MGB MGB insulation and ventilation
A
aerog
I was working on my MG today and realized that I really don't have much in the way of insulation on the floor, transmission tunnel, and firewall. There is a thin layer of, well, wool-ish batting under the carpet that doesn't amount to much. Any suggestions on a decent insulating material to lay around there to help keep the exhaust heat out?
Along similar lines I was playing with the inside vents. I have to admit I've never payed close attention to exactly where the air is supposed to go when you open the vent behind the radio. There's a small gap in the console for air to move along the driver's legs, but not much for the passenger. Is there something missing that helps direct the air into the cockpit?
Regardless, it seems like the lower fresh-air vent works best CLOSED so 100% of the air goes through the upper vents, just curious if there was something else missing.
Kim de B
Scott --
As you may recall, I added "heat shield" insulation to my car this winter. (Under floor carpets, on tranny tunnel, on firewalls, even behind the side kick panels.) I highly recommend it. The car is remarkably more solid sounding, and a LOT less warm on the feet and especially on the tranny tunnel.
This is stuff that Moss sells. ("Space age" insulation. About $25 a roll.) I tried to find the same stuff in stores locally, and couldn't. It took two rolls to do the job. I've got enough left over to do behind the door panels, which I'm going to do the next available weekend.
I also, at the last minute, decided to put down a sound deadening kit. (Also from Moss, it's the British Heritage Trust kit.) But you can buy a similar adhesive asphalt-based polymeric sound damper stuff from McMaster-Carr online. Cheaper and more pliable. Only you have to cut it into strips yourself and apply it between the ridges of your floor boards.
I know the McMaster-Carr stuff would work, as a guy on another MG board sent me a sample to compare with the Moss kit. Same thickness, but more "rubbery," and not so fragile as the OEM stuff.
A
aerog
OK thanks for the info. I do have some sound-deadening "stuff" down there (not bare metal), but not exactly like what you're talking about either. I'll look into the other stuff. I'm not sure I want to go to all the trouble right now of taking the console apart (yeah, remember I have the later more modern and oh-so convenient version with all the plastic around it
), but I might manage to do the rest of the car soon.
W MGB Under-hood insulation on the MGB MG 8
CJ Burton MGB-GT Bolts for INERTIA STARTER on 1966 MGB GT MG 8
M MGB Ground polarity '67 MGB MG 2
M For Sale 1978 MGB MG Classifieds 0
Carlbanan56 MGB MGB oil consumption MG 5
A Wanted 1970 MGB - Emissions Parts MG Classifieds 3
C MGB Re strapping a MGB seat bottom MG 2
Simmo MGB Re Engined MGB MG 4
Carlbanan56 MGB MGB rear break rebuild MG 6
C Wanted Early MGB soft top and/or tonneaus, condition not very important MG Classifieds 0
Carlbanan56 MGB Mgb turn signals MG 17
J MGB 1970 MGB Steering Lubrication MG 1
C Wanted Wanted: 1977 to 1980 MGB Dashboard MG Classifieds 0
L SOLD!! For Sale MGB Hardtop MG Classifieds 3
EvansClassicCars For Sale 1980 MGB for sale MG Classifieds 0
J MGB Tire pressure for 1980 MGB MG 14
5 Wanted Wanted 1966 mgb banjo type axle rear hub MG Classifieds 0
I MGB Purchase of 1972 MGB Roadster MG 3
C MGB-GT MGB-GT Front Ride Height MG 0
J MGB Advice for new MGB owner? MG 16
D Wanted Wanted: Chicklet Headrests for MGB/C! MG Classifieds 0
Editor_Reid MGB Anders Clausager's "MGB" book MG 4
J MGB 1966 MGB won't start MG 1
Erica General MG Oil Drain Valve -- mine is an MGB, but they have others MG 3
TunaJ Will MGB Upper Seat Runners work with Midget seat rails? Spridgets 1
Erica MGB Carburetion and MGB fuel economy. MG 0
wkilleffer MGB MGB clutch slave bleed driving me nuts MG 38
R MGB side chrome installation MG 4
C MGB MGB MG 5
3798j Off Topic MGB at the Drive in Bank MG 1
wkilleffer MGB 1974 MGB clutch master cylinder questions MG 1
Rut MGB 62-67 upper MGB steering shaft MG 3
VeeCee MGB 1974 MGB Roof Installation MG 0
J MGB Just bought a 1966 MGB MG 50
T MGB MGB hoses MG 6
G MGB Sorry from the Newbie...Clutch gone on 78 MGB MG 17
Briancole702 MGB-GT 71 Mgb gt no gas in float bowls MG 1
Ranger68 Wanted 1969 MGB Sun Visor Wanted MG Classifieds 0
R MGB MGB Roadster Door Panel Speakers MG 9
DrEntropy MGB Good video on the MGB MG 0
adcronin For Sale MGB Turn Signal (lights, horn, indicator) Switch, New for 62-67, also Sprite MK 3 & 4, MIDGET MK 2-3 thru 67 MG Classifieds 0
J Wanted 1969 MGB Roadster sun visor clip MG Classifieds 4
JohnGone MGB 1980 MGB Spark Plug recommendations MG 6
R MGB 1972 MGB Defroster Hose MG 2
T For Sale MGB Black Label Overdrive For Sale Or Trade For New RB Parts MG Classifieds 2
T MGB-GT cant rails on 1967 MGB GT MG 12
JohnGone Wanted '80 MGB without seat belts? MG Classifieds 3
JohnGone MGB Help getting my 1980 MGB to pass CA smog test MG 19
JohnGone Wanted Spare & Jack for an '80 MGB MG Classifieds 0
