TR2/3/3A Starting from scratch what color
Jayplum
Have my 57 TR3 torn down. Getting ready to get into engine.
seeing light green paint on some parts, oil sump, front plate, etc.
any suggestions on getting back to OE? Is there a site addressing this?
Car is signal red; will repaint engine compartment in same.
Got_All_4
Best way to find out the original color is o order a build certificate from British Heritage. I did that on my second round on my 1960 TR3A. Bought it from the original family in 1976 in primer and they said it was off white. Didn't do a lot of research back then and the cars weren't worth much then so I had it painted Layland White. After driving it for almost 30 years took it's tole on the finish and original rust was starting to come through. Plus the fact the cars were significantly increasing in value, it was time to redo it correctly.
Anyway my point is going to be that I did just that and found out it was Sebering White. Not a color that can be duplicated with modern paints. Many paint codes out there but none of the paint companies could come up with a formula. I waited too long to find all that out and delayed my project. Got lucky after Googling and after months of reading Google pages (I thing I was on page 300 +) I found a discussion on a defunct forum where two guys were discussing the color. Not an actual formula but I was able to get a great match from that search. Good luck!
Jayplum
Jayplum
Yeah, folks don't know how hard white is to match and the number of variations there are. My TR6 was painted by PO and the closest I could come was Chrysler's artic white. I painted the engine compartment with a factory pack based on Triumph's chart and it was very different. Had to paint the upper cowl and underside of bonnet just to minimize any difference.
DavidApp
Two white TR3s. The colour difference is slight but was discernible. Mine the closer one has a more yellow tone to the white. It was taken from the GM code for Dover White.
David
Jayplum
Jayplum
The white on my 6 was so far off, standing by the door and looking at the engine compartment it was very obvious difference with under the side. Almost takes the touch and feel of the old time painters; knew this father and son pair who painted so many gas doors or let down panels even on newer cars just to get a match. But I could trust them completely to get a great job.
glemon
Yes, modern paints really do look different than the old stuff, so if you really want it to look original a lot of work is involved. A single stage will get you closer to an original look, but basecoat/clearcoat is sort of the expectation for gloss and depth of shine these days. Get the original Triumph TR book by Piggot for more information on what color various things were painted. https://www.google.com/shopping/pro...jEm9IjblCzIdfcjf-M0mqZQymog,cdl:1,prmr:1,cs:1
Jayplum
Jayplum
My car has 2 stage on her but I believe a good buffing and a couple chip repairs is all I am doing on the exterior.
engine bay will be single stage.
ckeithjordan
So this with the original post questions is a bit confusing (to me). Are you asking what color to paint the car, the engine components, the engine compartment?
Jayplum
Jayplum
All undersides and the nooks and crannies show the same what I think is Signal Red. Exterior is clear coated. She was professionally repainted a couple years ago by PO.
Jayplum
Jayplum
Yes. Tried to up load earlier. But obviously not successful.
Jayplum
Jayplum
Originally asked about engine components, ie front plate, timing cover, sump, oil filter canister, etc.
I got off topic talking paint. I am painting the engine bay I body color.
CJD
Front plate was black, timing cover black with a grey noise deadener, sump black, oil filter a sort of aqua blue/green, oil filter head natural, water pump black, pulley and extension black, valve cover likely chrome on your year...black for earlier cars, fuel pump natural, dizzy natural with a black pedastal.
I think that covers most of it. The black was a semi-glosss by today's standards.
DavidApp
Thermostat housing natural. Engine block was black I think. Have seen a few photos of blocks with what was said to be the factory original vehicle designation in red pant done by hand.
David
Baz Starting from scratch. Racing 28
W starting from scratch. need help to get started Austin Healey 13
K TR2/3/3A Pushing down the clutch pedal when starting the car? Triumph 13
angelfj1 TR5/TR250 TR250 - Lucas 4ST Starting Solenoid-Mounting Location/Details Triumph 2
bigjones TR2/3/3A Starting up an engine that hasn't ran for a while. Triumph 39
S TR2/3/3A TR3 Hard Starting Triumph 4
H MGB Starting Problems MG 3
J TR4/4A 1964 Triumph TR4 - Not Starting/Running Triumph 3
angelfj1 TR5/TR250 Starting a TR250 that's been sitting for 10 years Triumph 12
T TR6 Continuous Starting and Ignition Issues Triumph 6
M TR6 Just starting out… Triumph 16
RichB4493 TR2/3/3A TR3 not starting - Slow/Weak Starter Triumph 33
M TR2/3/3A 1958 TR 3 , crankshaft nut for hand starting Triumph 7
P Wedge Starting problems TR8 Triumph 3
K TR6 tr6 not starting Triumph 11
Jim_Stevens TR2/3/3A Intermittent starting Triumph 14
R TR2/3/3A Starting car for 1st time after rebuild. Triumph 13
F TR2/3/3A starting scuttle repair Triumph 27
jdubois GT6 After over two years stalled at the body shop, my GT6 is starting come back to life! Triumph 5
R TR2/3/3A Starting TR-2 for first time after restoration Triumph 58
D Wanted TR3A starting handle Triumph Classifieds 0
D Starting After Carbs Rebuilt Austin Healey 30
Got_All_4 TR6 Starting my frame restoration Triumph 32
sundown TR6 Starting Triumph 43
F TR2/3/3A I'm stuck... alternator/wiring/starting/? Triumph 2
F TR2/3/3A 1960 TR3A starting chassis work Triumph 81
J TR2/3/3A Starting my TR3 A restoration Triumph 8
F TR2/3/3A Starting Triumph 4
N Hesitant starting Austin Healey 16
Got_All_4 TR6 Starting The Tear Down Of MY 1969 TR6 Triumph 6
G TR4/4A Starting without Transmission attached Triumph 9
P BN4 Hesitates on Starting Austin Healey 12
D Hard Starting Austin Healey 14
mgedit TR2/3/3A 56 TR3 Starting Issue Triumph 9
M Starting from cold Austin Healey 2
R Very Difficult cold weather starting problems! Austin Healey 21
R TR4/4A Starting TR4A after 30 years Triumph 12
R winter hard starting BJ7 Austin Healey 16
P Jump starting a positive ground BJ8 Austin Healey 4
W starting motor Jaguar 0
D TR2/3/3A Starting my Bodywork journey. Triumph 166
P TR6 Quick starting Triumph 2
Joe Reed General Tech Starting a screw in a tight location... MG 9
P TR6 TR6 hard starting Triumph 24
Q Just Starting Restoration Of 1967 E Type Jaguar OTS Jaguar 13
stretchit2 Starting Issue Austin Healey 6
M TR6 Intermittant starting problems Triumph 4
Willie_P TR4/4A Starting long dormant TR engine..start up procedures? Triumph 10
S Hard starting on Webers from cold Austin Healey 12
