tmc
I'm at the wiring - electrical - fuel - cooling system stage of my restoration. At the moment,I'm trying to remember if this car was positive or negative ground. I have pictures of the firewall with everything in place, but I cannot read the + - symbols on the battery posts. It appears to me the battery is in "backwards" and the negative post is grounded, with the positive post connected to the solenoid. The voltage regulator that it came with is a later model with blade attachment; however, I have the older version to replace it with. All the above leads me to think it's been "converted" to negative ground.
It appears to me from my reading that this car was originally positive ground, which was true until after TS60001. I don't plan to add a radio, or electronic ignition, or whatever, this is a restoration to original except for some "sensible" upgrades.
What are the pros and cons of positive or negative ground, other than the obvious (it's different than most other cars and jump starting it wrong can be disastrous)?
