TR4/4A TR4 Laygear circlip - or lack thereof
AHS
Hi, I've got a question about a TR4 transmission rebuild. I've never done a TR transmission before and this specific one is CT33xxx. Most of it was in good shape but there was some wear on the layshaft at the rear bearing, which I understand is common. The rear needle bearing also needs replaced. The odd think is that the bearing housing was not pressed fully into the layshaft. It was flush with the end of the layshaft but there was about 1/8" gap at the inside end of the bearing. The drawings I have show a spacer washer beneath the bearing and a circlip on top, and this bearing appeared to have neither. Missing components would explain the extra gap. The bearing housing was pressed in place and wasn't going anywhere, in fact it had to but cut out. The bearing was a made in UK Torrington bearing, and I think it was original. Now that the bearing is out there is not even a groove for a circlip. Is this normal?
Now here's the odd part. The front bearing clearly has a circlip and is slightly below flush. There is no gap at the bottom. I don't want to remove the front bearing because I think it is OK, so I don't know if there is a circlip groove. It seems very odd that the front bearing is not retained in the same manner as the rear.
One more thing - I got a new layshaft but it is .002" smaller diameter than the original. This is enough that there is just a little rattle in the bearing. Have others experienced this? I suppose I'm stuck with this, as the old shaft has some damage.
I'll order a new bearing, spacer & circlip, and I hope it is a press fit like the old one. I don't think I'll be able to use the circlip as there is no groove. Am I assembling this correctly or am I missing something?
Thanks,
Andy
alanjohnturner
The gap behind the bearing is really important. Its where you put the puller jaws to get the bearing out.
They are a pain if somone has pushed it right in. I had to make a special tool to get one out.
Can't remember there being any circlips. But there are two distinct bearing types. One, the older one has rollers that can fall out.
The later ones have roller that dont fall out. I have an idea they inter-change.
You will need some kind of tapered guide tool to get the layshaft back through without barking into the corner of the rollers and winding up with a disaster. The layshaft pushes the taper through in front of it and this opens out the rollers and the shaft slide in behind the taper.
I turned a nylon plug but you could carve it in wood I expect.
HerronScott
Andy,
There shouldn't be a circlip retaining the layshaft bearings in the countershaft gear/hub or a spacer. The original ones were a press fit and should be flush (the factory manual shows a stepped drift for installing them - "lettered face outwards") although at some point they did switch to the open-cage ones (certainly by the time of the TR6). I would definitely replace both the front and rear since they are a failure point although I think the rear one is the one that usually fails. You don't want to have to do this again anytime soon for a $20.00 part!
The factory manual shows the countershaft diameter to be 0.8120" to 0.8125". If yours doesn't match that, I would send it back to the vendor as defective. The bore of the countershaft gear for the needle bearings is shown as 1.062" to 1.062".
Scott
alanjohnturner
The next question is "how do I get the bearings out".
Somewhere I have a photo of the original Sykes puller for this job. Shout if you are interested.
I invented a puller to do this. It has two tiny conical "jaws" and a threaded rod to open them and pull on them.
Easy if you can get on a lathe.
These bearings are not very tight. But they wont jump out at you either.
Guys have been known to succeed by Dremel and smash methods.
AHS
AHS
Thanks gentlemen. I don't have a TR4 shop manual as this transmission is intended for a TR3. The layshaft bearings are not the same. It sounds like the bearing is as it was pressed in from the factory, flush with the "Made in UK" facing outward. The front bearing appears to be pushed in too far as you said.
The new shaft measures .8100". The old shaft is .8123," within the specs Scott provided. I don't think I want to use it but I can at least wait to see the fit on the new bearings. Does anyone know of a source for good ones?
Alan, do you have a sketch of that removal tool? I do have a lathe. I cut the rear bearing out and the front is pressed too far in, so it may not do me any good, but I'm curious to see what you invented.
Thanks,
Andy
alanjohnturner
If you PM me I'll send the Churchill tool catalog.
Its too big to post on here.
See tool GV3.
I used a length of 3/8 all thread and two conical "jaws" like GV3.
You make a complete washer with the thread in it and slice in half.
Then grind bits off untll they drop into the bearing.
Fiddle about until you can screw the all thead in and force the jaws into th gap behind the bearing.
If you dont have a gap jack the jaws in behind the rollers.
Pull on the allthread with a nut and washer.
Nearly all the tricky TR dismantling can be solved by a homemade version of one of these tools.
If you have no workshop manual try this:
https://www.vitessesteve.co.uk/Servicemanuals.htm
Al.
R TR4/4A 1963 TR4 soft hood cover with attached plastic stiffeners Triumph 2
T TR4/4A TR4 seat buffer problem Triumph 5
KVH TR4/4A TR4 Movie Showcase Triumph 3
oldbagpipe For Sale 1961-1962 Triumph TR4 Short Bubble Bonnet (hood) Triumph Classifieds 0
oldbagpipe For Sale '2' Triumph TR4 engines Triumph Classifieds 9
scottkilpatrick TR4/4A Send Unit Issues - 62 TR4 Triumph 4
EvansClassicCars For Sale 1966 TR4 Triumph Classifieds 0
S TR4/4A TR4-Stromberg throttle shaft play Triumph 3
scottkilpatrick TR4/4A Difficulty Level with specific maintenance TR4 - Part 2 Triumph 8
scottkilpatrick TR4/4A Difficulty Level with specific maintenance TR4 Triumph 10
mctriumph TR4/4A earliest Tr4 ?? Triumph 0
D TR4/4A TR4 inner ball joints Triumph 8
jfarris For Sale TR4 Fuel Gauge with 2 Transmitters Triumph Classifieds 0
mctriumph For Sale hood for early Tr4 Triumph Classifieds 0
Rod-H TR4/4A TR4 Body Number Plate Supplier Triumph 6
F For Sale Four Steel Wheels Triumph TR3 or TR4 Triumph Classifieds 5
KVH General Tech Heater and Vent Control Cables--TR2 thru TR4, and more . . . Triumph 3
Tim Tucker TR4/4A Konig 16x7 wheels and leaf spring clearance for TR4 Triumph 5
MTr4 TR4/4A In search of a 1962 TR4 Triumph 2
A For Sale 1963 TR4 for sale Triumph Classifieds 0
Cokerair TR4/4A Searching for "How To" instructions for TR4 Tonneau Triumph 5
J TR4/4A 1964 Triumph TR4 - Not Starting/Running Triumph 3
tj_tr3_tr6 Wanted Wanted / Need / TR4 Engine Block for 62 Tim from So California Triumph Classifieds 3
mctriumph For Sale Tr4 Short bubble Bonnet Triumph Classifieds 2
K TR4/4A TR4 no start Triumph 26
L For Sale TR6 1976 (restorable project) and TR4 1966 for parts Triumph Classifieds 4
G TR4/4A TR4 Lacks Spark! Triumph 22
Ericstammer TR4/4A TR4A body on TR4 frame Triumph 0
tj_tr3_tr6 TR4/4A looking for Machine Shop TR4 Valve Job Ventura - Los Angeles area Triumph 4
K For Sale TR2-TR4 Camshaft Sprockets...New...1/2 Price Triumph Classifieds 0
P Wanted WTB Restorable TR4 Triumph Classifieds 7
A TR4/4A TR4 Overdrive Solenoid Triumph 19
J For Sale 1965 TR4 + TR3 Parts - floors, gauges, misc. Triumph Classifieds 14
D TR4/4A Automatic transmission in a TR4 A Triumph 13
Twit TR4/4A First startup of TR4 Triumph 4
Twit early TR4 Crank Handle wanted Triumph Classifieds 0
Lotuswins TR4/4A Is this normal? TR4 gap between door and cowl Triumph 10
R Tr4 restoration books Restoration & Tools 2
M TR6 EZ EPAS Steering Column Fitment to TR4-6. Triumph 0
Kurtis TR4/4A TR4 Wiper Arm Remval Triumph 2
Twit TR4/4A early tr4 check straps Triumph 4
Twit TR4/4A restoring TR4 sun visors Triumph 0
