TR4/4A largest tire and wheel combo?? for a stock tr4
trfourtune
Hi all,
I am sure this has been dragged out a thousnd times, but what is the largest tire and wheel combo that will fit a stock fendered tr4. Car will be lowered as well, planning 100mm-125mm ground clearance.
thanks
Rob
toysrrus
Hi trfourtune,
I`ve seen quite a few TR4s with "Stock" TR6 rims and tires. The look is pretty nice if thats what you like (15").
I`m sure you`ll get to see a bunch of pics on this thd. regarding your request.
Russ
T
trfourtune
can a 205 series tire fit without fender modifications?? 7" rims?
Rob
TR4nut
Someone will prove me wrong, but I really doubt you can fit 7" and 205 profiles - particularly if lowered. I think in the front you will either get fender clearance issues, or interference on the upper a-arms.
Randy
T
trfourtune
I have seen 205 series on 6" wide wheel on tr6 and i know i can fit 195/65-15 tires on 5.5" rim but am considering bigger.
Anyone??
DanB
I put 215/60 15s on mine, but I had to space out the wheels because of their offset. I am using a set of Sendel wheels. The spacers correct the offset of the wheels and bring the tires out to the edge of the flare. There is a lot of discussion on wheel and tire size on the forums at Britishv8.org
Dan
T
trfourtune
thanks Dan. I saw mostly tr6 fitments except for one with 6" tr6 wheels and 205 tires. doesn't seem to look right though. it looks like the OD is smaller and the car needs to be lowered more to take up that space above the tires. Oh well, guess i cant have my cake and eat it too.I like the look of the 195/65-15's OD filling the space just considering grip though.
R
T
trfourtune
dan, is that tire on a 6.5" wheel?
R
toysrrus
Hi trfourtune,
Take a look at a `65 TR4 on www.britishcarlinks.com classifieds.
Mean looking little sucker with TR6 rims!
Regards,
Russ
DanB
I honestly can't remember, but I am thinking they are 7"
I looked up the original diameter for the stock tires, and the 215/60s match it almost perfect. Interestingly, the 165 recommended replacement radials for the stock bias tires are quite a bit smaller in diameter.
I don't have a picture of the car with those wheels and tires on it yet. I will try to remember to take one and post it this evening.
T
trfourtune
the 165 original tires are 25.4" diameter. not too many 15" performance tires come to that diameter. I didn't want to up size the wheels to 16" or 17" but who knows, Its all bench racing at this point. Bigger wheels make it much easier to fit a serious brake upgrade.
T Largest tire size I can put on my 89 xj40 Jaguar 1
tr6nitjulius TR6 Largest gathering of TR6 on the West Coast Triumph 0
J TR2/3/3A I just found the LARGEST bolt on a TR3A Triumph 5
JPSmit Tonight is the largest lottery in Canadian History Spridgets 5
T OT - worlds largest eBay marshmallow seller Triumph 6
J Largest Tires on R/B Midget Spridgets 1
S TR2/3/3A Tire balance Triumph 15
J MGB Tire pressure for 1980 MGB MG 14
T Tire Age Austin Healey 14
R 2500M Inner Fenders - are they the same as a Vixen 2500? (Also Tire Size) TVR 3
Frameman 1949 Tire Options Austin Healey 16
T TR6 TR6 Tire Pressures Triumph 2
NutmegCT Tire pump in reverse? Restoration & Tools 5
prb51 BN6 Wheel/Tire Combo Austin Healey 26
JohnGone Wanted Q: Small Boot, Small Spare Tire? And, Jack needed. MG Classifieds 2
F TR4/4A Tire saver ramp recommendations Triumph 10
D Wanted Austin healey Tire - used Austin Healey Classifieds 4
Bocaray TR2/3/3A Centred Tire Triumph 3
H Wanted Need Spare tire rod BJ8 Austin Healey Classifieds 1
S For Sale Tire for Sale (155SR15) Triumph Classifieds 3
F TR2/3/3A Spare tire cover Triumph 8
S TR2/3/3A spare tire compartment holes for modern license Triumph 8
Mark Bailey Old tire rule? Restoration & Tools 5
Healey Nut Tire Sizes Austin Healey 10
F TR2/3/3A Spare tire cover Triumph 3
P Wanted E type spare tire bracket Jaguar Classifieds 2
P Wanted 62 E Type spare tire bracket Other British Classifieds 1
K TR2/3/3A Tire pressure and ride comfort? Triumph 9
P TR6 What make and size tire was on the TR6 when it left the factory? Triumph 7
G Rear tire scrubbing!!? Spridgets 23
H Can a 175x13 tire be fitted on Bugeye Spridgets 6
M TR5/TR250 Compatible Modern Tire Size Triumph 5
L TR2/3/3A tire manufacturing build date Triumph 2
K TR2/3/3A Optimum Tire pressure for a TR3 daily driver? Triumph 5
J TR6 Tire Recommended for TR6 Triumph 3
S TR2/3/3A tr3 spare tire fit Triumph 16
K TR2/3/3A TR3B Tire/Wheel Advice Triumph 2
L General TR tire age code Triumph 3
H TR2/3/3A Original Dunlop 5.50X15 Bias Ply Tire Data Triumph 4
AUSMHLY Wheel Tire Camber Austin Healey 57
madhouse Tire pressure monitoring system [TPMS] for Healey? Austin Healey 0
tahoe healey Tire pressure again Austin Healey 59
Raymond MGB Wire Wheel Tire Mounting MG 0
T General TR Wire wheels - tire mounting/balancing - Southern California Triumph 14
O TR2/3/3A Spare tire Triumph 4
M Brake fluid on tire - cylinder need replaced? Spridgets 19
F TR2/3/3A Spare Tire Size Triumph 11
H Tire choices for Bugeyes Spridgets 14
