I have changed the solenoid and the overdrive start to works again and it is perfect. After about 30 times the overdrive was burnt again and in the same time the throttle switch start to have a strange rumor after that i put out the throttle switch and opened the coffer to see if there was something wrong that didn't work. After the change of the solenoid i put on again the throttle switch but it made a more strong rumor and i have decided to put it out. i want ask to you if i can use regulary the overdrive without the throttle switch. also i've decided to put one fuse (10 amper) to protect the solenoid do you think it's correct?
P.S. Andrea i'm from Lucca. I have seen your restoration, congratulations, it is perfect!!
