nicko
Hi all !
I have been reading the forum for a while now and have found the advice given really excellent.
This is my first posting , so please be gentle!
I have managed to sort out quite a few small things with the car (I'm not a mechanic but practically minded).
However, after a small hole in the exhaust has got bigger,and is sounding like a tractor , I thought it would be a simple job to replace the two pipes from the manifold to the fist silencer. (the rest of the exhaust is fine).
Getting the exhaust off was the easy bit but found that the studs into the manifold were rusty and needed replacing.
This is where the problem lies ! How do you get them out?
Is there some special tool to remove them or is it as I think,
that I need to remove the carburettors ?
If so, is it a case of struggling and patience to get the bolts out, or does somebody know better ?
Advice gratefully received,
Yours frustatingly,
Nicko.
Yours frustatingly,
Nicko.
