MGB MGB Ignition Timing
Can anyone tell me how much I should retard (or advance) my ignition timing to reduce run on after I turn off the switch? I have a '70 B/GT, European model, although I don't think it has a high compression engine. I have static timed to about 8 degrees BTDC, using 93 octane unleaded. Run on after shut down is too much. I picked up at Craftsman timing light with variable advance, but I'm not sure what I should dial in. Thanks for your help.
My 72 is set at +15 degrees, vac advance disconnected and hose plugged while setting. Hook up after. It runs great!
8 degrees should be about textbook.
15 degrees is good for performance, and good to know you should be able to go that high.
If you are running twin SU's and still having issues after timing, check carb synchronization. If you're running a weber downdraft, your decel valve might be leaking.
just some thoughts.
Thanks for the suggestions. Carbs are synched, points are properly gapped, plugs are clean. Found a plug wire that had touched a metal cable and burned through the insulation. That could be a problem, but it isn't missing at lower RPM. The car has about 50,000 miles on the original distributor. Is that about time to replace, assuming it wasn't properly lubricated before? The 3500 mark makes me think that the vacuum advance isn't working. I pulled the advance to time it, plugged it and replaced it when I finished. Can't figure anything other than distributor wear (just had to be the most expensive item, didn't it).
You can test to see if the vacuum advance is working by sucking on the end of the line connecting to the unit--it should hold a vacuum. My distributor's vacuum and mechanical advance weren't working, and I had the whole unit rebuilt by Jeff at AdvancedDistributors.com (on the advice of people from this forum). It works and looks great now, and I didn't feel it was that expensive to have done.
The problem I had that prompted it, however, wasn't run on but misfire at speed. It's a 74 MGB with a downdraft weber, I'm running at 15 deg. BTDC.
100-6, at what rpm's did you adjust your timing? I have a 74b with 32/36 Weber and have been playing around with timing to get rid of stumble on initial tip in.
Trey
Actually, tdecell, I set it at 15 degrees static timing, but the car still has a very noticeable stumble; I got a nice timing light, so I'm going to set the timing and will tell you what I used and if it solved the problem.
[ QUOTE ]
[/ QUOTE ]
Perhaps more importantly, while sucking on the hose, make sure the advance plate is actually <u>moving</u> . Just because the diaphragm holds vacuum doesn't meen that the advance plate isn't frozen in place.
Jeff
T MGB Static timing a MGB w/ a Crane Electronic Ignition MG 5
rovernut MGB MGB ignition timing MG 1
TRickster6 MGB electronic ignition on '73 MGB MG 1
H MGB 1980 mgb no power from ignition switch MG 23
Y MGB 1977 MGB Ignition Coil and Wiring. MG 7
F MGB '76 MGB ignition trouble MG 62
M Advancing ignition for MGB MG 12
D T-Series Access to ignition switch '68 MGB MG 9
mikecyc72usa MGB 71 MGB ignition lock core removal MG 3
Sebring222 T-Series 74 CB MGB Ignition Switch MG 17
N MGB Question about ignition wiring unique to 1980 MGB MG 15
A MGB trying to locate the ignition relay on a 1977 mgb MG 4
vette MGB MGB Electronic Ignition MG 2
C T-Series 1977 MGB ignition switch MG 4
EMGEBE MGB MGB Ignition question MG 9
B MGB replacing 1976 MGB ignition MG 1
M T-Series 1974 mgb ignition switch/lock w/harness MG 10
Carlbanan56 MGB MGB valve seals MG 1
M MGB 1967 MGB starter conversion MG 9
CJ Burton MGB-GT Bolts for INERTIA STARTER on 1966 MGB GT MG 8
M MGB Ground polarity '67 MGB MG 2
M For Sale 1978 MGB MG Classifieds 0
Carlbanan56 MGB MGB oil consumption MG 5
ab-1970mgb Wanted 1970 MGB - Emissions Parts MG Classifieds 4
C MGB Re strapping a MGB seat bottom MG 2
Simmo MGB Re Engined MGB MG 4
Carlbanan56 MGB MGB rear break rebuild MG 6
C Wanted Early MGB soft top and/or tonneaus, condition not very important MG Classifieds 0
Carlbanan56 MGB Mgb turn signals MG 17
J MGB 1970 MGB Steering Lubrication MG 1
C Wanted Wanted: 1977 to 1980 MGB Dashboard MG Classifieds 0
L SOLD!! For Sale MGB Hardtop MG Classifieds 3
EvansClassicCars For Sale 1980 MGB for sale MG Classifieds 0
J MGB Tire pressure for 1980 MGB MG 14
5 Wanted Wanted 1966 mgb banjo type axle rear hub MG Classifieds 0
I MGB Purchase of 1972 MGB Roadster MG 3
C MGB-GT MGB-GT Front Ride Height MG 0
J MGB Advice for new MGB owner? MG 16
D Wanted Wanted: Chicklet Headrests for MGB/C! MG Classifieds 0
Editor_Reid MGB Anders Clausager's "MGB" book MG 4
J MGB 1966 MGB won't start MG 1
Erica General MG Oil Drain Valve -- mine is an MGB, but they have others MG 3
TunaJ Will MGB Upper Seat Runners work with Midget seat rails? Spridgets 1
Erica MGB Carburetion and MGB fuel economy. MG 0
wkilleffer MGB MGB clutch slave bleed driving me nuts MG 38
R MGB side chrome installation MG 4
C MGB MGB MG 5
3798j Off Topic MGB at the Drive in Bank MG 1
wkilleffer MGB 1974 MGB clutch master cylinder questions MG 1
Rut MGB 62-67 upper MGB steering shaft MG 3
