Interior cockpit coatings and insulation
Rajun Cajun
I just got my tr 6 back from the body shop and had new floor pans put in. they are sealed and primed twice. Anyone try using pick up truck bed liner as a first coat before doing any other work in the interior? was think about the sound insulation qualities of this product as well as the ability to absorb vibrations and protect the metal floor pans. any ideas or pictures please share.
NutmegCT
Welcome to BCF!
I had slightly rusty floor pans, so scraped off surface, treated with phosphoric acid, then POR15. Then I put Home Depot foam carpet insulation mat (loose, not glued) on the surface, and regular interior carpet. That carpet insulation does *wonders* for heat and sound insulationi.
The pickup liner stuff may help a bit with sound, and will certainly "protect" the floor pans if that's what you want. But rubber mats and/or carpeting will do the same thing - and are removable if needed.
Got any pictures of your 6?
Tom
PeterK
IMO bedliner is a perfect undercoating, floor stiffener, and vibration absorber. I would put it on outside surfaces not in the interior but have seen it done both ways. I wouldn't want to try to remove it though as it seems like it bond so well, it would be worse than asphalt undercoatings of the past.
R
Rajun Cajun
Welcome to BCF!
Tom
Thanks for the welcome aboard. I will take some happy snaps of the car today. I have three goals in this project. First is a bit of heat insulation on the right side of the cockpit. previously, I noticed a bit more heat under the right side and when I removed the carpet on the right side it looked really ugly. my guess is the combination of heat and moisture and temperature extremes helped cause the right side floor pan to deteriorate more as compared to the left. secondly, a little sound proofing might be nice, and thirdly, if I can protect the metal from water that will be an obvious benefit, although I don't plan to drive the car in the rain. As a side note, I am also going to wrap the exhaust pipes with a quality exhaust wrap.
R
Rajun Cajun
TR3pilot
Member
May I be so bold as to ask the cost of the labor for the floor replacement?
Thanks
ps I know of a stock trader who goes by your handle, not you is it?
R
Rajun Cajun
the cost of the floors was 200, I bought those. the labor was about 8K. Also involved in that was replacing all 6 U joints and powder coating rear end while it was disassembled for the floor pan replacement. the shop told me that they had to drill out each weld individually and peel back the metal and then re-install. I had started out just wanting to do lizard skin on the floor pans for about 400. floor pans were too rusted to do it, so they had to be replaced. another local shop owner went and looked at the car and he told me I was getting way over-charged. the conclusion was that while the car was on a lift and brace welded to hold everything in place that I was sort of sucked into completion of the job. every invoice I got was 40 percent more than originally estimated. I finally pulled the car once the floor pans were in and decided to do the spray in liner just due to cost as no more funds were available to do the lizard skin. not a stock trader.
apbos
I used Raptor Liner on my B/E. It is tintable and it can be rolled on or sprayed. Hard as nails. One step for you and done! You can get a kit on Ebay. 4 qts will do both top and bottom with extra for areas that would typically be undercoated.
Paul
R
Rajun Cajun
below are some pictures of my 74 TR 6.
Gliderman8
I used bed liner as an undercoat on my 6. It is holding up nicely!
UltimateQuestion
Yikes! 8K for floors! I am even more convinced to learn welding while replacing mine.
MichaelG
POR 15 would be choice. it has held up for many years on my 4A. You might only need one of their topcoat products given the two fresh coats of primer...best to call customer support for recommendation. Many choices on insulation. I elected to insulate the underside of the transmission tunnel with a foil faced heat shield attached with 3M heavy duty spray adhesive and covered the seams with aluminum tape..aluminum side facing out. Under the carpet I would only use something that breaths such as regular Jute underlayment or perhaps the "synthetic jute"...this way no moisture will be trapped between the floor and whatever is under the carpets.
SpeedyG TR4/4A Interior door handles and escutcheons Triumph 9
AngliaGT MGB-GT WANTED: Driver's Door Regulator + Two (2) interior handles. MG 1
Popeye TR4/4A Attaching convertible top to bows - interior Triumph 2
Overdrive45 BJ8 Interior Trim Austin Healey 8
KVH General Tech Reinstalling TR4A Interior Triumph 13
Mickey Richaud Wanted Interior Austin Healey Classifieds 2
W TR2/3/3A Interior and Body Colours Triumph 14
D For Sale BT7 interior door cards - new ! Austin Healey Classifieds 0
K 100-6 Interior Austin Healey 4
MGTF1250Dave T-Series Interior Trim Panel installation MG 12
Csarneson BN4 Interior Assembly - Unidentified Holes Purpose Austin Healey 2
H 100-6 Interior Installation Austin Healey 4
nichola TR6 Interior panels Triumph 5
F Interior Door Handle Removal Austin Healey 2
S TR2/3/3A carpet kit and the interior done Triumph 8
B BJ7 Interior Finishing Details Austin Healey 2
rjc157 Wanted 76 interior Triumph Classifieds 1
77MidgetMkIV New top and interior-that escalated quickly! Spridgets 9
C XK120 Interior... and Interiors in General Jaguar 17
B TR4/4A Midnight blue interior Triumph 6
T Interior Door Panel and Top Rail Austin Healey 3
Y For Sale MK V DHC interior wood for Left Hand Drive Jaguar Classifieds 2
A TR2/3/3A Interior rear panel covering gas tank and rear seat bottom install. Triumph 7
S TR2/3/3A copied an old original interior piece and carpet pad Triumph 6
EWD TR6 ‘74 TR6 Interior - Padded dash and heat/sound material Triumph 4
S TR4/4A Vinal interior trim piece eaten by rodent Triumph 3
F Wanted Used leather interior for BT wanted Austin Healey Classifieds 5
R Wanted TR6 Interior Door panels Triumph Classifieds 0
AUSMHLY BJ8 Leather interior - what pieces were leather/vinyl Austin Healey 13
D Interior Finished Austin Healey 3
G For Sale TR6 Matador Red Interior and Boot Triumph Classifieds 0
F Bug eye interior Austin Healey 2
D BT7 interior purchase Austin Healey 5
D Prepping Floors Before Installing Interior Restoration & Tools 6
HealeyRick 100 Interior Trim Austin Healey 1
G TR4/4A Interior Install...and other random questions. Triumph 11
D T-Series Trying to find out an interior dimension MG 7
S For Sale Austin Healey 100-4 Carpet Kit and Interior Panel and Trim Kit Austin Healey Classifieds 0
D interior on a budget... Austin Healey 6
R Paint first or interior Austin Healey 10
ckeithjordan TR2/3/3A New Interior Trim Re-Use Triumph 6
G TR4/4A Interior Install Steps Triumph 3
Zitch TR4/4A Tr4 Carpet Install and interior install Triumph 2
C For Sale 1965 TR4 Red - Black Interior Triumph Classifieds 4
T Colorado Red Vinyl Interior Austin Healey 6
CessnaTPA New Interior Recommendations Austin Healey 8
D BJ8 Interior Austin Healey 6
Rut TR4/4A Rimmer interior Triumph 17
J 100-4 interior kit Austin Healey 3
K BJ7 interior back panel difference Austin Healey 4
