Working with new carpet kit to install
bighealeysource
Bronze
Hey all,
Know I have seen a similar post about installing a new carpet
kit but can't find it. Have new carpet kit from AH Spares and it is a nice quality hessian backed carpet very close to the original. Problem is it is as stiff as a board !! I believe
I read where someone else had a similar problem and steamed
the carpet to work it so it would install easier ? Does
anyone recall this or have any ideas on how to make this
stiff carpet more flexible to work with as I install the
fitted pieces ?
Thanks,
Mike
bighealeysource, last summer i watched a pro. interior installer that only does expensive high end cars using a heat gun around areas that needed to be contoured to fit.
T Turn Signal Indicator Not Working Austin Healey 6
D Trying to get back working on the 1974 Midget Spridgets 45
T Wanted Working overdrive unit Austin Healey Classifieds 2
D Overdrive Stops Working After Oil Change Austin Healey 26
S TR2/3/3A my OD stopped working after it was working Triumph 25
D TR2/3/3A Traffic at or and horn button not working Triumph 2
tr6nitjulius For Sale TR6 working/clean parts 4sale Triumph Classifieds 0
O Spitfire Tail lights not working Triumph 6
T Wanted Working Fuel Gauge for TR3A Triumph Classifieds 5
rgfrey 1959 Low Beam Headlights Not Working Austin Healey 5
Celtic 77 MGB Non working tach. MG 4
M Tachometer not working following ignition upgrade Austin Healey 10
S TR2/3/3A LED turn signal -- panel flasher not working Triumph 5
KVH General Tech Speedometer Not Working Triumph 5
S TR2/3/3A Horn not working unless I rotate the control head Triumph 6
S TR2/3/3A Speed O not working Triumph 27
M Wiper Motor Problem Not Working Spridgets 5
TRclassic3 TR4/4A A type OD working in 3rd but not in 4th Triumph 5
W Healey 100 Overdrive stopped working Austin Healey 15
1 MGB Lights not working MG 11
A MGA High beam indicator light not working MG 2
1 MGB Speedometer and tachometer on '66 MGB are not working MG 8
2billydavies TR2/3/3A generator doesn't appear to be working Triumph 7
Airwave BJ8 overdrive stops working after a while driving Austin Healey 17
warwick-steve Direction indicators not working Austin Healey 29
L Wanted WANTED: good Working Oil Pressure GAUGE Triumph Classifieds 0
Martinld123 Austin Healey 100 BN2 fuel gauge not working Austin Healey 13
Jim_Gruber Brake Light - Getting them working Spridgets 8
Superwrench Tach not working Austin Healey 6
M TR2/3/3A Panel lights not working........ Triumph 5
Rhodyspit75 Working on the Bugeye body Spridgets 19
J General TR D Type overdrive not working need suggestions Triumph 5
J Helping out some students working on a 59 bugeye Spridgets 6
R Master Cylinder change working Austin Healey 12
F Overdrive - working but not really working Austin Healey 14
T TR2/3/3A Air dam seems to be working very well Triumph 5
BN6_2197 BN6 brakes not working properly Austin Healey 9
bugedd Fuel guage not working Spridgets 7
Nelson Working under the car Spridgets 5
T Horn and rear right indicator stopped working...head scratch imminent Austin Healey 16
R Choke Not Working In Cool Weather Austin Healey 15
D new mecahnical fuel pump not working Spridgets 8
Gerry M TR6 Speedo stopped working Triumph 6
DanLewis Looking for an old-style fuel gauge [working or not] Spridgets 3
P I need a non-working electric tachometer for parts Spridgets 0
DerekJ Left side indicators not working. Austin Healey 3
G MGB STILL working on clutch slave MG 37
bigbadbluetr6 TR6 Rear tail lights not working. Triumph 17
J Funniest thing you found working on your car Austin Healey 32
B Horn Quit Working Austin Healey 14
