TR2/3/3A The door and B post hardware
sp53
The door and B post hardware are still very tight on my car. I am wondering how the new hardware is for that application. I have plenty of original stuff that has wear and I am always worried about buying new, so what others have experienced would be much appreciated.
steve
S
sp53
The part that grabs me the most is where the wood in the door frame meets the B post on pre 60K car because there is just a little bump on the door frame pushed out by the angle of the wood in frame. It looks like I could just tap the B post on the tub and that would solve the problem.
CJD
Tap? When it comes to aligning the doors, I have a large rubber flooring hammer that I'm not afraid to let loose with. The door can even be twisted by grabbing the open and and twisting against the hinges. Several times I've had the door fit perfect, only to remove them and resintall and they're out of alignment for no reason!?!
I have also hammered the A post hinge locations and/or bent the brass hinges to get everything into alignment. It amounts to whatever it takes to make it all fit...preferably before the paint goes on. You get more limited after painting.
S TR2/3/3A Stubborn door hinge screws in “A” Post Triumph 6
Jim_Stevens For Sale Post-60K LH door Triumph Classifieds 2
Tinkerman TR2/3/3A DOOR PANEL HELP NEEDED 1960 TR3 A post 60000 car Triumph 5
K TR4/4A The Gap between the Door and the B Post on the 4A? Triumph 2
T TR2/3/3A TR3A door post packing Triumph 9
Jim_Gruber Inital Door Fit and A-Post Spridgets 3
DanNagy Wedge TR7 - Lower Door Post Trim Triumph 5
pan Door Shut Face Panels Austin Healey 0
D Door Lock Tumbler Austin Healey 4
drooartz Spring service of the 4-door Sprite (Morris Minor) Spridgets 8
A 100/6 BN4 Door Lock Austin Healey 15
SpeedyG TR4/4A Door window regulator spring Triumph 5
SpeedyG TR4/4A Interior door handles and escutcheons Triumph 9
AngliaGT Wanted Two inside window handles & Regulator for Driver's Door - '67 GT MG Classifieds 6
AngliaGT MGB-GT WANTED: Driver's Door Regulator + Two (2) interior handles. MG 1
D Older door panel clips Restoration & Tools 4
BoyRacer Door Skin Removal Austin Healey 6
Southwarks TR2/3/3A TR2 door help! Triumph 2
M For Sale 2017 Jaguar F-TYPE Premium 2-Door Convertible for Sale mlbirk@aol.com Jaguar Classifieds 0
R MGB MGB Roadster Door Panel Speakers MG 9
D Top Door rubber and fuzzy seal Spridgets 5
J For Sale Triumph TR3 door, left, for sale Triumph Classifieds 0
Popeye TR4/4A Door seal channel near top of windscreen Triumph 6
fordmstr 73 Midget rocker panel end caps and door handle gaskets advise Spridgets 3
D MGB Older style door pulls MG 0
V Door Seals Austin Healey 8
Bayless Door seal question Spridgets 3
Donald1107 TR2/3/3A Door hinges Triumph 14
algot1901 1950 Prefect E93A-946480 - door bottom rubber Other British Cars 14
D Door Seal Fit Austin Healey 18
D For Sale BT7 interior door cards - new ! Austin Healey Classifieds 0
E 3000 Healey Door Checks Austin Healey 1
A MGB MGB a glove box door MG 10
chicken BJ7 Door Fit Austin Healey 27
Patrick67BJ8 Glazing Door Window Glass in BJ8 Austin Healey 15
F Door Panel Hardware Austin Healey 3
LAW75 Door Latch Adjustment Austin Healey 22
BoyRacer Door Panel Measurements Austin Healey 3
LAW75 BJ8 Door Locks Austin Healey 2
Cappy Occasional Door Malfunction Austin Healey 1
nichola TR6 Door handle and window crank installation Triumph 0
J Door Draught Metal Clips Austin Healey 4
F Interior Door Handle Removal Austin Healey 2
F Wanted wanted new old stock driver side door latch Triumph Classifieds 2
M Spitfire 1500 LH Door Triumph Classifieds 0
chicken Healey BJ7 door (i think) Austin Healey Classifieds 0
