    BCF is a FREE resource for the Little British Car community. I just did a little math and found that less than 1% of the registered members appreciate this forum enough to support us with an account upgrade. We do not "require" you to pay to play here, but if you find BCF helpful, appreciate no pop up ads, and want to ensure we stay online - Consider supporting us with an "optional" low-cost member upgrade. There are some benefits to upgrading!
TR2/3/3A TR3 Transmission Tunnel Sealant
CCURTISS
I have my TR3 transmission tunnel out of the car and will be re-installing it shortly, what is everyone using as the sealant around the metal tunnel to the car?
I bought a tube of latex caulk/adhesive from Home Depot last time (fits in my caulking gun). Worked well for me, I'll use it again. Easier IMO than messing with rubber strips.
I was thinking of doing that but I was a little worried about how hard it would be to remove at a later date if I ever had to take it out again. I am guessing that is what I will end up doing.
Thanks,
I used a kit for a TR4-6 from TRF. Worked well.
Recently I came on a great tip for reinstalling the cover.
When I did mine, I wrestled it trying to get the bolts to line up with the captured nuts in the floor. The trick is to use longer bolts threaded UP through the captured nut from the bottom. This gives you a stud-type arrangement making it easier to deflect the holes in the cover over the studs. Then use washers and nuts from the top to hold it down.
What a nifty idea!
Glad to hear that the TR4 kit works. I've been thinking about that experiment, and I'm glad to know I won't be the first to attempt it.
You can buy silicone rubber based "rope caulk" at the Home Despot. You want something that doesn't set up or harden.
Came right out for me. Either it's not that good an adhesive, or I didn't get the oil cleaned off enough, or possibly the surface was contaminated with DOT 5.
FWIW, I used closed cell foam tape, as used for insulating around door, etc.
Just as an aside, you might go back a couple years in the posts, if you have the time. It's amazing what you don't know you don't know, and the answers will be there. (Sorry, shades of D. Rumsfeld). I bought a TR6 a while back, and spent a couple evenings just powering thru old threads. Learned a lot, and very entertaining!
mgbmedic TR2/3/3A TR3 Transmission Tunnel Triumph 8
S For Sale FREE - TR3 engine and transmission Triumph Classifieds 0
S TR4/4A TR3/4/4a Transmission rebuild question Triumph 7
S TR2/3/3A What weight transmission oil in a tr3 with OD? Triumph 13
G Wanted TR3 Overdrive Transmission Triumph Classifieds 2
Moosca TR2/3/3A TR3 Overdrive Transmission Verification Triumph 5
T For Sale Free tr3 transmission radiator and generator Triumph Classifieds 2
Got_All_4 TR2/3/3A Fitting the original tr3 transmission cover over a tr6 overdrive Triumph 9
D TR2/3/3A TR3 Overdrive to transmission mating problem Triumph 8
R TR2/3/3A TR2/TR3 transmission dip stick access Triumph 10
T TR2/3/3A Will Spitfire D-type overdrive work in TR3 with TR4 transmission? Triumph 3
R TR2/3/3A TR3 A Transmission rebuild Triumph 5
charleyf TR2/3/3A Transmission numbers on a TR3 Triumph 7
Scotsman TR2/3/3A HVDA transmission conversion. 90* speedometer cable adapter may be required on TR3's Triumph 4
JFeher TR2/3/3A Has anyone installed a TR6 OD transmission in their TR3? Triumph 8
AHS TR2/3/3A TR3 transmission clutch fork & shifter removal? Triumph 5
T TR4/4A I'm back to the well of knowledge - TR3/TR4/TR4A clutch-transmission confusuion Triumph 10
P TR2/3/3A TR3 Transmission oil Triumph 13
T TR2/3/3A Is CT52431 a TR3 Transmission serial ? Triumph 4
T TR2/3/3A What weight gear oil to use in TR3 transmission? Triumph 23
Russ Austin TR2/3/3A TR3 Transmission Installation Hints / Tips Please! Triumph 14
Russ Austin TR2/3/3A TR3 Transmission question Triumph 8
O TR2/3/3A TR3 Transmission Removal Triumph 2
RedTR3 TR2/3/3A TR3 Transmission Differences Triumph 27
RedTR3 TR2/3/3A Removing TR3 OD transmission Triumph 5
M TR2/3/3A Draining and refilling TR3 transmission with OD Triumph 23
M TR2/3/3A Metal transmission cover color for TR3 ??? Triumph 9
T TR2/3/3A TR3 transmission cover - supposed to be metal? Triumph 5
Moseso TR2/3/3A TR3 Transmission noises Triumph 11
K TR2/3/3A Toyota transmission for TR3=long distance driving Triumph 13
CCURTISS TR2/3/3A TR3 Transmission Questions Triumph 14
B TR2/3/3A tr3 transmission oil fill plug Triumph 18
White79MGB TR2/3/3A TR3 Transmission Oil Triumph 18
hondo402000 TR6 TR3 VS TR6 Transmission units Triumph 6
gubba TR2/3/3A TR3 B 5 speed Transmission conversion Triumph 0
S TR2/3/3A tr3 transmission Triumph 2
S TR2/3/3A tr3 transmission front seal Triumph 3
mcguijo TR2/3/3A TR3 Transmission Blues Triumph 16
jsneddon TR2/3/3A TR3 Transmission Oil Capacity Triumph 3
S TR2/3/3A Tr3 transmission oil Triumph 4
T TR2/3/3A Hole in transmission bellhousing TR3!!!! Triumph 5
T TR2/3/3A Proper oil TR3 Transmission Triumph 3
W TR2/3/3A TR3 Seat Belts Triumph 3
R TR2/3/3A TR3 Timminge Triumph 11
J For Sale Triumph TR2 TR3 rocker panels, right and left Triumph Classifieds 0
J SOLD!! Triumph TR2 TR3 Channel - Drip - Rear Edge Triumph Classifieds 1
J For Sale TR2 TR3 Tie Member Triumph Classifieds 0
S TR2/3/3A tr3 valve spring compressor Triumph 5
