TR4/4A Trans/OD gear oil?
shoopal
What to use? The official TR manual says 90 wt. The laycock overdrive maintenance manual says SAE 30 wt. Some posts and Buckeye have recommended red line GL4 Mt-90 or Mt-85 or MtL
Leo Ruof (an OD rebuilder whom I trust) says 30 Wt. and is pretty adamant about it.
What is the final answer?
Recently a few owners that I know have had issues with rebuilt OD's not releasing OD because of clutch sticking. RedLine MT-90 resolved it in all cases. I use MT-90 with good results, remember technology has come a long way since these units were first built. SAE 30 weight is really designed for engines not transmissions and it too has changed over the years with modern additives designed for modern engines. No disrespect towards your OD builder friend only my personal experience with my OD and others.
Jerry...thank you for the info. I have a fresh rebuild that sticks, so I have to get under the car and rap the ring with a hammer to release it. I'm using ND 30w. I was considering a post about the sticking, but you answered the question! I'll grab some Redline today!
Shoopal,
There are so many opinions on what is best for the Laycock de Normanvile OD, anything from SAE 30, GL4 90 Wt, MTL, ATF, etc, etc..
My Volvo 240 used ATF in it's Laycock de Normanvile OD equipped transmission, and it was still running strong at 335,573 miles when I sold it, and last I heard it's still running strong today.
I have been using Redline MTL in my TR4's OD transmission for years without a problem.
The transmission shifts better with MTL, or at least mine does.
YMMV.
M.
In one case (a racer) it took several iterations but eventually started working well. He's a bit anal about his oils and went back to a Brad Penn product once it started working. Have not heard any more about his issues. May see him next weekend and will ask. Other cases it was an immediate fix. Yours may be different but whatever you do don't back up with it stuck.
Leo replies:
"I am a fan of putting in what the factory calls for. Redline will
definitely "seep"
(my word, he used a different one - a synonym of urinate which for some reason got blocked)
out around the cross shaft o-rings. It will also bleed
around the actuating piston if they are the o-ring style. Which can
change the way it engages. Redline can also foam"
I had the exact same issues as you described in a previous post only I initially filled with the mt-90 and after the first rap(as directed by rebuilder) the od released and I flipped it in and out a few times on jackstands and it never stuck again .
8K miles and everything is fine except for the bronze looking fines in the oil changes which I suspect is more from the clutch than thrust washers,but I have never seen the clutch material so time will tell.
Tom
My personal experience does not support any of his objections, I used Hylomar sealant the last time I had it apart and my leaks are now less than the previous assembly. Don't recall if I have the O-ring style pistons, I've had several apart over the years and have seen both types. Just don't recall.
TFB - the brass won't be from the clutch it's material is similar to an actual clutch disk. If you put in new syncros they are a likely source too. I don't think it's s sign of pending doom as my gearbox did that too and has run just fine for a long time.
Thanks,yes I believe the syncros are new ,And everything I have read about the bronze/brass fines is don't worry,but I will be changing the oil more frequently than if it came out cleaner.
Tom
I drove around looking for the Redline yesterday with no luck. I did engage the OD couple times and it actually came out without sticking. It may take a while for the cone to shape the friction material after a rebuild? Anyway...I still plan to go with the Redline when I can mail order a couple quarts. Thanks!
I buy MT-90 locally at Summit Racing, surprised that a speed shop in the Dallas area doesn't stock it. Doubt the local parts store would however.
Might be worth pointing out that Standard-Triumph changed their recommendation to GL4. So the Redline IS what the factory recommended.
I've been using it for over 10 years, and it works well for me. Leaks are no worse and the main gearbox shifts noticeably better.
Quick follow-up. I finally got the TR2 back on the road after changing to the Red Line GL-4 (from ND30w oil). The tranny shifts great and no sticking in OD. The OD engages instantly and disengages in about a half second. So I'm sold on the GL4!
M correct gear oil for bj8 trans and overdrive ???? Austin Healey 5
steveg Toyota W58 Trans Hard Getting Into Gear Austin Healey 8
K TR2/3/3A Help!..Installed new Clutch....Trans stuck in Gear? Triumph 8
RedTR3 TR2/3/3A Trans Gear lever interference Triumph 0
M trans popping out of 4th gear Austin Healey 5
bighealeysource BN2 trans gear lever getting stuck Austin Healey 8
K trans pops out of gear Austin Healey 13
Tim Hollister Rib Case Trans Problem - 1st Gear Spridgets 6
AUSMHLY BJ8 Trans Cover Carpet Austin Healey 7
T General TR Another trans popping out of 2nd Triumph 14
S TR2/3/3A engine and trans are stuck together pretty well Triumph 8
AngliaGT Pontiac Trans Sport / Honda Insight Spotted 1
EWD TR6 ‘74 TR6 Starter & Trans Cover Triumph 13
B COMPLETE DROP-IN Rebuilt 1975/6 MG Midget 1500 engine PLUS rebuilt Spitfire Overdrive trans NEVER INSTALLED Spridgets Classified 2
skystryd Trans and Diff Spridgets 7
G Trans Axle Parts Lotus 20
tinman58 TR5/TR250 Trans slipping in reverse Triumph 38
R General Tech Preserve eng/trans that has been removed Triumph 11
S For Sale 3000 BJ8 Laycock 4 speed with 22% OD trans & 2 6 cyln engines / long blocks / BUNDLE Austin Healey Classifieds 1
S For Sale RARE FIND BN2-BT7 and? Trans Parts for Sale Austin Healey Classifieds 2
T Toyota 6 cylinder eng & trans in a BJ7 Austin Healey 0
Superwrench For Sale 62 BT-7 Trans. and OD unit for sale Austin Healey Classifieds 0
doc50 NASH METROPOLITAN trans capacity? Other British Cars 0
RAC68 Alternate Trans/OD Oil Selection Austin Healey 17
doc50 Nash Metroplitan trans swap? Other British Cars 33
Bob Claffie Spitfire Engine & trans compatability Triumph 1
B For Sale 1956 Austin Healey 100-4 SCCA big bore race car plus parts lot engine trans etc Austin Healey Classifieds 0
P 5spd Trans for Bugeye Sprite Spridgets Classified 14
RAC68 Another Discussion of Trans/OD Fluid Austin Healey 14
S Smitty trans Master cylinder Austin Healey 21
C General MG Midget trans mounts MG 0
R TR2/3/3A Transmission fluid for 57 TR-3 Manual OD Trans Triumph 3
D TR4/4A Trans replacement front oil seal not same size as original Triumph 2
D TR4/4A broken trans fork pin Triumph 14
C TR4/4A How to get the $&@%# filler bolt out of the side of the trans to top her off?!? Triumph 7
histerical Dat Trans Spridgets 2
bugedd Datsun 210 Trans Question Spridgets 9
M TR4/4A Covers at side of H frame over the trans tunnel...ideas please. Triumph 9
K TR6 Thread repair for trans cover bolt Triumph 14
S TR2/3/3A driver side on the trans-cover? Triumph 11
tinman58 TR5/TR250 Trans swap Triumph 2
NutmegCT Any Borg-Warner automatic trans experts here? Other Cars 5
N Trans compatibility Spridgets 6
RAC68 Loud Trans Scrapping Noise Austin Healey 9
britlover TR4/4A Where can I get an A-type TR4A Trans rebuilt in SE Michigan? Triumph 9
M TR2/3/3A TR3 overdrive trans rear speedi sleeve Triumph 6
S TR2/3/3A overdrive trans Triumph 11
R GT6 GT6 trans issue Triumph 3
S TR2/3/3A Test an overdrive trans. Triumph 6
K TR2/3/3A TR3A with TR6 trans Clutch Bleed Issue Resolved. Triumph 6
