DerekJ
My left side indicators stopped working at the weekend. May or may not be connected to the fact I was at a Hillclimb where there was heavy rain during the event and the 200 mile round trip.
The facts are:
- Indicators operate by switch on the dashboard not via a trafficator.
- Brake lights work
- Front and rear side lights work
- Indicators work on the right side
- All filaments in left side bulbs are intact.
- I have 12 volts at the solenoid connections on the relay box (connection numbers, 8, right side and 4, left side)
- Connections 3 and 2 (left side indicators) read between 2 and 5 volts approx when indicator switch is on
- Connections 7 and 6 (right side indicators) appear to fluctuate between 3 and 8 volts when indicators operating correctly
- When left side indicator switch is selected I can hear the clicking of the indicator relay itself.
- the external wire connections to the relay box appear to be ok but I will re-check.
Does the above mean the problem may be in the large relay box?
Only other thing might be a poor connection of the green/red wire to the front light or the purple/white wire to the rear.
Any other ideas?
The facts are:
- Brake lights work
Any other ideas?
