britlover
I'm well into my engine rebuild, starting to wrap up the bottom end, and I need to know if my machinist lost some washers. The bolts that keep the cam bearings located appear to extend beyond the bearing surface if I run them all the way in. Is there a copper washer required on these? I can't seem to find any reference to any in the manual or online. The bolts will foul on the cam journals without something to shim them out a bit...
