TexasSprite
I have a 59 928 Sprite with a smooth case transmission that won't disengage the gears even though the shifter appears to be in nuetral. It feels like you can shift forward or back into a gear, but not the whole pattern of 1-2-3-4-R. The clutch hydraulics are not functional, but shouldn't you be able to at least shift the gearbox into nuetral?
The PO said that he put the car into storage 16 years ago when he couldn't get it out of reverse. (now I know why the propellor shaft was disconnected at the differential). He also said this was when he noticed that the MC was dry. I've got a resleeved MC on the way, but I'm wondering if that is going to fix the problem.
Any ideas?
Any ideas?
