TR6 Transmission tunnel insulation
EWD
Any current thoughts on whether to insulate the transmission tunnel on top or underneath? (using one of the heat/sound insulating products) Have seen it done both ways. It would seem that if underneath, it would give you a better top fit for the carpet and padding.
Thanks,
Will
Madflyer
EWD
I did sound heat pad then carpet over same. seems to work well I did glue it down and comes off in one piece. On my MG B same and the shift lever cover I used spray foam on inside for heat. Madflyer
Martin Secrest
I've used bubble foil insulation underneath the tunnel on both a GT6 and my TR6, with general trim spray adhesive. Doesn't take long, but you have cut a few different pieces to get the whole thing covered obviously. The difference was quite noticeable on the GT6, probably mostly because that car puts out so much undissipated heat to begin with. Didn't make quite such a noticeable difference in the TR6, but the GT6 tunnel was plastic and it's fiberglass on my TR. It seems to me it's done to better effect if done from underneath, but as usual, I have no actual data to buttress this belief, like most things I say. :single_eye:
EWD
EWD
Thanks to all for quick and helpful replies.
Madflyer - Finished my instrument rebuild. No longer need the bezel. Thx.
Will
Madflyer
No problem help is still here on TR 6's. I am in the middle of my up dating on my 1973 timing chain and cover seal one leak down after test. New radiator. Now trans seals parts due in this week. pulled yesterday flushed trans found just a few metal bits on magnet drain plug should be OK then new front windscreen and last a Backlight to replace top and role bar ( Backlight is rear glass with Surry filler between front and back glass and or fiberglass top panel ) When I am able to do pic will post same. Madflyer
T TR2/3/3A Transmission Tunnel Configuration Triumph 11
nevets Transmission tunnel removal Austin Healey 4
S Jute Installation on Transmission Tunnel - Heritage Trim Austin Healey 9
J TR2/3/3A Transmission tunnel gasket? Triumph 16
F Seal between transmission tunnel and the forward bulkhead Austin Healey 7
MikeAH100M Transmission Tunnel Install - BN2 Austin Healey 2
P Mysteries under the BJ8 transmission tunnel, speedometer cable, overdrive and gerabox Austin Healey 1
B TR2/3/3A Beat my transmission tunnel to death? Triumph 12
T TR4/4A Cutting an access panel into transmission tunnel cover for solenoid adjustment Triumph 13
nevets Removing carpet from transmission tunnel Austin Healey 15
F TR4/4A TR4 shifter and transmission tunnel Triumph 4
mgbmedic TR2/3/3A TR3 Transmission Tunnel Triumph 8
eschneider Spitfire Spitfire ABS transmission tunnel cover - worth it? Triumph 10
M Transmission tunnel removal Triumph 14
chicken how do you secure the transmission tunnel down ? Austin Healey 19
J Transmission Tunnel Cover - BN7 Austin Healey 10
C Transmission tunnel carpet Austin Healey 2
CCURTISS TR2/3/3A TR3 Transmission Tunnel Sealant Triumph 7
Ed_K Don't use RTV to seal the transmission tunnel Austin Healey 28
DNK Transmission Tunnel Lamp Triumph 0
Sprocket BJ-7 Transmission Tunnel Removal Austin Healey 5
S Transmission Tunnel Seal Austin Healey 3
vette Transmission Tunnel Seal Austin Healey 7
L Early B transmission tunnel cover needed MG 8
S Transmission Tunnel Austin Healey 5
Jim_Gruber Correct Transmission Oil for Datsun 210 5-speed Spridgets 1
mctriumph SOLD!! Tr7/ Tr8 transmission Triumph Classifieds 0
C TR6 Transmission Number Meaning Triumph 5
R 100-4 Transmission Austin Healey 1
J TR4/4A TR4A automatic transmission conversion Triumph 6
Popeye TR4/4A Transmission noise - intermittent Triumph 22
D XK150 Transmission Input Shaft Jaguar 1
A TR2 Transmission overhaul Restoration & Tools 0
E General MG Transmission Fluid Level MG 2
B Transmission Gear Lockouts Austin Healey 8
K Putting a Getrag 5 speed OD transmission in a Jaguar Mkll ? Jaguar 4
AUSMHLY Transmission Noise Austin Healey 11
KVH General TR Transmission Problem Triumph 3
T Looking for "BillMs rear transmission mount" Spridgets 2
T For Sale Excellent Original 1968 TR250 Frame with Engine & Transmission Triumph Classifieds 6
D TR2/3/3A Torque for bolts back of transmission ? Pl Triumph 0
bighealeysource Side-Shift Transmission Austin Healey 13
D transmission conversion Other British Cars 1
PAUL161 T-Series Original transmission sold MG 2
KVH TR4/4A Assembling Transmission to Engine--Vice/Versa Triumph 4
BritBite Transmission Repair Austin Healey 8
AUSMHLY Transmission Bearing, Sealed vs. Non-Sealed Austin Healey 6
