Ignition timing
higgins
OK guys, I've read almost everything posted here on setting timing. /bcforum/images/%%GRAEMLIN_URL%%/thumbsup.gif
There still remains something I am still not clear on.
The fact sheet for my 100/6 BN4 Longbridge model states <u>static</u> timing 6° BTDC.
Later models state <u>dynamic</u> timing 15° BTDC
/bcforum/images/%%GRAEMLIN_URL%%/confused.gif /bcforum/images/%%GRAEMLIN_URL%%/crazy.gif
How is 6° static timing set or have I misunderstood something along the line /bcforum/images/%%GRAEMLIN_URL%%/frown.gif
I have a standard strobe light without dial.
Question: The notch should be painted white, or black, or lipstick gloss, or whatever.
You've also mentioned in the past to place a mark for 15° 1/2" on both side of the notch.
Unfortunately, what I am not quite clear on is, when I set the dynamic timing, does this mean that the notch has to line up with the pointer or that the 1/2" mark has to line up when turning the distributor?
I am able to set static timing with the little 12 volt bulb, I now want to go a step further and be able to understand exactly how it works.
Cheers /bcforum/images/%%GRAEMLIN_URL%%/cheers.gif
Lets see, Static timing is setting the timing with the engine turned off and requires only an inexpensive test lamp. Dynamic timing is setting the ignition timing with the engine running and using a timing light. I usually use a dynamic setting of 12-15 degree BTDC. A timing light with a dial aids adjustment because you set the dial and just look for pointer and 0 to line up on the crank. Static is usually used just to set the initial adjustment.
HTH
E Ignition Timing Austin Healey 14
K TR2/3/3A Ignition timing questions while I'm waiting for Spring Triumph 27
Lin Ignition timing question Spridgets 2
Lin Checking static timing for a 1275 with Crane XR700 ignition Spridgets 0
K TR2/3/3A Ignition Timing? Triumph 11
D BT7 ignition timing Austin Healey 5
F TR2/3/3A Ignition Timing - Again Triumph 11
F TR2/3/3A Timing with Electronic Ignition Triumph 14
Jagguy MGB Ignition timing issues....I'm getting confused! MG 16
Lutz Kramer Ignition timing with Pertronix Ignitor and strobe light Austin Healey 67
R Ignition Timing Issue, Phase II Austin Healey 8
R Ignition Timing Issue Austin Healey 37
K TR2/3/3A Setting ignition timing to 4 degrees BTDC? Triumph 1
S Ignition timing - I can't get less than 12 deg at idle Austin Healey 7
K TR2/3/3A Setting ignition timing at 8 degrees BTDC instead of 4? Triumph 9
sundown TR6 ignition timing Triumph 10
C Static Ignition Timing Austin Healey 1
I Bugeye 948 ignition timing help please Spridgets 8
Bruce Bowker ignition timing mark Austin Healey 5
glemon Never Assume [Ignition Timing] MG 1
MGTF1250Dave TR2/3/3A TR3 Static Timing with Pertronix Ignition Triumph 5
S TR6 Ignition timing on TR6 Triumph 3
R TR6 Ignition timing on '72 TR6 Triumph 14
T static timing with electronic ignition? Triumph 10
M Another Ignition Timing Question Austin Healey 8
AltaKnight Ignition timing Triumph 19
T MGB Static timing a MGB w/ a Crane Electronic Ignition MG 5
10musketeer Confused with starting/ignition/timing Spridgets 63
L Spitfire Ignition Timing for my Spit 1500... Triumph 12
O MGB MGB Ignition Timing MG 7
B ignition timing? Austin Healey 7
I Ignition timing help Triumph 22
D BJ 8 Ignition timing Austin Healey 5
I ignition timing n stuff Spridgets 12
P TR4/4A Ignition Timing Adjustment on a TR4A ? Triumph 13
A Rookie Ignition Timing Question - Micrometer Adj? Austin Healey 8
SCguy TR6 Ignition Timing with a timing light on a a TR6 Triumph 16
Earl TR2/3/3A TR3 Ignition Timing Triumph 8
AltaKnight TR6 TR6 ignition timing Triumph 6
B Dynamic Ignition timing BN1 Austin Healey 5
H Ignition timing and pinging Austin Healey 1
txtr3 basic ignition timing question Triumph 3
bluemiata90 TR4/4A TR4 ignition timing Triumph 6
MGTF1250Dave TR2/3/3A TR3 Ignition Timing Help Triumph 12
rovernut MGB MGB ignition timing MG 1
Y Fundamentals of ignition timing Spridgets 1
K Ignition timing woes - PLEASE HELP! Austin Healey 8
R Pertronix ignition and static timing MG 22
M How Do I Set Timing On 1990 Marelli Ignition V12 after reinstalling distributor ? Jaguar 0
