Door Seals
Veneerme
I need to replace the door seal weatherstripping (again) on my 1958 Austin Healey 100–6. The material I purchased from Moss seems to have an aluminum internal clamp that doesn't grip very well. A friend told me to give the TR six version a try. I purchased this material. However, it does not seem to be any better. I would rather not glue this material in place. Is there another material that has a stronger grip? Or, is there a clamping tool that would help it stay put?
Healey Nut
Ditto. Bristleflex is the stuff to use.
You can also get it through Autofarm in Ontario Canada.
Editor_Reid
Platinum
Take a close look at it to ensure its appearance meets your desires. I have always found Bristleflex to be unfortunately very different in appearance from the original stuff. It's nice weatherstripping, but it doesn't look like the original.
Healey Nut
But it stays in place once it’s on and it seals better that the stuff from the other suppliers .
Healey Nut
Thank you to everybody with your advice. I have contacted McGregor.
Martin McGregor can be a hard guy to pin down . If he doesn’t answer within a few days I would suggest going via Autofarm in Canada .
Patrick67BJ8
I had a hard time getting my seals to stay in place and I used a Gel Superglue. I would dab a spot about every 3 or 4 inches and it worked. When I had to remove a area it was easy to do with a putty knife.
volunteer Wanted Need Door Seals, Vent Window Seals and Trunk Seal for Daimler ds420 Limo Jaguar Classifieds 23
Jim_Stevens TR2/3/3A Rear door seals on a 3A? Triumph 12
M 3000 BJ8 Door Seals Austin Healey 9
KVH TR4/4A Door Seals: Moss Part 249-607 Triumph 0
Lin BT7 furflex/rubber door seals Austin Healey 17
HealeyRick BJ7/8 Door Seals Austin Healey 7
KVH TR4/4A Door Seals and Top Padded "Rail" Triumph 5
H General Tech Door Glass outer seals installation Triumph 6
D Door seals bt7 Austin Healey 4
H Door seals BJ8 Austin Healey 15
Sarastro TR4/4A Puzzled about TR6 door seals on a TR4A Triumph 7
B TR4/4A Door seals Triumph 2
B Front Seat Bases and Door Seals -- BJ7 -- Advice Austin Healey 6
S TR4/4A door and trunk seals Triumph 3
Gerald_Gordon TR4/4A Hard door closing after replacing rubber seals Triumph 8
Scotsman TR2/3/3A TR3 door weather seals Triumph 22
R TR4/4A Door Seals Triumph 4
J Door/scuttle rubber seals Austin Healey 2
M Door Seals: Best Quality and look Spridgets 4
B TR2/3/3A Question about rubber door seals Triumph 0
CanberraBJ8 door trim/seals info Austin Healey 6
V 100-6 BN4 door seals Austin Healey 8
6 Door Window Seals Spridgets 6
P Anyone have pics of door seals / furflex on a BJ7 Austin Healey 0
T TR2/3/3A TR3 Door seals Triumph 6
1 Door Glass Seals Spridgets 6
T TR5/TR250 TR250 Fuzzy Door & Window to Windscreen Seals Triumph 3
I TR6 Help installing TR6 door pulls and fuzzy seals Triumph 14
CJD TR2/3/3A TR3A Door Seals Triumph 12
M Door window drip seals Spridgets 2
I Help with Bugeye door seals Spridgets 7
M MacGregor Door Seals Spridgets 5
I Help with door seals please Spridgets 17
mountainman TR2/3/3A TR3 Door Seals Triumph 8
M Bug Eye Door Seals Spridgets 8
M New Door Window Seals Question MG 1
pjsmetana Furflex Door Seals. Alternatives? Triumph 0
Lynn Kirkpatrick MGB-GT MBG GT door seals MG 17
Bone Door seals? Spridgets 7
M Moss Rubbe/Vinyl Door Seals Spridgets 4
newmexTR3 TR2/3/3A TR3 Aftermarket Door Seals that work? Triumph 11
J Looking for dark blue door seals. Austin Healey 4
M Bristleflex Door Seals for 58 Sprite Spridgets 3
martx-5 TR2/3/3A TR3 Furflex - Fuzzy Door Seals Triumph 4
N Door Seals To Bristleflex or not to Bristleflex Triumph 11
T Wedge TR8 door seals Triumph 4
regularman Door window seals Spridgets 1
TR6oldtimer Fuzzy door seals to cut or not, buy new or keep Triumph 12
rulle7 Door seals ... Spridgets 2
jlaird Question-door seals Spridgets 9
