LED Lights on Roll Bar for safety-more pics added
Brosky
I got this light from Signal Dynamics in Florida for $24.95 and it works great! It was foggy tonight and I had it out and you can really see this thing with the running lights and especially when you hit the brakes. Simple three wire hook up and no draw to speak of so all lights stay evenly lit.
Installation from rear flat against bar:
From top side view. I'll seal this off nicely with some black vinyl body molding.
With running lights on:
With the brake lights on:
swift6
Re: LED Lights on Roll Bar for safety
How about a photo of how you mounted it? Please /ubbthreads/images/graemlins/grin.gif
PeterK
I like the running lights; mine doesn't have that option. bwahhh
Brosky
Brosky
Daylight mounting picture to follow later today.
jeff3113
bought my LED version off of ebay for about $20. I used black silicone to mount it directly to the metal of the rollbar (underneath the horizontal portion -of course).
Jeff
Brosky
Brosky
Basically my installation was done as follows:
There is a 1/4" recessed hole on each end of the light for mounting. The three (3) wire harness comes out dead center of the light in a sealed circle about 1/2" in diameter. I simply drilled the appropriate holes to match and screwed it to the back of the horizontal bar after running the wires down through and out the side of the bar.
The wiring harness runs back the left side of the car, under the carpeting to the taillamps, which makes it easy to splice and solder in.
Black is ground, red is running (or parking) lamps and green/blue is brake lights.
Brosky
Brosky
Day time pics are up for installation.
J LED lights for PL 700 Restoration & Tools 12
bighealeysource LED Instrument Lights Austin Healey 12
johnrip Wedge TR7 LED Tail lights from Wedge Shop Triumph 1
P LED Brake Lights Austin Healey 2
R TR2/3/3A Positive-ground LED lights Triumph 13
Martinld123 Problem Using LED lights with Existing Brake Lamps Austin Healey 20
D LED shop lights Restoration & Tools 10
Marla TR4/4A Led dash lights Triumph 0
P LED Dash Lights Spridgets 1
gbtr6 TR6 LED Dash Lights Triumph 8
D TR2/3/3A TR3 LED Lights? Triumph 5
B LED bulbs as side lights/stop light/flashers Austin Healey 29
T TR2/3/3A LED tail lights for TR3A and positive vs. negative ground Triumph 11
Johnny Installing LED panel lights, and interior lights on AH BJ7 Austin Healey 6
Johnny Installing LED panel lights, and interior lights on AH BJ7 Austin Healey 0
bighealeysource LED tail lights for Healey's and most Brit cars Austin Healey 7
Lynn Kirkpatrick LED lights? what color? Restoration & Tools 8
G LED lights Triumph 4
hondo402000 LED Dash lights Triumph 15
PAUL161 T-Series MGT 7 inch LED Headlights MG 4
B Positive-Ground LED Light Strip Austin Healey 8
K TR2/3/3A Switching to green LED dash panel bulbs? Triumph 3
Gatheringtree TR2/3/3A LED headlamp and tail light conversion. Triumph 4
RJS General TR Warm White H4 LED Headlight Bulbs Triumph 1
Rob Glasgow LED Dash Light Upgrade Austin Healey 28
Guido36 LED Headlight Upgrade Austin Healey 1
linuxcoupe General MG Lamp to LED Conversion - How many ballasts to use MG 5
BoyRacer LED Turn Signals Austin Healey 5
S TR2/3/3A LED turn signal -- panel flasher not working Triumph 5
EWD TR6 LED instrument conversion / Dimmer. Triumph 25
B TR6 LED Headlights Thouights? Triumph 20
T Decreasing Intensity of LED Lighting Austin Healey 3
V LED light bulbs : One thing leads to another Spridgets 7
V LED light bulbs : One thing leads to another Austin Healey 2
Michael Oritt LED bulb/resistor wiring question Austin Healey 24
johnrip Wedge TR7 led light conversion question Triumph 1
ckeithjordan TR2/3/3A LED Flasher Problem Triumph 13
AUSMHLY E10 Light bulb, 2.2w vs 5w vs warm white LED Austin Healey 4
Lukens TR2/3/3A Led flasher relay? Triumph 3
AUSMHLY Led headlight conversion kit with Lucas headlight bucket Austin Healey 37
Martinld123 Just installed LED headlights in BN2 Austin Healey 15
Bob_Spidell LED Headlamps Austin Healey 14
Gliderman8 TR6 Correct LED flasher relay Triumph 6
N Charging warning light LED conversion Austin Healey 29
S LED or Quartz-Iodine headlights for my '67 AH 3000 Austin Healey 22
J LED Brake / Turn Signal Austin Healey 4
Joe Schlosser LED Turn signals Austin Healey 9
Joe Schlosser LED flashers Spridgets 2
Gliderman8 General TR Let there be [LED] light! Triumph 18
GTP1960 TR2/3/3A LED headlight question Triumph 11
