Stock tire size
Morris
Hey guys, I am trying to figure out the odometer error ratio for my car. Finding calculators to do this for me is no problem. But, I can't, for the life of me, figure out the diameter of the stock tire.
Can someone help me out?
Chalk, driveway, tape measure
diameter=circumference/pi
The stock tyre is a 145SR13 which is a 145/80R13 in modern terms. This equates to 562mm OD or 22-1/8".
Rolling diameter is what you want. Unloaded diameter will be larger than rolling diameter. Measure the rear tires from the gound to the axle centerline and multiply by 2 to get rolling diameter. This takes into account the weight compresssion of the sidewall.
JPSmit said:
https://www.1010tires.com/tiresizecalculator.asp
odometer ratio will be the same as the speedometer ratio
not quite true.....i changed the rear end from a 4.22 to a 3.9, introducing more error than was already present.. now i have a 7% error in speed plus or minus, but a 15% error ratio in the odometer, as measured thru 20 plus miles of interstate, using both a stopwatch. .. these speedo's aren't all that accurate.. at least MINE isn't.
I never even thought to check my odometer. I will check it next time against the GPS and see how far off it is. I know my speedo reads 7mph slow and 45 is really 52. I need to fix that because it is off the "bad way"
a CONSTANT 7mph slow? no matter your speed?.. take off the needle and put it back on in the right place! simple fix for that.. if its a percentage error, that's quite a different problem.. if its a steady 7%, someone changed the rear end from a 4.22 to a 3.9!
Ha, no I changed from a 3.90 to a 3.55 and then added a 5 speed. I need to do some more testing to see how linear it is, but that is what I am going to do frist is adjust the needle. I will make it right at about 60 and then hopefully it will be close enough through the rest of the range. I got gearing for days now. One for every occasion :lol:
Jim_Gruber Tire Size and Stock BE Wheels Spridgets 40
T TR4/4A largest tire and wheel combo?? for a stock tr4 Triumph 10
D Stock Camshaft TVR 0
jfarris For Sale TR3 Stock Fan used (1956) Triumph Classifieds 0
V MGB Stock Alloy Wheels from Other Cars That Fit 4 114.3 and 14" with correct offset? MG 10
nichola TR6 Stock exhaust sound... short video Triumph 4
Joel Lester TR2/3/3A Are all "stock" camshafts the same? Triumph 9
F Wanted wanted new old stock driver side door latch Triumph Classifieds 2
johnrip Wedge Tires for TR7 stock alloy wheels Triumph 1
steveg TR6 Installing stock trailing arm bushings on the car - is it possible? Triumph 2
S TR2/3/3A stock fog light Triumph 2
PC Actually in stock? Spotted 0
S TR2/3/3A Stock air cleaners and aftermarket air cleaners. Triumph 7
S TR2/3/3A Mounting a stock steering wheel. Triumph 3
M TR4/4A Fuel Line Fittings - Stock or Upgrade? Triumph 6
R Upgraded rod bolts for stock rods Austin Healey 1
S New Build Stock Wheels? Spridgets 38
T How to add a bit more realiability/endurance to a stock 1275 engine rebuild? Spridgets 9
B Wanted stock Bj8 distributor Austin Healey Classifieds 1
S For Sale Triumph tr3 tr3a tr3b tr4 tr4a differential cover new old stock Triumph Classifieds 0
simon1966 Rarity of Stock 100! :-] Austin Healey 13
T Front Tilt or Stock Fit Bonnet Spridgets 18
I Tips for installing intake manifold plugs in a stock Bugeye? Spridgets 6
S For Sale Tr3 tr3a tr3b tr4 tr4a differential cover new old stock Triumph Classifieds 0
Jim_Gruber Thoughts on stock '69 1275 manifold vs LCB Headers for street use Spridgets 9
T Tilting the stock seat for comfort Spridgets 6
simon1966 Does taking a stock BN1 and adding M bits increase its value? Austin Healey 10
T WW Axles in stock Bugeye housing? Spridgets 7
L Modifying stock shift surround for Datsun 5 speed Spridgets 20
K TR4/4A Stock Triumph Radio Troubleshooting? Triumph 4
C Smaller diameter steering wheel - that looks like stock? Austin Healey 16
G TR6 TR6 air filter element replacements for stock housing Triumph 3
CJD TR2/3/3A Stock Valve Lift Triumph 3
RJS TR4/4A TR4A Stock Ride Height - my measurements Triumph 0
CJD General TR BSW thread stock Triumph 2
T TR4/4A Flywheel... Lightened or Stock, that is the question Triumph 14
RJS TR4/4A TR4A Stock Ride Height Triumph 5
Gerard Anybody have a steering wheel emblem for '68 Sprite stock steering wheel? Spridgets 11
K TR2/3/3A Lightening a stock TR3A flywheel..... Triumph 13
M Healey Mk2 with Colored stock steering Wheel Austin Healey 3
B Found more unopened stock to ofer/trade/giveaway to a good home Spridgets 0
C Stock seat belt color? Austin Healey 11
K Converting a MkII with a V8 back to stock Jag 6? Jaguar 3
Ed_K Modifing the stock BJ8 air cleaners Austin Healey 0
T TR2/3/3A Attaching HS6s to the stock TR3 manifold. Triumph 3
D Stock oil filter vs spin on filter Austin Healey 17
R Planing my built. Stock vs transplant Spridgets 58
T Single Weber Redline carb for stock Midget 1275 Spridgets 12
T stock bugeye front springs Spridgets 4
T Milling a head on a Stock 1275 for compression? Spridgets 13
