TR2/3/3A 1960 3A post 60,000 top installation
Tinkerman
I see that I am going to need a lift the dot punch and a Tenax wrench. I think I have the wrench but not the punch. Does any one have a punch they are through with, that I might be able to buy or borrow?
All offers greatly appreciated!
Also any tips from the more experienced would be greatly appreciated. I figure I have only one shot at getting this right so all help
would be openly accepted....................
Cheers, Dick
carpecursusII
Do this in the spring or summer when it's hot out. Work from the center out. If possible, use binder clips to initially hold the webbing to the frame, you will need to set up the correct spacing between the braces to align with your specific top. The outer most snap on each side of the windshield will have the most effect on wrinkling.
TR3driver
Great Pumpkin - R.I.P
Instead of the punch, I use the backing plate as a guide and make slits for the prongs with an X-acto knife. Definitely a "shade tree" method, but it works. A piece of cardboard helps, but still keep your fingers out of the way. Once the fastener is in place, I use the knife to cut around the hole.
TuffTR250
I recommend installing the Lift-the-Dot connectors so the dot is off to the side, not straight down. It makes it a lot easier to release them when removing the top.
Regards, Bob
2liter4cyl
Bronze
I have the $75 punch I bought on e-bay for $12 + shipping. I also made the tenax punch from a brass fitting I sharpened . I'm done now, and would be willing to send both to you, hoping that when you are done, you might forward all to the next TR owner so asking. Instead of a tenax wrench, I used a small needle nose plyers. A snap ring plyers may also work. Le T.
vickxxx
I used the punch from a grommet kit for tarps that I had picked up at the hardware store for 12 bucks. It gave clean cuts and worked through the whole project easily.
parkerg1
Member
When I did the tonneau cover on mine, I went to an old upholstery shop, and he had 2 or 3 punches still laying around. He also gave me a old tuna can filled with melted lead to use as a back stop, instead of wood like most people use. I borrowed both from him, and gave him $10 for rent when I brought them back. He was happy, and I saved having to buy one. I have also read many negative posts on the new after market punches. By the way, the lead worked great, I tried the wood and the lead worked much better. When it starts to get too many punch marks, just use a propane torch to re melt it.
Gary
Tinkerman TR2/3/3A 1960 TR 3 A post 60,000 part needed. Triumph 7
Tinkerman TR2/3/3A 1960 TR3A post 60,000 series seat pan covering Triumph 3
Tinkerman TR2/3/3A 1960 TR3A post 60000. WON"T START ???????????????? Triumph 8
Tinkerman TR2/3/3A DOOR PANEL HELP NEEDED 1960 TR3 A post 60000 car Triumph 5
Tinkerman TR2/3/3A Major oil leak from original oil filter system 1960 TR3A post 600000 series Triumph 3
Tinkerman TR2/3/3A 1960 TR3A Instrument Cluster Ground Post Screw Triumph 9
Tinkerman TR2/3/3A 1960 TR3 Post 60000 elec equipment Triumph 12
R For Sale 1960 Healey BN7 Oil Pan For Sale Austin Healey Classifieds 0
W For Sale 1960 TR3A for sale Triumph Classifieds 0
J Wanted Hood (Bonnet) for a 1960 BT7 Austin Healey Classifieds 0
G For Sale 1960 TR3A for sale $11,999 Triumph Classifieds 0
W TR2/3/3A 1960 TR3A Radiator replacement recommendations Triumph 11
dougie 1960 Austin Healey 3000 Works Lightweight vs. 1962 Ferrari GTO Austin Healey 6
G For Sale 1960 BugEye..Very Good..$20,500 Austin Healey Classifieds 0
5 Sold My 1960 Bugeye Spridgets 10
M TR2/3/3A 1960 TR3A--intake manifold-to-SUH6 carbs studs Triumph 3
B Fluctuating Fuel Gauge 1960 Bugeye Spridgets 4
J Wanted 1960 Sprite Bonnet Spridgets Classified 3
KellyRob BMC GEARBOX 1960 British Motor Corp 2
Pool Dad 1960 TR3 engine serial number Triumph 14
Fanch00 My 1960 BT7 History Search Austin Healey 1
poolboy General TR LeMans 1960 Triumph 8
jlaird 1960 AH Sprite Spridgets 96
O For Sale New Member from NJ 1960 TR3 Triumph Classifieds 1
C 1960 BT7 Thoughts Austin Healey 14
L For Sale 1960 Austin Healey steel oem wheels Austin Healey Classifieds 0
F Installing AC in my 1960 Healey Austin Healey 14
G 1960 3000 BN7 Top Help Austin Healey 0
M TR2/3/3A 1960 TR3A turn signal harness Triumph 6
J 1960 Bugeye Paint Codes Austin Healey 1
K MGA 1960 MGA Vin MG 3
F 1960 FriskySport Barn Find Other British Cars 6
5 Proud of my 1960 Bugeye Spridgets 5
F Three worn hubs and wire wheel centers - What to do next? 1960 BT7 Austin Healey 6
R TR3 1960 refurbish Triumph 14
B Wanted Wanted: Trailer hitch for 1960 TR3-A Triumph Classifieds 7
A TR2/3/3A 1960 TR3A front brake dust covers Triumph 5
F TR2/3/3A 1960 TR3A starting chassis work Triumph 81
P 1960 Lancia Appia coupe Other Cars 1
F Wanted 1960 Triumph TR3A fuel tank Triumph Classifieds 5
Nugget 1960 Bugeye "Patents" inherited reconstitution Spridgets 12
6 For Sale 1960 Bugeye Survivor for Sale with Original Rubber Mats Spridgets Classified 0
T Wanted 1960 Jaguar MK2 front door wood trim, both right and left. Jaguar Classifieds 0
D Great Gas Mileage in Southern California [Circa 1960!] Austin Healey 3
M Wanted 1960 Bug eye sprite 1275 ! Austin Healey Classifieds 0
red57 1960 BT7 top mounting brackets Austin Healey 4
T TR2/3/3A Accelerator Say 1960 TR3 Triumph 11
B 1960 TR3 With rust in cylinders Triumph 7
busybrit For Sale 1960 MGA 1500 Restoration Project for sale. MG Classifieds 2
