TR4/4A Oil pressure line from engine....assistance please.
malbaby
I assume the oil pressure pipe was attached to the oil filter housing ex factory....lower front bolt hole?
I cannot find the original bolt that accepts the banjo fitting [ I have the oilpipe/ line with the banjo fitting on the end].......is it a special bolt that allows it to screw into the block as well as accept the banjo fitting of the oil line?...a pic would be helpful.
Also, can the oil pressure pipe with a made up adaptor be fitted to one of the bolts/bolt holes that come out of the oil gallery.
The line with the banjo fitting goes on the stud in the lower front corner. The stud is ordinary, but there are copper washers and a special nut (with a cap on it to hopefully stop leakage through the threads).
Sorry, I thought I had a photo but I can't seem to find it now.
No reason you couldn't make up an adapter to replace one of the plugs. But watch out for straight threads and don't get a cam bearing retainer by mistake.
It would definitely be worth checking with them, though. Many pressure switches use 1/8" NPT, which is also a common thread for attaching a pressure gage.
When I added an OP gauge to the Stag, I just tapped a good spot for 1/8" NPT, and then used a common right angle NPT to compression adapter to link it to the line to the gauge.
https://www.mcmaster.com/?m=true#5220k92/=xmnxoj
(Just an example, should be readily available closer to home for you.)
As others have mentioned, it's a stud with two copper washers (different sizes) and a cap nut.
Which oil gallery bolt is used as a alternative oil pressure pick up point?
Also, I presume that there is an oil pressure feed ["Minks" picture] inside the filter housing to that bolt.
Then engine side copper washer has a larger hole for the oil to "leak" around the stud. The outer copper washer seals the banjo connection.
Can someone please advise... where exactly does the oil [under pressure] enter along the bolt/stud that the oil pressure line banjo attaches to.
This question is post rebuild and assembly of my engine.
Is there a small gallery inside the oil filter housing that runs to that stud?...or is part of the housing attachment gasket cut away to the base of the stud?
On the full flow Purolator heads, there is a groove in the face of the housing that goes against the cylinder block, connecting the adjacent oil cavity to the hole for the stud. No gasket modification is needed.
However, I don't know what the Tecalemit heads have.
D TR2/3/3A oil pressure line venting? Triumph 4
R Bugeye oil pressure line Spridgets 9
M TR2/3/3A Oil Pressure Gauge Line Fitting Triumph 8
K TR4/4A Oil pressure gauge Line? Triumph 5
Gliderman8 TR6 Stainless oil pressure line install HELP! Triumph 8
Scotsman TR4/4A Replacement oil pressure line Triumph 5
fpstude TR2/3/3A Flex Oil Line to Oil Pressure Gage Triumph 5
maxwedge5281 oil pressure gauge line...urgent!!! Austin Healey 10
B Oil Pressure Line Spridgets 5
T Oil Pressure Gauge braided line failure Austin Healey 6
mgbmedic TR2/3/3A oil pressure line routing TR3A Triumph 4
tmc Oil pressure line Triumph 6
tmc oil pressure gauge and line Triumph 5
C Oil pressure line MG 1
M Oil pressure line question ??? Triumph 8
bluemiata90 TR2/3/3A TR3 OIL PRESSURE LINE CONNECTION---HELP Triumph 4
71tr oil pressure sending line Triumph 5
JPSmit #3 Oil pressure line Spridgets 3
hondo402000 TR6 TR6 plastic oil pressure line Triumph 2
A Hot-low oil pressure / Aux. oil line problem fixed Triumph 6
jhorton3 Braided Oil Pressure Line Spridgets 12
Tinkerman TR2/3/3A Oil Pressure Guage Line TR3 Triumph 3
B Banjo Fitting - Oil Pressure Line Triumph 6
R TR6 TR6 Cylinder Head Oil Line effect on oil pressure Triumph 10
G Engine block oil pressure line fitting Spridgets 7
J Oil pressure line connection to oil filter post Triumph 1
tahoe healey oil pressure gauge line. Austin Healey 23
G Where does my oil pressure line connect? Spridgets 4
S Pressure Relief Spring & red line oil Austin Healey 13
B Oil Pressure Line Leak Austin Healey 4
R oil pressure Spridgets 2
RickPA Overdrive Oil Pressure Austin Healey 8
J MGB Oil Pressure Gauge Gives Constant Reading -- Doesn't Seem Right MG 15
G High Oil Pressure Austin Healey 2
RJS General TR Oil Pressure Gauge - Test Triumph 11
RJS TR4/4A R&R Oil Pressure Gauge Triumph 7
A MGB Oil pressure MG 9
K TR2/3/3A Oil pressure readings Triumph 10
J Oil Pressure Relief Valve Austin Healey 3
L Oil Pressure Gauge Austin Healey 5
LAW75 Oil Pressure Austin Healey 4
AUSMHLY BJ8 Overdrive Oil Pressure Austin Healey 14
M 1973 TR6 oil and filter changed - oil shooting out from high pressure valve? Triumph 15
K TR2/3/3A Oil pressure readings Triumph 3
K TR2/3/3A Oil pressure at Hot idle? Triumph 3
S TR6 Oil Pressure Light Triumph 2
Hamish Racing TR2/3/3A Low oil pressure warning Triumph 0
Kurtis No oil pressure Spridgets 5
D TR6 Disconnecting pipe from engine block to oil pressure gauge Triumph 6
