BJ 8 Ignition timing
DavidThorn
Having problems with igntion timing on my car. If timing is set correctly with stobe light car lacks power and returns about 18 to the gallon but runs sweetly at tickover and can be slowed down to about 600 revs. Advancing the ignition by about 10 degrees makes the car run much better under load and returns 24 to the gallon - but tickover is uneven and lumpy and will not slow to below 1000 rpm. Any ideas a friend looked at the distributor and felt that it was not badley worn. The vacum on the adavance and retard seems to be holding (tested by sucking on the pipe). I suspect that the springs may be to weak (or perhaps to strong) Anyone any ideas?
What degree advance are you setting initially with the
engine at idle and the vacuum disconnected.???-Keoke
David,
most likely the mechanical advance mechanism is not working the way it should, as suspected by you. I guess that the springs were worn and replaced by the PO, maybe with springs that don't have the proper rates due to lack of originals.
If you are tired of fiddling with your distributor, check this out. I have put it in my car and it's a dream. Car runs smooth when idling and under load due to spark balancing. I got a 10% better mileage out of it, although I had previously replaced the worn, original distributor by a Mallory unit with Pertronix ignitor (pointless ignition system). Plus you don't have to worry about spares. Cap and rotor are standard Bosch items (recommended to be replaced every 20,000 miles) with the only moving parts being the shaft and the rotor. Everything works electronically, even the vacuum is measured electronically and you can select between 16 different advance curves via a switch. Though the look is still classic.
If you need one, contact me.
Try the factory setting of 15 degrees BTDC at 600 rpm with the vacuum disconnected to get started. Then check what the maximum advance is when revved. Should be 35 degrees BTDC.
Cheers,
John
Yes Have now set it to that - in fact that is not far off the setting I had guessed to in the first place. It seems to be running much sweeter on tick over,which I had to slow down considerably that aunfortunate sucking (induction )noise has also gone.It seems to pull well also . Will report back on fuel consumption.
E Ignition Timing Austin Healey 14
K TR2/3/3A Ignition timing questions while I'm waiting for Spring Triumph 27
Lin Ignition timing question Spridgets 2
Lin Checking static timing for a 1275 with Crane XR700 ignition Spridgets 0
K TR2/3/3A Ignition Timing? Triumph 11
D BT7 ignition timing Austin Healey 5
F TR2/3/3A Ignition Timing - Again Triumph 11
F TR2/3/3A Timing with Electronic Ignition Triumph 14
Jagguy MGB Ignition timing issues....I'm getting confused! MG 16
Lutz Kramer Ignition timing with Pertronix Ignitor and strobe light Austin Healey 67
R Ignition Timing Issue, Phase II Austin Healey 8
R Ignition Timing Issue Austin Healey 37
K TR2/3/3A Setting ignition timing to 4 degrees BTDC? Triumph 1
S Ignition timing - I can't get less than 12 deg at idle Austin Healey 7
K TR2/3/3A Setting ignition timing at 8 degrees BTDC instead of 4? Triumph 9
sundown TR6 ignition timing Triumph 10
C Static Ignition Timing Austin Healey 1
I Bugeye 948 ignition timing help please Spridgets 8
Bruce Bowker ignition timing mark Austin Healey 5
glemon Never Assume [Ignition Timing] MG 1
MGTF1250Dave TR2/3/3A TR3 Static Timing with Pertronix Ignition Triumph 5
S TR6 Ignition timing on TR6 Triumph 3
R TR6 Ignition timing on '72 TR6 Triumph 14
T static timing with electronic ignition? Triumph 10
M Another Ignition Timing Question Austin Healey 8
AltaKnight Ignition timing Triumph 19
H Ignition timing Austin Healey 1
T MGB Static timing a MGB w/ a Crane Electronic Ignition MG 5
10musketeer Confused with starting/ignition/timing Spridgets 63
L Spitfire Ignition Timing for my Spit 1500... Triumph 12
O MGB MGB Ignition Timing MG 7
B ignition timing? Austin Healey 7
I Ignition timing help Triumph 22
I ignition timing n stuff Spridgets 12
P TR4/4A Ignition Timing Adjustment on a TR4A ? Triumph 13
A Rookie Ignition Timing Question - Micrometer Adj? Austin Healey 8
SCguy TR6 Ignition Timing with a timing light on a a TR6 Triumph 16
Earl TR2/3/3A TR3 Ignition Timing Triumph 8
AltaKnight TR6 TR6 ignition timing Triumph 6
B Dynamic Ignition timing BN1 Austin Healey 5
H Ignition timing and pinging Austin Healey 1
txtr3 basic ignition timing question Triumph 3
bluemiata90 TR4/4A TR4 ignition timing Triumph 6
MGTF1250Dave TR2/3/3A TR3 Ignition Timing Help Triumph 12
rovernut MGB MGB ignition timing MG 1
Y Fundamentals of ignition timing Spridgets 1
K Ignition timing woes - PLEASE HELP! Austin Healey 8
R Pertronix ignition and static timing MG 22
M How Do I Set Timing On 1990 Marelli Ignition V12 after reinstalling distributor ? Jaguar 0
