TR2/3/3A TR3 Transmission Removal
oxendine
After finally sorting my TR3 to the point I could actually drive it the transmission started acting up. Hard to shift into 2nd gear and a squeal from what sounds like the throw out bearing. I've decided to pull it and install a TR4 box. I have done this job in the past but cannot remember the details. Does the back of the engine need to be tipped a bit to remove the upper bolts? Any tricks or tips to ease the removal/installation?
Thanks, Donnie
TR3driver
Great Pumpkin - R.I.P
Yeah, you'll have to lift the rear of the engine some, mostly to get the gearbox out. The TR4 box is also longer by about 3/8", so you'll need to slot the holes in the rear cross-member. I would also add the reinforcement for the taper pin before you put the box back in. And, it might be worth making up some long headless bolts, to use in place of the studs, as a guide for installing the box.
Otherwise, it's pretty straightforward.
If you were using a later gearbox, there are also some accommodations required for the thicker bellhousing flange, but as I recall the TR4 box was the same thickness as the TR3.
Oh, and if your TR3 is before TS50,000; you may need to do some sheet metal work on the tunnel, to clear the starter bulge. You might also want to consider combining the top covers, so you can keep the dipstick.
Although the TR4 shift lever will work, my preference would be to keep the original TR3 lever. It will fit into the TR4 top cover, but it may be necessary to drill out one or two of the holes, so you can insert the cross bolt. At some point, it became two threaded pins instead of the early cross bolt.
Geo Hahn
What he said.
Some photos just 'cause I like photos:
The headless bolts I use, screwdriver slot in the ends:
Cutting cardboard to fit the floorboards keeps it neat and the dingus slides out better. I go out the drivers side if the steering wheel is out of the way:
The aforementined cross bolt:
I just confirmed that the flanges are the samer thickness on my 3 & 4 bellhousings.
AHS TR2/3/3A TR3 transmission clutch fork & shifter removal? Triumph 5
S TR4/4A TR3/4/4a Transmission rebuild question Triumph 7
S TR2/3/3A What weight transmission oil in a tr3 with OD? Triumph 13
G Wanted TR3 Overdrive Transmission Triumph Classifieds 2
Moosca TR2/3/3A TR3 Overdrive Transmission Verification Triumph 5
T For Sale Free tr3 transmission radiator and generator Triumph Classifieds 2
Got_All_4 TR2/3/3A Fitting the original tr3 transmission cover over a tr6 overdrive Triumph 9
D TR2/3/3A TR3 Overdrive to transmission mating problem Triumph 8
R TR2/3/3A TR2/TR3 transmission dip stick access Triumph 10
T TR2/3/3A Will Spitfire D-type overdrive work in TR3 with TR4 transmission? Triumph 3
R TR2/3/3A TR3 A Transmission rebuild Triumph 5
charleyf TR2/3/3A Transmission numbers on a TR3 Triumph 7
Scotsman TR2/3/3A HVDA transmission conversion. 90* speedometer cable adapter may be required on TR3's Triumph 4
JFeher TR2/3/3A Has anyone installed a TR6 OD transmission in their TR3? Triumph 8
T TR4/4A I'm back to the well of knowledge - TR3/TR4/TR4A clutch-transmission confusuion Triumph 10
P TR2/3/3A TR3 Transmission oil Triumph 13
T TR2/3/3A Is CT52431 a TR3 Transmission serial ? Triumph 4
T TR2/3/3A What weight gear oil to use in TR3 transmission? Triumph 23
Russ Austin TR2/3/3A TR3 Transmission Installation Hints / Tips Please! Triumph 14
Russ Austin TR2/3/3A TR3 Transmission question Triumph 8
mgbmedic TR2/3/3A TR3 Transmission Tunnel Triumph 8
RedTR3 TR2/3/3A TR3 Transmission Differences Triumph 27
RedTR3 TR2/3/3A Removing TR3 OD transmission Triumph 5
M TR2/3/3A Draining and refilling TR3 transmission with OD Triumph 23
M TR2/3/3A Metal transmission cover color for TR3 ??? Triumph 9
T TR2/3/3A TR3 transmission cover - supposed to be metal? Triumph 5
Moseso TR2/3/3A TR3 Transmission noises Triumph 11
K TR2/3/3A Toyota transmission for TR3=long distance driving Triumph 13
CCURTISS TR2/3/3A TR3 Transmission Tunnel Sealant Triumph 7
CCURTISS TR2/3/3A TR3 Transmission Questions Triumph 14
B TR2/3/3A tr3 transmission oil fill plug Triumph 18
White79MGB TR2/3/3A TR3 Transmission Oil Triumph 18
hondo402000 TR6 TR3 VS TR6 Transmission units Triumph 6
gubba TR2/3/3A TR3 B 5 speed Transmission conversion Triumph 0
S TR2/3/3A tr3 transmission Triumph 2
S TR2/3/3A tr3 transmission front seal Triumph 3
mcguijo TR2/3/3A TR3 Transmission Blues Triumph 16
jsneddon TR2/3/3A TR3 Transmission Oil Capacity Triumph 3
S TR2/3/3A Tr3 transmission oil Triumph 4
T TR2/3/3A Hole in transmission bellhousing TR3!!!! Triumph 5
T TR2/3/3A Proper oil TR3 Transmission Triumph 3
R TR2/3/3A TR3 Timminge Triumph 11
J For Sale Triumph TR2 TR3 rocker panels, right and left Triumph Classifieds 0
J SOLD!! Triumph TR2 TR3 Channel - Drip - Rear Edge Triumph Classifieds 1
J For Sale TR2 TR3 Tie Member Triumph Classifieds 0
S TR2/3/3A tr3 valve spring compressor Triumph 5
