    BCF is a FREE resource for the Little British Car community. I just did a little math and found that less than 1% of the registered members appreciate this forum enough to support us with an account upgrade. We do not "require" you to pay to play here, but if you find BCF helpful, appreciate no pop up ads, and want to ensure we stay online - Consider supporting us with an "optional" low-cost member upgrade. There are some benefits to upgrading!
Transmission tunnel removal
nevets
I need to remove the transmission tunnel on my BN6 in order to do some OD troubleshooting. It's a fiberglass tunnel and so far I removed all the screws from the tunnel flange that screw down into the floor/chassis. I am assuming there is also a flange that screws into the bulkhead (see attached pics). One issue I am having is that the carpet on the tunnel trims very neatly where it meets the bulkhead and I am concerned about causing damage to the interior. I'm guessing that if I peel back the carpeting on the bulkhead, I will expose the tunnel flange and gain access to the screws? And hopefully everything will go back neatly.
A related issue is that after I removed all the screws from the floor attachment, I figured the tunnel would be loosened somewhat and I would be able to lift the tunnel slightly. I even tried prying it up from underneath the car and it does not move. Is it possible that the restorer glued the tunnel to the chassis /floor?
Any advice would be greatly appreciated.
Thanks,
Steve
YEP ,But it might take just a wee bit of ahesive to make it lay smooth again.
Hi Steve
from your FIRST photo ___ It appear (to me) to be riveted to the floor /If I see correctly NOW you can drill the rivets and then sobst. it with screws
GLUE the steel is not impossible but very hard to do, and a very strange application
On this Google album https://picasaweb.google.com/112770819864514987162/BN4LongbridgeCARPETSAndINSULATION
you can find the sistem normaly (screw inox is better 6or8 on floor and 3 on sheed) used to fit the tunnel on floor / but it can vary by the restorer preference
example I have prefered the VELCRO strips at gluing the carpets on tunneln and do a window for the gearbox OIL STICK
your carpet appear correctly applied use care in the removing
Yes, there are screws along the bulkhead flange. Hopefully you can gently peel the carpet back enough to get to them....
In my car, the carpet piece covering the removable tunnel was tucked very tightly, and quite far along, under the piece covering the rear (fixed) tunnel, and it took quite a bit of grunt to get things moving. I know some people do put caulk around the base of the tunnel too, which may be sticking.
FWIW, I have a metal tunnel that, I'm guessing, was reworked a bit during restoration. My challenge is always figuring out the pub/bar puzzle of how to get the tunnel out without removing the parking brake assembly. (Start lifting with the transmission in 1st gear, clear the parking brake, rotate 90 degrees, select 4th gear, slide back, et cetera, et cetera.)
Thanks for the info, and yes andrea, the carpet is correctly applied and looks very neat (KT restoration) so I will try to be careful...and thanks for the link with the useful photos.
M Transmission tunnel removal Triumph 14
Sprocket BJ-7 Transmission Tunnel Removal Austin Healey 5
EWD TR6 Transmission tunnel insulation Triumph 6
T TR2/3/3A Transmission Tunnel Configuration Triumph 11
S Jute Installation on Transmission Tunnel - Heritage Trim Austin Healey 9
J TR2/3/3A Transmission tunnel gasket? Triumph 16
F Seal between transmission tunnel and the forward bulkhead Austin Healey 7
MikeAH100M Transmission Tunnel Install - BN2 Austin Healey 2
P Mysteries under the BJ8 transmission tunnel, speedometer cable, overdrive and gerabox Austin Healey 1
B TR2/3/3A Beat my transmission tunnel to death? Triumph 12
T TR4/4A Cutting an access panel into transmission tunnel cover for solenoid adjustment Triumph 13
nevets Removing carpet from transmission tunnel Austin Healey 15
F TR4/4A TR4 shifter and transmission tunnel Triumph 4
mgbmedic TR2/3/3A TR3 Transmission Tunnel Triumph 8
eschneider Spitfire Spitfire ABS transmission tunnel cover - worth it? Triumph 10
chicken how do you secure the transmission tunnel down ? Austin Healey 19
J Transmission Tunnel Cover - BN7 Austin Healey 10
C Transmission tunnel carpet Austin Healey 2
CCURTISS TR2/3/3A TR3 Transmission Tunnel Sealant Triumph 7
Ed_K Don't use RTV to seal the transmission tunnel Austin Healey 28
DNK Transmission Tunnel Lamp Triumph 0
S Transmission Tunnel Seal Austin Healey 3
vette Transmission Tunnel Seal Austin Healey 7
L Early B transmission tunnel cover needed MG 8
S Transmission Tunnel Austin Healey 5
S For Sale FREE - TR3 engine and transmission Triumph Classifieds 0
Jim_Gruber Correct Transmission Oil for Datsun 210 5-speed Spridgets 1
mctriumph SOLD!! Tr7/ Tr8 transmission Triumph Classifieds 0
C TR6 Transmission Number Meaning Triumph 5
R 100-4 Transmission Austin Healey 1
J TR4/4A TR4A automatic transmission conversion Triumph 6
Popeye TR4/4A Transmission noise - intermittent Triumph 22
D XK150 Transmission Input Shaft Jaguar 1
A TR2 Transmission overhaul Restoration & Tools 0
E General MG Transmission Fluid Level MG 2
B Transmission Gear Lockouts Austin Healey 8
K Putting a Getrag 5 speed OD transmission in a Jaguar Mkll ? Jaguar 4
AUSMHLY Transmission Noise Austin Healey 11
KVH General TR Transmission Problem Triumph 3
T Looking for "BillMs rear transmission mount" Spridgets 2
T For Sale Excellent Original 1968 TR250 Frame with Engine & Transmission Triumph Classifieds 6
D TR2/3/3A Torque for bolts back of transmission ? Pl Triumph 0
bighealeysource Side-Shift Transmission Austin Healey 13
D transmission conversion Other British Cars 1
PAUL161 T-Series Original transmission sold MG 2
KVH TR4/4A Assembling Transmission to Engine--Vice/Versa Triumph 4
BritBite Transmission Repair Austin Healey 8
