on them. There appeared to be no babbit wear or if it was it was even. They mic'd at .0920 and .0925.
The other set with about 60k miles mic'd .0918 and .0910. Same story on the babbit.
Good, Tom!!
PB: It seems to vary with both materials and the frequency/duration of the left foot on the clutch, IMO. If the clutch is used momentarily they last. If it's "ridden" they poop out kinda quick whether "stock" or not. Tho Helms' ones are FAR superior to any "white box" replacements.
CuriousGeorge said:
How are these replaced? Is it an engine-out job?
Depends on how badly damaged other things are. The thrust washers themselves can be changed with the engine still in the car, but you'll need to drop the pan & the rear main bearing cap. With the cap removed, just slide the new washers into place, pushing out the old ones.
This engine had 80k+ miles on it. The clutch was stock. I drove the car as a daily driver, and I drove it hard, often flat out. I also have to admit that I did not take very good care of, or do the simple maintenance to the engine as I should have.
Oddly, or at least to me, the cylinders had only a .002" taper. Not bad, but the pistons had actually worn by .006".
Anyway, the TR6 engine is not going to be rebuilt by me. Faced with the need for the cam bearing insert line bore ($600), and the crank ground ($300), and an aluminum fly wheel ($370), I opted to save the $1,270 for other things, so I'll shove it back under the workbench from whence it came.
Instead, I will use a lower mileage TR250 block I have, install the dual timing gears and chain, punch it out .020, install the '73 head shaved .100, and of course, use the '250's lighter flywheel.
Oh, when the time comes to sell the car, I will throw in the old original block.
Hi Randall-
I have a TR6, new TRF magic clutch, heavy use in metro stop and go traffic.
I've no idea the condition of the thrust washers but everything else on the
car was badly abused and has had to be replaced.
How many of the T/W are there in a TR6 engine?
How do I know what size to order?
Can I see them from under the car while on jack stands?
What holds them in place? Bang them out with hammer & screw driver?
Bang them back in? I really don't know their function.
I loaned out my Bentley Blue and now have no visual reference books.
Thanks for the help.
Dale (Tinster)
Dale, when I posted this thread, I thought about you, and almost did not do it. Before you jump into replacing thrust bearings that may not need replacing, buy these two items.
Dial indicator stand,
https://www.harborfreight.com/cpi/ctaf/Displayitem.taf?itemnumber=5646
Dial indicator,
https://www.harborfreight.com/cpi/ctaf/Displayitem.taf?itemnumber=623
$20 +shipping is a small price to pay to find out if the thrust bearings are shot or OK.
You really do not want to lay on your back, under the car, with oil dripping all over you, unless you really have to do it.
This is what you will see when you drop the pan (except, hopefully you have rods and pistons in the block). If you look close, on the right of the picture, you will see a 4 stamped on the block. There should also be a 4 stamped on the bearing cap in the same orientation. Be sure the numbers on both are in the same orientation when the cap goes back in. Also, it takes a bit of work to remove that cap.
Here is a shot of the bearing cap off. Toward the back of the crank, you can see one of the thrust bearings, the other is in front.
Here is a shot of the thrust bearings as it rotates out. You can easily see there is quite a bit of space between the crank and bearing journal and how an extremely worn bearing can easily fall out.
Mains and rod bearings can also be replaced with the engine in the block, so while there, you may want to take a look.
This is the TR6 engine that I am not rebuilding.
If you notice the 2 oil retaining grooves on each ofthe Thrust bearings. They are only on one side. Be sure you put them in correctly.
The smooth sides are back to back, Grooves face flywheel and radiator.
TR6oldtimer said:
I agree, you should absolutely check the crankshaft end play before going through all that grief to replace the thrust washers. "Normally" they should last as long as the other bearings on the crankshaft.
However, I'm a bit leery of buying any sort of precision tool from Harbor Freight, unless you have the facility to check and adjust it yourself. For precision tools, I go to Enco:
https://www.use-enco.com/CGI/INSRIT?PARTPG=INSRAR2&PMAKA=605-4080&PMPXNO=1645544
In this case, it's actually cheaper anyway (as long as the sale lasts).
V GT6 Shifter Worn? Triumph 2
K TR2/3/3A Using a dial gauge to adjust valves when rocker arm surfaces are worn? Triumph 9
F Three worn hubs and wire wheel centers - What to do next? 1960 BT7 Austin Healey 6
2 Wanted SU-h6 Carb. BODY ONLY needed, badly worn. for TR3A Triumph Classifieds 5
aeronca65t Worn clutch bits, etc Spridgets 11
H TR4/4A Worn Fulcrum pins Triumph 5
L 100 timing chain worn? Austin Healey 7
5 Worn steering box Austin Healey 4
Rob Glasgow Worn Hub Extension Studs Austin Healey 2
TulsaFred What are the symptoms of worn throttle shafts? Spridgets 9
M Worn out throw out bearing Spridgets 4
mgnewbie worn/old front suspension bushes MG 3
PatGalvin TR2/3/3A TR3 Upper Wishbone Fulcrum Pins? Too Worn? Triumph 6
davester Is this normal for a worn out clutch? Spridgets 2
M Front hub worn out Spridgets 6
livinginthepast Anyone have a worn out old 948 engine for sale? Spridgets 9
M Tire Worn Uneven Spridgets 4
B worn Webber carb MG 7
Tinkerman Worn Shifter Forks Triumph 6
jcatnite Worn gears Spridgets 15
Thor Do you have to ream swivel axle if not worn? Spridgets 6
Mark Jones Differential nut removal & worn thurst washer Triumph 1
Bob_Carroll TR6 Worn #1 Exh Cam Lobe - TR6 Triumph 9
B TR6 Thrust face repair Triumph 1
KVH General Tech Thrust Washers Triumph 2
newmexTR3 TR2/3/3A How to remove thrust washer from lower wishbone & trunion Triumph 7
B TR4/4A Thrust washer issue Triumph 11
P TR2/3/3A Crankshaft Thrust Washers Triumph 4
JPSmit Midget Thrust bearing coonversion Spridgets 9
Csarneson Source for Distributor Fiber Thrust Washer Austin Healey 3
K Thrust washer Austin Healey 4
J TR6 Thrust washers in sump Triumph 4
J TR2/3/3A Crankshaft thrust washers. Triumph 2
PeterK Wedge TR7 thrust washer Triumph 0
B TR2/3/3A where to buy oversize thrust washers for TR3B? Triumph 16
Gerard Laygear thrust washer for ribcase gearbox Spridgets 5
H 4.2L distribitor drive distance/thrust washer Jaguar 0
M Healey Crankshaft Thrust Washer Thickness Austin Healey 3
P those infernal thrust washers Triumph 11
H Crankshaft Thrust Washers Austin Healey 2
O Spitfire Spit 1500 Thrust Washers? Triumph 13
6 thrust washers & cam Triumph 7
Monark192 MGB MGB Diff Thrust Washer Question MG 2
S Tachometer thrust button Austin Healey 1
T ever see a rusty thrust washer? Triumph 10
T crank thrust bearings Triumph 5
K TR2/3/3A TR3 thrust washers wishbone arm to trunnion ? Triumph 6
Jim_Gruber Wheel Bearings and Thrust Label Spridgets 6
healeyboz replacing a thrust bushing Spridgets 6
M pining the thrust washers on 1500cc Spridgets 10
