TR2/3/3A Stubborn door hinge screws in “A” Post
Skellyt
Good morning. I’ve been a member of the forum since 2007, but this is the first time I’m posting a query. I’m in the process of repainting my TR3B and have removed the front doors and fenders in order to paint the inner fenders and A posts. Some of the door hinge screws on the A post will not budge even though I’ve been spraying them daily with Liquid Wrench, WD-40 and PB Blaster. I’ve tried regular flat head screwdrivers, hand impact driver with a heavy 10 lb hammer and have even tried using an impact bit attached to a ratchet and breaker bar to no avail. I don’t want to use any heat, to avoid having to remove the carpeted interior side panel.
My next step was going to be the use of an air impact hammer, but a friend said that this might damage the A post. He advised me to drill them out, which I previously thought be be a last resort for fear of damaging the captured nuts.
Does anyone have any suggestions, recommendations, etc.
Thanks, and stay safe.
DavidApp
Drilling it out and re tapping the captive nut may be your only option. You run the risk of spinning the captive nut in the cage if they are frozen that badly.
You must have taken the doors off the hinges to get the wings off. Could you leave the hinges in place when you paint the inner wings?
David
sp53
Here is thought I had. I would use a left hand drill bit and then maybe when enough meat is taken away the screw might spin out. Another thought would be to put an old say 8 inch drill bit in the hole you drill and heat the bit from a distance. I heated a drill bit the other day to burn some rubber out of the capping and bit got red hot fast. When drilling something like that get the center punch hole dead center and remove enough material. I have used like 1/8 for a pilot hole, but the hole needs to be bigger. If you cut the gage nut some you can still retap.
S
Skellyt
Thanks to all for the quick response. They are both good ideas. Based on an earlier
phone conversation with another TR3 friend, I might just give up and leave them attached. Since the screws are not in bad shape and are still tight on the A post, I should probably leave well enough alone and just paint over them. No doubt, they’ll outlast me.
Thanks again for the help.
CJD
It sounds like you have been through the standard order of escalation. Normally, if I've used the impact driver there is nothing left of the head...so it is obvious to drill following that. If your head is still intact...you could take out a lot more frustration before giving up!
sp53
Not sure if this is applicable and I am not trying to be funny, but some of those early impact hammer deals had to be cocked so the cam would spin with impact and some had a tightening setting also. It usually says on the handle. It should have spun at least a couple free.
Graham H
If you are not taking the fenders off so you can get to the captive nuts I would leave them as they are.
Graham
R6MGS stubborn door locks MG 5
J General MG Stubborn spinner MG 1
J General MG Thoughts on removing a stubborn 2-ear spinner MG 5
D TR4/4A stubborn lever shock link Triumph 2
Jim_Gruber Steering Rack Question / Removing a stubborn Front Shock Bolt - Progress on Bugsy II Spridgets 11
Gliderman8 Removing stubborn screw Restoration & Tools 22
Banjo TR6 springtime and stubborn TR6s Triumph 6
E TR2/3/3A stubborn TR3 turn signal wires Triumph 7
vping T-Series Stubborn Clutch hard line MG 2
2wrench Stubborn key in the crank Triumph 14
2wrench TR6 '74 TR6 Stubborn cam shaft Triumph 8
6 Stubborn rusted screws/bolts Austin Healey 4
RickB Need Tip to remove stubborn headlight trim rings MG 3
V Stubborn Bolts Restoration & Tools 14
Mark_Gibson Stubborn Screws on My TR-2 Windscreen Frame Triumph 3
TNMGB Stubborn inline fuseholder... MG 6
CharlieCarpenter Stubborn Water Pump Austin Healey 2
pan Door Shut Face Panels Austin Healey 0
D Door Lock Tumbler Austin Healey 4
drooartz Spring service of the 4-door Sprite (Morris Minor) Spridgets 8
A 100/6 BN4 Door Lock Austin Healey 15
SpeedyG TR4/4A Door window regulator spring Triumph 5
SpeedyG TR4/4A Interior door handles and escutcheons Triumph 9
AngliaGT Wanted Two inside window handles & Regulator for Driver's Door - '67 GT MG Classifieds 6
AngliaGT MGB-GT WANTED: Driver's Door Regulator + Two (2) interior handles. MG 1
D Older door panel clips Restoration & Tools 4
BoyRacer Door Skin Removal Austin Healey 6
Southwarks TR2/3/3A TR2 door help! Triumph 2
M For Sale 2017 Jaguar F-TYPE Premium 2-Door Convertible for Sale mlbirk@aol.com Jaguar Classifieds 0
R MGB MGB Roadster Door Panel Speakers MG 9
D Top Door rubber and fuzzy seal Spridgets 5
J For Sale Triumph TR3 door, left, for sale Triumph Classifieds 0
Popeye TR4/4A Door seal channel near top of windscreen Triumph 6
fordmstr 73 Midget rocker panel end caps and door handle gaskets advise Spridgets 3
D MGB Older style door pulls MG 0
V Door Seals Austin Healey 8
Bayless Door seal question Spridgets 3
Donald1107 TR2/3/3A Door hinges Triumph 14
algot1901 1950 Prefect E93A-946480 - door bottom rubber Other British Cars 14
D Door Seal Fit Austin Healey 18
D For Sale BT7 interior door cards - new ! Austin Healey Classifieds 0
E 3000 Healey Door Checks Austin Healey 1
A MGB MGB a glove box door MG 10
chicken BJ7 Door Fit Austin Healey 27
Patrick67BJ8 Glazing Door Window Glass in BJ8 Austin Healey 15
F Door Panel Hardware Austin Healey 3
LAW75 Door Latch Adjustment Austin Healey 22
BoyRacer Door Panel Measurements Austin Healey 3
