Rear Axle Shock Link Help
John_W
Hello Team,
I am in the middle of a BN1 restoration project (correction: beginning of a BN1 restoration project). I have stripped apart most of the rear axle casing and have new shock links ready to go. The issue I have is this: on one side the shock link fits nice and snug just like it's supposed to. On the other side the old shock link must have corroded a bit and wobbled around creating a slightly oversize and irregular shaped hole. Thus, the new shock link seems to wobble around a little because the mounting whole is not perfectly round and a little too large now. I could just torque the nut extra good but I'm not sure that's a good idea. I have two thoughts on this:
1) Fill the hole with a little weld and then try my best to drill a new new hole to the correct diameter;
2) Over drill the hole and insert a bushing of the correct size.
In both cases getting a drill aligned squarely with the hole will be nearly impossible. I can get it close but it will not be square.
I'm looking for some pearly words of wisdon here.
Thank you.
John
GregW
Hi John,
Welcome aboard. Are you referring to the hole in the axle mount, or the hole in the shock arm?
Genos2
I've used this method- Right/angle drill,variable bit or slightly smaller than bushing, for press fit & steel bushing. If its elongated, no amount of tightening, will keep it from moving,by rebushing & using loctite, rechecking after a good run, you should be okay. cheers Genos2
J
John_W
Howdy,
It's the hole in the axle mount.
Thanks.
JW
Keoke
:agree This is the way to do it!
J
John_W
Excellent. Thanks for the input on this and I'm sure I'll be back for more advice on something else!
John
vette
John, A few years back, I snapped the shock link mounting off the axle during some rather questionable and agressive driving. My best memory of this is that at the time my wife mentioned that we were sliding and I responded to her rather casual comment with a more pointed " I KNOW !". While pulling it down into second gear and accelerating out of the turn. ( I was chasing a Mini up an old hill climb road ). Anyway, it did turn out to be a difficult fix with everything in place ( just wanted to keep it on the road for the summer). So I just fabricated another half to the bracket and gobbed it up with alot of weld as I could reach it to hold it there. It lasted many years. I have finally gotten into the full restoration part of this ownership. Since it is a full restoration, I have pulled the axle housing completely from the car. Doesn't take that much more time and you may have metal work to do back there anyway. Take copious pictures to help with reinstallation. With the axle housing out you can fab up a good mounting braket.
BN6_2197 Removing connecting link between shock absorber and rear axle Austin Healey 4
5 Wanted Wanted 1966 mgb banjo type axle rear hub MG Classifieds 0
KVH General Tech Rear Brakes and Solid Axle Triumph 2
R BJ7 Rear Axle Maintenance Austin Healey 5
A Rear Axle Oil Seal Austin Healey 4
W Rear Axle Hub Seal Austin Healey 8
R For Sale TR6 REAR AXLE HUBS Triumph Classifieds 0
drooartz Rebuilding rear axle Spridgets 19
M TR2/3/3A Speedy Sleeve Repair Sleeves for Rear Axle Pinion and Half Shafts Triumph 1
M TR2/3/3A Re-Assembling Rear Axle Outer Bearing and Hub Triumph 1
M TR2/3/3A Rear Axle Bearing Grease Triumph 5
J TR6 Differential / Rear Axle Triumph 1
Tr3aguy TR2/3/3A Rear Axle Rebuild Triumph 3
M TR2/3/3A Identifying Rear Axle Leak Source Triumph 12
BN6_2197 Rear Axle rearing up Austin Healey 12
K Rear Axle Breathers Austin Healey 17
John Turney BN4 to Early BJ8 Rear Axle Austin Healey 12
P TR2/3/3A Rear axle hub dis-assembly Triumph 1
S Rear axle - small leak .....? Austin Healey 7
T TR2/3/3A Will cable ties hold rear axle rubber buffer securely? Triumph 7
P MGB Noisy Rear Axle / Differential MG 1
R Rear Axle Restoration Austin Healey 6
Lin Rear Axle Hub Nuts Austin Healey 3
E For Sale Tr3 rear axle, rear end Triumph Classifieds 6
jfarris TR2/3/3A Changing rear wheel studs in a later Girling axle Triumph 3
K TR2/3/3A The rear axle "tube" seal replacement. Triumph 6
warwick-steve Oil for rear axle? Austin Healey 3
J Wanted Need tr3 rear axle housing Triumph Classifieds 0
T TR4/4A Replacing in situ oils sealing gearbox and rear axle Triumph 18
B How often should you change the rear rear axle oil Austin Healey 9
regularman Gear leaking from axle housing into rear brake drum Spridgets 3
Jim_Gruber Source for 3" cotter pins for bump rubber on BE Rear axle Spridgets 5
T TR2/3/3A Rear Axle Vent Triumph 12
Jim_Gruber Removing the Rear Axle Seal Spridgets 4
B TR2/3/3A Checking oil in rear axle Triumph 2
D TR4/4A Seals on TR4 Solid Rear Axle Triumph 5
F Leaking rear axle hub [BT7] following instalation of new seal! Austin Healey 9
KVH TR4/4A Removing Rear Differential Seal--Solid Axle Triumph 1
K TR2/3/3A Odd question re: rear axle hitting fuel line? Triumph 4
K TR2/3/3A Rear axle hub removal? Triumph 8
catfood BN1 Rear Axle drain plug. Austin Healey 7
KVH TR4/4A Here'a Another Rear Axle Hub Question/Problem Triumph 7
Don_R TR2/3/3A Rear Axle bearings Triumph 3
Popeye TR4/4A TR4A solid axle rear leaf spring question Triumph 14
bugedd Rear axle bump stop Spridgets 7
AUSMHLY BJ8 rear axle oil seal Austin Healey 6
AngliaGT Easiest Way to Remove/Replace Rear Axle Seals/Etc.? Spridgets 9
A TR2/3/3A Possible problems replacing a Lockheed rear axle with a girling unit Triumph 6
GTP1960 TR2/3/3A replacing rear axle buffer? Triumph 6
