Bugeye bonnet insulation
Rut
Good morning all...hope it's a good Saturday for you. While I would like to keep my Bugeye 'stock' in appearance I really want some heat protection for the bonnet and would like to install some type of mat to the underside of the bonnet. The shiny stick on stuff is not the look I want, but is the fiber style durable if glued on? This is the type on MGBs and TRs that's pretty commonplace.
Thanks, Rut
Rut
Rut
After a little research I ended up ordering the Dynamat 11905 Hoodliner which is a cut to fit and self adhesive 3/4" thick insulation. It's not exactly the look I wanted, but it has good reviews.
Rut
HealeyRick
Y'know, Rut, I'm not quite sure why you want to insulate your hood. Can't imagine you want to keep heat in the engine compartment and I doubt the exterior paint is going to get hot enough to damage it. Is it just for appearance? Not being critical, but I don't think I've ever seen that one to a bugeye before.
Rut
Rut
Rick,
I guess it's more of a habit than anything else since I've had or installed them on every LBC I've owned. I don't if it's necessary to help prevent paint damage, but my moderate engine build includes headers which might raise under hood temps. I can't see it raising temps or preventing heat from escaping enough to make a difference, but welcome any input since I don't want to cause a problem.
Rut
HealeyRick
Rut,
Other than protecting the paint from oil, I can't see it making much difference. Are you going to install it all the way down to the top of the grille? I guess they must be pretty popular as the Little British Car Co sure seems to have a bunch of them: https://www.lbcarco.com/cgi-bin/gen5?nextform=/bonnetliner.html&t=_top&o= I just never saw the nee for them, except as an appearance item.
D Wanted Bugeye bonnet (hood) fiberglass or steel Austin Healey Classifieds 0
B Wanted Bugeye front bonnet fender mirror like this Spridgets Classified 5
B Wanted I need a small section of a bugeye bonnet Spridgets Classified 5
Rhodyspit75 Bugeye bonnet prop rod Spridgets 2
Rhodyspit75 Bugeye bonnet brace. Spridgets 5
M Bugeye Tilting Bonnet Hardware Spridgets 2
Gerard Bugeye bonnet and entire rear clip Spridgets 4
A Best fibreglass/GRP Bugeye bonnet Spridgets 21
Rut Bugeye bonnet handle escutcheon Spridgets 9
Rut Bugeye bonnet mirror Spridgets 11
Rut Bugeye bonnet fit Spridgets 19
Rut Bugeye bonnet gas struts Spridgets 6
Editor_Reid Securing Bugeye Fiberglass Bonnet Spridgets 15
TulsaFred Bugeye bonnet prop rod Spridgets 7
6 crossflow radiator with bugeye bonnet? Spridgets 5
Rut Bugeye bonnet Spridgets 0
DanLewis New fiberglass Bugeye bonnet $395 [NFI] Spridgets 0
Rut Bugeye bonnet Spridgets 1
Rut Bugeye bonnet Spridgets 5
I Bugeye bonnet hinge bolt head busted off - ideas? Spridgets 8
I Anyone have a bugeye bonnet hinge or bonnet stay they could sell me? Spridgets 5
bugedd Bugeye bonnet differences Spridgets 9
I Help removing bugeye bonnet please Spridgets 5
P Bugeye Bonnet Latches Spridgets 7
Hairyone bugeye bonnet radiator cowl Spridgets 3
I bugeye bonnet welding help please Spridgets 11
Rut Bugeye bonnet latch Spridgets 13
RickB Bugeye Bonnet $100 on Santa Barbara craigslist-nfi Spridgets 1
The_architect Bugeye bonnet badges Spridgets 7
M Bugeye bonnet sheetmetal question Spridgets 12
I Tips or installing Bugeye bonnet needed Spridgets 14
Trevor Jessie Bugeye rear ends 100-6 [needs a bonnet] Spridgets 11
I Bugeye bonnet gaskets - do I really need these? Spridgets 10
I bugeye bonnet wiring harness fasterner help Spridgets 16
R bugeye bonnet Spridgets 7
P Bugeye bonnet on Craig's list Seattle Spridgets 6
RickB Bugeye Sprite Bonnet found on Ebay only $2900!!! Spridgets 11
M Tilt Bonnet Hinge Kit 4 BugEye Spridgets 8
Morris Winner's circle Bugeye Bonnet Spridgets 4
M Bugeye bonnet mounted on later sprite or midget? Spridgets 21
Jim_Gruber Front Hinged Bugeye Bonnet/Getting to curve back i Spridgets 6
Jim_Gruber Bonnet Seal / Bugeye Bonnet on Mark IV Sprite Spridgets 5
Branson Free bugeye bonnet <-- well almost Spridgets 1
drooartz How many guys to pull a Bugeye bonnet Spridgets 19
Jim_Gruber Getting the curve back in a Bugeye Bonnet Spridgets 3
Jim_Gruber Bugeye Bonnet Installation Up-date Spridgets 3
Jim_Gruber Trimming Inner Fender for Bugeye Bonnet Spridgets 13
racingenglishcars Jyllandringen grand prix Bugeye bonnet Racing 6
Morris Bugeye Bonnet SWA Butt Spridgets 0
John Moore Bugeye Bonnet Question Spridgets 6
