Post the crazy previous repairs you have found
mightymidget
This is what I found he other night as I moved forward on my rust repairs. What you are looking at is the passengerside foot well. A piece of metal was cut and shaped to fit floor boards and folded up to include upright. Where this gets crazy is they took a rubber floor mat and placed on the exposed orignal floor board then place the shaped metal on top so rubber is sandwiched between orignal floor and new floor. Then it was attached self tapping screws through the floorboards.
lesingepsycho
If you can't weld, laminate! :devilgrin:
:nonod::nonono::rolleyes::crazyeyes::nonod::nonono::rolleyes::crazyeyes::nonod::nonono::crazyeyes::rolleyes::crazyeyes::nonod:
M
mightymidget
This is my other bugeye. When I got it inside the shop I got the trash out of it and was wondering why al the plywood in small pieces.............well it seems someone thought a plywood floor screwed to top of floor struts whould make a good platform to attach seats
M
mightymidget
Got all of the rotted plywood and then look what I found. Carpet pad. and carpet pad is made from a product sililiar to a SPONGE
livinginthepast
Wow, I don't have anything that compares to the previous stories, however, the PO of my BE decided that he would hold the carpet down using tacks. Consequently, there are lots of little tiny holes in the floor pans.
The other thing is, at some point, the steel oil line that runs between the filter housing and the block was damaged and the PO used some vacuum hose to fix - which was bulging and ready to burst when I got the car...
Oh, and I cannot forget that the wrong front bearings were installed and the PO used a grinder to try to make them fit.
So, even with all the carb related issues that I'm having, my car is in a lot better shape than when I bought it...
dklawson
Don't be too hard on the DPO for the carpet pad. A number of the old cars I've worked on had their original material under the carpet... jute mats. Jute holds as much (if not more) water than that carpet pad.
bugimike
I had/have similar issues withe the floorboards (sans the rubber floor-mat though!)in my BE. I suppose the way to "fix" rusted-through floors is just to lay something in on top so ones feet don't fall through!
JPSmit
and let's not forget that for years these were just cheap used cars - though I have to say, they're still a pretty impressive bodge!
Jim_Gruber
Om my '68 Sprite Bugsy when I bought from DPO car would run if you sprayed starter fluid into the 1098 engine that had been transplanted in there but could not get the fuel pump to run. Engine would turn over like mad but no noises from the rear and as soon as starter fluid ran out engine would die. DPO had been beating his head against the wall for months trying to solve the engine not running issue so I got Bugsy for a good price. After a week or to of cogitating it occurred to me the battery was installed wrong. Sure enough battery was connected as positive ground in a negative ground car. A quick disconnect and turn around of the battery, turned the key and I heard tic-tic-tic coming from the right rear of the car, another further turn and Vroom, vroom. Only change that needed to be made with the originally positive ground 1098 was to repolarize the generator, a 2 minute fix.
Jim_Gruber
And we don't want to discuss hoe DPO attempted to start engine without oil pressure gauge line installed. The port is directly opposite the clutch slave adjustment cover which of course was not installed and the engine pumped a whole lot of 20W50 sideways and into the passenger compartment. And he never bothered to clean up.
M
mightymidget
Uploaded with ImageShack.us
This is a rubber gas line,
it is one piece from the fuel pump to the fuel filter at carburator.
It was attached at fuel pump and by "one" clamp.
The fuel line was sagging/hanging from the bottom of car 4-6" in places.
Just waiting to be caught on a stick or something.
PAUL161
jehuie Where to post for parts that fit many cars? FORUM Navigation Questions 1
Pythias Where to post FOR SALE Spridgets 1
PatPink TR6 Hello, I am new to the site and want to post some photos of my 1973 TR 6. I have done all mods to this car except body and paint. Triumph 10
P TR2/3/3A Block treatment post cleaning Triumph 17
jlaird MGB Don't post like I did 10 years ago. MG 7
EWD TR6 74 TR6 - “ A Post Seal” Triumph 0
jlaird MGB Follow up to my bad post on prewar MGs MG 4
Gliderman8 Editing a post FORUM Navigation Questions 6
F General Tech trouble with editing post Triumph 2
Michael Oritt Post- Open Roads 2002: Tahoe to MD the long way Austin Healey 19
S TR2/3/3A Stubborn door hinge screws in “A” Post Triumph 6
B TR6 New Member, first post Triumph 1
S TR4/4A B post to sill Triumph 5
Jim_Gruber Help and Advice needed for post pressure washing debacle Spridgets 10
Jim_Stevens For Sale Post-60K LH door Triumph Classifieds 2
R General Tech How to attach pic's to a post? Triumph 1
R Adding attachments to your Post FORUM Navigation Questions 1
tahoe healey past post about sholder belt foam Austin Healey 2
TomMull Elan Plus 2 post 1968 numbers don't quite match Lotus 0
H Windshield Post to Body - Captive nut needs to be replaced - Pillar to Body Spridgets 2
D Test image post FORUM Navigation Questions 1
ckeithjordan TR2/3/3A Apple Hydraulics vs White Post Restoration Triumph 13
M battery helmet stuck on post help Austin Healey 8
T Trouble inserting pictures to post FORUM Navigation Questions 2
M Wanted I tried to post this earlier and it didn't seem to work so this might soon appear as Austin Healey Classifieds 6
PeterK TR4/4A From a VTR post on Facebook. Herman has passed. Triumph 16
Lin Post in float bowl came loose Austin Healey 6
NutmegCT battery post connectors Restoration & Tools 6
S TR2/3/3A The door and B post hardware Triumph 3
R TR2/3/3A "B" post Triumph 7
Tinkerman TR2/3/3A 1960 3A post 60,000 top installation Triumph 6
Rut 2 post lifts Spridgets 18
Randy Forbes HMN Blog post about AHS 3610.... Austin Healey 6
Tinkerman TR2/3/3A 1960 TR3A post 60000. WON"T START ???????????????? Triumph 8
Got_All_4 TR2/3/3A Need Pic of a Post TS60000 Occasional seat Please Triumph 5
T How to post photos? Spridgets 6
J TR4/4A Answer to my post "help with tr4 transmission disassembly". Triumph 9
Jim_Gruber NOS 10 Post BE Windscreen on E-Bay right now - NFI Spridgets 3
CJD TR2/3/3A Screw Post Coils Triumph 6
S This internet article/post made me laugh... Austin Healey 5
AUSMHLY Can't post photos, why? Austin Healey 0
Basil At an Indian Trading Post Spotted 1
J TR2/3/3A Wood strip in B post. Triumph 3
M TR2/3/3A Body Measurement differences between pre & post 60,000 TR3s Triumph 4
C TR4/4A Top attachment to A-post Triumph 3
M_Pied_Lourd TR2/3/3A TR3A A post seal Triumph 1
rick_ingram General MG Post-Abingdon MGs MG 6
Tinkerman TR2/3/3A Front turn signal wiring question on my post 60000 TR3A Triumph 8
judow Can't post except in quick reply and other issues FORUM Navigation Questions 0
C TR2/3/3A Rear brake shoe steady post Triumph 2
