TR2/3/3A Tyre question, and an Latest
Konrod
Member
Tyre question, and an up-date
Hi all
The manual says 22psi on standard tyre. I have new Michelin XWX fitted all round, and at that pressure the steering is way too heavy even when moving. 30 psi seems better, but the rear does "skip" over larger ruts. What is the collective view of the right pressures with "modern" tyres?
Aside from that my TR3a odyssey continues. Fitted the OD gearbox which works a treat, did full engine setup from scratch - points gap, valve gaps, plug gaps, timing, carb balance and mixture (with colourtune) and it is running like a sewing machine. All of the hesitancy has gone and it runs sweetly. I also gave in to my wife and fitted seatbelts.
Of course, it isn't that simple. The the car has been spitting brown water from the radiator overflow, and then the temperature started rising and wouldn't stop, and the filler cap was coated on a brown sludge - I was concerned about a head gasket failure, but there isn't any oil in the coolant, or water in the oil and the compression tests are all consistent at about 130. I've emptied what was left of the coolant, used a pressure hose on light setting to blow out as much as I can from the block, heater and radiator, and plenty of sludge came out. The two parts of the thermostat housing were siezed together (PO has used sealing compound with no gasket) so I lost two hours of my life geting them apart without damaging them. The result was the area behind the stat was full of sludge and I think it was stopping the stat (bellows type) from opening.
Looks like the car hasn't been used much and there was no antifreeze/inhibitor and the coolant, creating a rusty sludge. So having blown everything out, I have had two goes with radiator cleaner which shifted some more, but was pretty clean. Still a bit nervous about the temperatires but with antifreeze and distilled water in it it seems to be behaving itself.
We set off for Le Mans next week which is 1000 mile round trip, so I want to limit the problems on the journey.
K
Konrod
Member
Re: Tyre question, and an up-date
Sorry, should have said that. 165 R 80 on 15" wires, so pretty much standard size.
James Christie
Try 24psi ar front and 26 psi at rear. Then you can fiddle around adjusting according to your requirements
james
ckeithjordan
When I had new Michelin XZX 165SR15s put on new wire wheels by Hendrix Wire Wheel in January, they recommended 30psi all the way around.
Keith
1957 TR3 TS20447LO
Geo Hahn
I am probably an extreme outlier here but I run 34psi front and 36psi rear. Harsher ride to be sure but lighter steering.
I believe that so long as you do not exceed the maximum pressure noted on the sidewalls you can experiment to discover what works best for you.
Geo Hahn
In the current thread 'Steering' I see this comment:
...Tires and how they are inflated makes a big difference too. I run about 32/36 instead of the 24/32 given in the book (for radials).
Just something to keep in mind as you explore higher air pressure.
Andrew Mace
I suppose one could try the old trick of some white shoe polish across the treads and well up the sidewalls inside and out, followed by some "spirited" cornering (think autocross/ Solo II style stuff) and then observe how much of the shoe polish you wear off and how far up the sidewall. Obviously too far up the sidewall is not a good thing.)
Alfred E. Neuman
The exact opposite of a sport bike. Used to call the unscuffed area up near the rim "chicken Strips" :highly_amused:
B Tyre question Other British Cars 1
Simon TR4a Tyre [tire] storage question. Restoration & Tools 4
S BN1 Wheel-Tyre Combination Austin Healey 10
Hamish Racing 3 sisters sprint deformed tyre Racing 4
Hamish Racing General Tech Wheel and tyre selection Triumph 11
L Tyre diameter less than 680mm but bigger than 640mm, any ideas? Austin Healey 11
D Scuttle shake and tyre pressures Austin Healey 2
T determining tyre pressures Austin Healey 9
T Trying to find an accurate tyre pressure gauge Spridgets 24
T Finding an accurate tyre pressure gauge? Spridgets 5
T intermittent deflating tyre Austin Healey 6
Z BN1 Tyre Diameter Austin Healey 8
T 100 4 Tyre Pressures Austin Healey 3
W GT6 GT6 MK3 "TYRE" sicker Triumph 3
blackdog Tyre rubbing under hard cornering Austin Healey 12
T Spare Tyre vs 'Inflate & Seal" Austin Healey 10
T Free Dunlop Gold Seal 5.20 13 bias ply tyre Spridgets 5
T Tire [tyre!] pressures Spridgets 1
1 BE spare tire [tyre] is slipping Spridgets 17
Geo Hahn Tyre Balancing Triumph 13
O tyre wear Triumph 3
J Tyre and wheels size Spridgets 9
Chatis Tire's [Tyre's] for a Bugeye Sprite Austin Healey 2
Kira Tyre Help Restoration & Tools 2
M MGB Disributor clamp question MG 1
K TR2/3/3A Cylinder head stud height question? Triumph 4
DonC1948 TR6 A "CLASSIC" question. Triumph 6
K TR2/3/3A Cylinder Head Bolt question.... Triumph 3
D TR2/3/3A TR2 Flying Mile question Triumph 11
M New Member with an HD8 Carb Question Austin Healey 1
Gliderman8 TR6 New shocks (damper) question Triumph 4
D TR2/3/3A Windshield assembly question Triumph 6
T MGB Quick question about something that don't really matter just want to know. MG 9
CARSINC Throttle linkage question Spridgets 1
S TR6 Steering question you will not hear every day Triumph 1
JPSmit Hypothetical Question of sorts - wheel bolts Restoration & Tools 12
E TR6 TR6 flip-up bonnet question Triumph 4
D TR2/3/3A headlight question Triumph 8
D A distributer question on the 1275 engine. Spridgets 7
P TR2/3/3A TR2 Headlight Trim Question: Triumph 8
SherpaPilot TR6 Ignition Switch Question Triumph 13
