Ignition timing question
Lin
As one begins the ignition timing process, the workshop manual states: “ Set the micrometer adjustment on the distributor in its central position.” So, how do you know when you are at the central position?
Thanks.
Lin
Wind it fully one way, then wind it fully the other, counting the turns. Then wind it in the original direction, for half the turns.
M Another Ignition Timing Question Austin Healey 8
A Rookie Ignition Timing Question - Micrometer Adj? Austin Healey 8
txtr3 basic ignition timing question Triumph 3
E Ignition Timing Austin Healey 14
K TR2/3/3A Ignition timing questions while I'm waiting for Spring Triumph 27
Lin Checking static timing for a 1275 with Crane XR700 ignition Spridgets 0
K TR2/3/3A Ignition Timing? Triumph 11
D BT7 ignition timing Austin Healey 5
F TR2/3/3A Ignition Timing - Again Triumph 11
F TR2/3/3A Timing with Electronic Ignition Triumph 14
Jagguy MGB Ignition timing issues....I'm getting confused! MG 16
Lutz Kramer Ignition timing with Pertronix Ignitor and strobe light Austin Healey 67
R Ignition Timing Issue, Phase II Austin Healey 8
R Ignition Timing Issue Austin Healey 37
K TR2/3/3A Setting ignition timing to 4 degrees BTDC? Triumph 1
S Ignition timing - I can't get less than 12 deg at idle Austin Healey 7
K TR2/3/3A Setting ignition timing at 8 degrees BTDC instead of 4? Triumph 9
sundown TR6 ignition timing Triumph 10
C Static Ignition Timing Austin Healey 1
I Bugeye 948 ignition timing help please Spridgets 8
Bruce Bowker ignition timing mark Austin Healey 5
glemon Never Assume [Ignition Timing] MG 1
MGTF1250Dave TR2/3/3A TR3 Static Timing with Pertronix Ignition Triumph 5
S TR6 Ignition timing on TR6 Triumph 3
R TR6 Ignition timing on '72 TR6 Triumph 14
T static timing with electronic ignition? Triumph 10
AltaKnight Ignition timing Triumph 19
H Ignition timing Austin Healey 1
T MGB Static timing a MGB w/ a Crane Electronic Ignition MG 5
10musketeer Confused with starting/ignition/timing Spridgets 63
L Spitfire Ignition Timing for my Spit 1500... Triumph 12
O MGB MGB Ignition Timing MG 7
B ignition timing? Austin Healey 7
I Ignition timing help Triumph 22
D BJ 8 Ignition timing Austin Healey 5
I ignition timing n stuff Spridgets 12
P TR4/4A Ignition Timing Adjustment on a TR4A ? Triumph 13
SCguy TR6 Ignition Timing with a timing light on a a TR6 Triumph 16
Earl TR2/3/3A TR3 Ignition Timing Triumph 8
AltaKnight TR6 TR6 ignition timing Triumph 6
B Dynamic Ignition timing BN1 Austin Healey 5
H Ignition timing and pinging Austin Healey 1
bluemiata90 TR4/4A TR4 ignition timing Triumph 6
MGTF1250Dave TR2/3/3A TR3 Ignition Timing Help Triumph 12
rovernut MGB MGB ignition timing MG 1
Y Fundamentals of ignition timing Spridgets 1
K Ignition timing woes - PLEASE HELP! Austin Healey 8
R Pertronix ignition and static timing MG 22
M How Do I Set Timing On 1990 Marelli Ignition V12 after reinstalling distributor ? Jaguar 0
R TR6 Crazy Ignition Failure in TR6 engine… Triumph 7
