Laygear End Float BN1-BJ8
AUSMHLY
Do all the Healey models, BN1-BJ8 specify the laygear end float to be 0.012?
The two manuals I have don't reference which models.
The green Austin Healey 100/6 and 3000 workshop manual, General Data page 15 states:
Layshaft bearing, End float .012 in (.30mm.)
The Haynes Austin Healey 100/6 & 3000 manual, page 102, gearbox and Overdrive states:
Layshaft bearing , Endfloat 0.021 in (0.30 mm). I'm assuming 0.021 is a misprint, should be 0.012
How important is the accuracy of end float?
Is + or - a few thousand of 0.012 ok?
How or what does end float affect in the transmission?
I'm waiting for a rebuilt laygear 22B141 to arrive from Healey Surgeons.
Bruce sets the end float at .005
I did mention to Bruce the workshop manuals state .012.
No comment from him on that.
What's the advantage of .005 vs .012
AUSMHLY Remanufactured Laygear with welded 1st gear Austin Healey 20
AUSMHLY BJ8 Laygear Replacement Options Austin Healey 0
AUSMHLY BJ8 Laygear Wear Austin Healey 11
S T-Series laygear MG 13
AHS TR4/4A TR4 Laygear circlip - or lack thereof Triumph 5
Gerard Laygear thrust washer for ribcase gearbox Spridgets 5
S Rounded teeth laygear mesh with chamfered teeth? Austin Healey 1
Johnny BJ8 Laygear and baulk rings Austin Healey 2
M Layshaft End Play Austin Healey 7
scottkilpatrick TR4/4A Send Unit Issues - 62 TR4 Triumph 4
M T-Series MG TD 1st/2nd sliding hub end play MG 1
D ARP big end bolts. Spridgets 7
fordmstr 73 Midget rocker panel end caps and door handle gaskets advise Spridgets 3
G MGB '71 MGB Front End Rebuild MG 2
AUSMHLY Synchromesh Hub End Float Austin Healey 1
X Front End Alignment Austin Healey 14
craigshealey3000 Front End Shake Austin Healey 31
B MGB Mgb crankshaft end play shims MG 2
AUSMHLY Lucas Generator C42 End Caps Austin Healey 3
RJS General TR Winter Blend Fuel Triumph 1
F Off Topic metal forming for a friend Triumph 25
Got_All_4 TR6 Distributor Gear Mounting Question Need End Float Washer Triumph 4
B Bent frame rails near BE front end Spridgets 2
jfarris Mitty at Road Atlanta this weekend, Apr 23-25 Racing 3
S Rear End Noises Spridgets 28
Walter74 Steering Box End Play Austin Healey 2
S Sway Bar End Links Austin Healey 15
K TR2/3/3A Removal of tie rod end? Triumph 7
roscoe Rear end crown and pinion gear swap. 4.11:1 to 3.54:1 [long read] Austin Healey 12
S TR2/3/3A purchased a box of tr3 parts this weekend, Triumph 1
S TR2/3/3A Cutting the finish end on the windshield top rubber Triumph 4
B 2013 Nissan Frontier front end mystery Other Cars 7
K TR2/3/3A Front wheel bearing adjust and end float?? Triumph 10
J TR6 End Float Triumph 5
Jayplum TR2/3/3A Steering Box end play Triumph 6
J TR6 Top End Chatter Triumph 11
A TR2/3/3A Rear end locked up Triumph 6
drooartz MGB Talk to me about bottom end bearings MG 34
B BJ7 back end rebuild Austin Healey 1
K TR2/3/3A Isit possible to buy a single left hand thread tie rod end? Triumph 5
R Connecting Rod Big End Specification Austin Healey 4
Michael Oritt Lube points on BN/BT7 front end Austin Healey 4
K TR2/3/3A Advise on previously botched front end lower fulcrum support bracket. Triumph 5
AUSMHLY BJ8 Front End Squeak Austin Healey 25
AUSMHLY 64 front end too high Austin Healey 14
K TR5/TR250 TR250 question [Not asking for a friend] Triumph 17
John_Mc TR6 Twitchy rear end Triumph 18
M MGB New member trying to help a friend with his 1980 MGB LE. MG 4
T TR5/TR250 Wiper wheel box knurled end not tight on arm Triumph 9
J TR2/3/3A Hastings Piston Ring End Gap Issue Triumph 16
