TR2/3/3A Starter failure
TR3MT
Member
Bronze
My M. M. starter, PN 541-530, failed because the drive retaining nut (PN 149-900) became detached from the drive shaft. I suppose this happened because the cotter pin was not put in place and I missed it when I installed the new starter. When the failure occurred a 2" hole was blasted through the cast iron clutch housing and I found the nut on my garage floor under the car. The main spring (PN149-900) is now jammed between the flywheel and the clutch housing and the engine is jammed. Looks like I may have to tear things apart to get to that spring. I am planning to either braze or epoxy a metal patch over the hole in the casting. Does that sound like a good idea? The spring is barely visible with a mirror and I don't see how it can be removed in place. The starter is under warranty but the rest will be on me.
TR3driver
Great Pumpkin - R.I.P
I had somewhat the same thing happen years ago, except the spring went out the hole too. A crack started from that hole, which eventually ran all the way around the bell-housing flange, ruining the (overdrive) gearbox.
Based on that, I would suggest having a piece of similar material cut to fit (aluminum alloy, not cast iron, assuming this is an original TR3A transmission) and welded into place. The original part doesn't seem to have been overly strong (they beefed the design up several times behind the 2.5L six), and I think you want a repair that is as strong as possible.
Or just go ahead and replace the housing now. TR3 housings aren't that hard to come by; I saw one on eBay a couple of days ago. Starting bid $100 and no bids (at that time). Seems those early crash boxes aren't very popular.
TR3MT
TR3MT
Member
Bronze
Thanks for the advise and moral support. It helps to share my pain for such an avoidable failure.
Jerry
The spring should be steel, I removed the starter and fished in the hole with a magnet. Got all the loose parts and put it back together. But I was lucky, no damage to the case.
Trevor Jessie Common Starter failure? Spridgets 11
King_of_England aftermarket gear reduction starter failure Triumph 10
CJ Burton MGB-GT Bolts for INERTIA STARTER on 1966 MGB GT MG 8
R TR6 Starter Solenoid Conection Triumph 11
R TR6 Lucas Starter 2M100 - Extra Part? Triumph 2
G TR2/3/3A TS37903F Is my engine a TR3A engine because my starter says no. Triumph 3
Frameman 1949 Engine Misfiring & Starter Cranks Slowly When Hot Austin Healey 8
N TR5/TR250 Starter Box Assembly Leak Triumph 14
P TR2/3/3A British High Torque starter Triumph 6
W General Tech 2500S starter motor and fuse box questions Triumph 3
EWD For Sale ā€˜74 TR6 original starter Triumph Classifieds 0
M High-Torque Starter Austin Healey 10
W Generator and Starter Long Bolts Spridgets 0
H Lucas Starter Model for 3000 Mark II, BT7 Austin Healey 3
R Bugeye Starter Switch Spridgets 7
B General MG Remote Starter Switch MG 6
S MGB MGB Starter Woes MG 13
M TR6 Starter Relay on a 73 TR6?? Triumph 22
edkap2002 TR6 starter motor advice Triumph 12
algot1901 1950 Prefect starter Other British Cars 1
Martinld123 High-Torque Starter Austin Healey 4
R TR6 Starter wiring question Triumph 6
S TR2/3/3A Rebuilding the early tr3 starter Triumph 5
RichB4493 TR2/3/3A TR3 not starting - Slow/Weak Starter Triumph 33
B TR4/4A High Torque Starter Wiring Triumph 9
algot1901 1950 Prefect Starter Other British Cars 10
S Starter Solenoid Nut Size for BJ8 Austin Healey 1
B High-Torque Starter Rattling Noise Austin Healey 3
EWD TR6 ā€˜74 TR6 Starter & Trans Cover Triumph 13
Jim_Stevens TR2/3/3A Starter/ring gear engagement Triumph 11
J TR6 72 TR6 starter problem Triumph 10
A TR2/3/3A Early TR3 starter (bomb style) bushings sizes Triumph 7
C MGA Change a pull starter to a push button system MG 6
Michael Oritt Starter Button Austin Healey 19
D WOSP Starter Austin Healey 9
DrEntropy MGB Replacement starter MG 7
steveg TR6 '74 - Where is the Starter Relay located? Triumph 1
AUSMHLY Crankshaft Starter Nut Austin Healey 10
K For Sale Triumph TR3 Bullnose Starter Triumph Classifieds 0
B TR4/4A Starter dog bolt Triumph 15
D Starter Austin Healey 26
red57 What starter is this? Austin Healey 6
S TR2/3/3A Correct Starter Triumph 4
Jim_Stevens TR2/3/3A No Ignition light and no starter Triumph 11
R TR6 Is this a starter issue? Triumph 6
Got_All_4 TR2/3/3A Gear reduction starter problems Triumph 5
John_Mc TR6 Starter not engaging consistently Triumph 9
R TR2/3/3A Starter rear plate 54 TR-2 Triumph 12
M TR6 Starter lagging issue Triumph 2
