Ohiobugeye
I'm droping a 1275 engine and ribcase transmission in my Bugeye. Looking at the parts catalogs Moss and Vic. Brit, I have a few questions as to what parts to order. First the muffler, I will be using a late 1275 exhaust pipe....Should I order the 1275 muffler or the 948 regular Bugeye muffler? Second is the Speedometer cable, I have a 4" Black face speedometer from a early midget and I have the rib case transmission. Will the cable for the 948-1098 work with these items or should I go with the 1275 cable? Last is the clutch slave cylinder, again the ribcase transmission and the standard 7/8" bore master cylinder.Should I go with the 7/8" bore for the 948-1098 or the 1" bore for the 1275? Thanks, Don
