Insulation Done [pics]
Miser
This was a miserable job but it's done. I also added a kill switch on my transmission tunnel. I even double coated the outside and inside the transmission tunnel because that's where most of the heat comes out of!
Mickey Richaud
Nicely done! You're gonna thank yourself later!
Tugboat
Yeah it's a miserable job because it looks so sloppy while you are doing it but Mickey is right, you'll appreciate it later. Wait until the first time you go over some railroad tracks and for the first time you won't wonder which part of your TR just shook loose. The sound deadening effect is that good.
KVH
Looks great. I've now done that to three TRs. The toughest part is getting that dash saddle to go back over the hump. It's as if back in '62 they had a special computer that calculated the precise curvature so that the four bolts could reach the captive nuts only in one precise location, at one exact angle, and only then without cross-threading or stripping the bolts.
The insulation does look great. Heat and sound.
Is that Eastwood product backed with a thick matting?
M
Miser
The Eastwood mat is about medium thickness. I am going to add thicker material down where my feet will be.
TR3TR6
Looks real good. You might want to stay away from a black interior, that installation works both ways when your running with the top down.
M
Miser
good point I didn't think of this
Patrick67BJ8 Insulation and Sound Deadening Austin Healey 0
FlyingCat Spitfire Insulation Triumph 2
Walter74 Insulation set from Koolmat Austin Healey 3
EWD TR6 Transmission tunnel insulation Triumph 6
NutmegCT Garage roof insulation Restoration & Tools 37
Jim_Gruber Heater Box and Insulation for Bugsy IV Spridgets 8
Rut Bugeye bonnet insulation Spridgets 4
D Fire wall insulation Austin Healey 36
NutmegCT wet insulation Restoration & Tools 9
M TR4/4A Underhood/Bonnet insulation...Yes...No ? Triumph 3
maxwedge5281 under floor insulation Austin Healey 15
L 3000 BN7 insulation Austin Healey 11
H quick insulation paint color quesrion Austin Healey 7
Griz Cockpit Insulation Austin Healey 13
R Interior cockpit coatings and insulation Triumph 12
F Wire insulation damage under the dash - Bugeye Spridgets 5
R Another insulation question Austin Healey 3
B insulation to the footwell Austin Healey 21
andrea Insulation Austin Healey 6
S TR6 Hood insulation for 1972 TR6 Triumph 3
memphis Braided Wire Insulation Austin Healey 12
bighealeysource good heat insulation product Austin Healey 1
A 76 MIDGET CARPET / INSULATION / SEAT INSTALL Spridgets 11
B Floor insulation question Austin Healey 10
jhorton3 Interior Insulation Spridgets 17
T TR6 TR6 heat insulation recommendations Triumph 12
martx-5 Cloth Insulation Tape Triumph 4
Raymond Insulation MG 3
NutmegCT heat insulation - interior Triumph 22
R John loftus bj7 restoration firewall insulation Austin Healey 6
W MGB Under-hood insulation on the MGB MG 8
A Dynamat ?---or what interior insulation?? Triumph 27
chicken Floor pan insulation panel Austin Healey 7
RomanH Timing Cover Sound Insulation Triumph 6
A Sound/heat insulation with foil---which way?? Triumph 7
jerrybny Heat & Sound Insulation question Triumph 2
H SU insulation installed MG 2
H Need heat shield insulation MG 4
C Floor insulation Austin Healey 17
T HVAC box to firewall insulation? Triumph 0
C Heat insulation washers Austin Healey 6
S Lizard Skin Ceramic Insulation MG 0
D Sound Absorber / Insulation in TR-# Doors? Triumph 8
W Exterior Heat Insulation?? Austin Healey 20
L What to use for carb shield insulation? MG 5
Stinky Can't find old post about insulation/sound deaden Triumph 8
A MGB MGB insulation and ventilation MG 2
mctriumph General TR They are never DONE!! Triumph 5
PAUL161 NASCAR, I'm done. Racing 11
PatPink TR6 Hello, I am new to the site and want to post some photos of my 1973 TR 6. I have done all mods to this car except body and paint. Triumph 10
