GTP1960
I've been at this heater problem awhile now, and it still will not produce hot air.
what I've done & verified:
replaced the heater valve and stem under the bonnet. (Leaked a little at the base of stem & I wanted to make sure I had flow)
replaced heater hoses under the bonnet( outflow from firewall to engine pipe, felt soft & was crimped a little)
removed and and flushed the core (flushed out with mild solvent, produced an impressive amount of crud until I got continuos clear water)
i am pretty sure water was flowing thru the core as I could hear it sloshing around in there.
pressure test = no leaks.
hooked it back up sitting in a Tupperware on the floorboard.
i could feel the inflow hose get warm & pressurize. But not the outflow.
question: is there an designated inflow & outflow to the heater core? Maybe I have the hoses backwards.(pls see pic)
question: is there a step I need to take on the outflow engine hookup.(left side and below thermostat housing)
I was under the impression it was a simple flow thru system, if the heater valve is open.
any advice appreciated.
THX!
Guy
THX!
Guy
