Ignition timing and pinging
healey_100_s
Hi All
It appears the distributor on my 100 ( still in possession )has slipped a little and I now have pinging/knocking/pinking...whatever you may want to call it, on heavy throttle. Idle is OK.
My questions are.
1. Is is running too retarded.
2. Which way do I turn the distributor to advance ie clockwise or anti clockwise.
ie -
to advance turn ??
to retard turn ??
Thanks
Dimitri
HI Dimitri, go to the MG Forum here and read"Help Pleese" good info there on your problem.---Fwiw--Keoke
E Ignition Timing Austin Healey 14
K TR2/3/3A Ignition timing questions while I'm waiting for Spring Triumph 27
Lin Ignition timing question Spridgets 2
Lin Checking static timing for a 1275 with Crane XR700 ignition Spridgets 0
K TR2/3/3A Ignition Timing? Triumph 11
D BT7 ignition timing Austin Healey 5
F TR2/3/3A Ignition Timing - Again Triumph 11
F TR2/3/3A Timing with Electronic Ignition Triumph 14
Jagguy MGB Ignition timing issues....I'm getting confused! MG 16
Lutz Kramer Ignition timing with Pertronix Ignitor and strobe light Austin Healey 67
R Ignition Timing Issue, Phase II Austin Healey 8
R Ignition Timing Issue Austin Healey 37
K TR2/3/3A Setting ignition timing to 4 degrees BTDC? Triumph 1
S Ignition timing - I can't get less than 12 deg at idle Austin Healey 7
K TR2/3/3A Setting ignition timing at 8 degrees BTDC instead of 4? Triumph 9
sundown TR6 ignition timing Triumph 10
C Static Ignition Timing Austin Healey 1
I Bugeye 948 ignition timing help please Spridgets 8
Bruce Bowker ignition timing mark Austin Healey 5
glemon Never Assume [Ignition Timing] MG 1
MGTF1250Dave TR2/3/3A TR3 Static Timing with Pertronix Ignition Triumph 5
S TR6 Ignition timing on TR6 Triumph 3
R TR6 Ignition timing on '72 TR6 Triumph 14
T static timing with electronic ignition? Triumph 10
M Another Ignition Timing Question Austin Healey 8
AltaKnight Ignition timing Triumph 19
H Ignition timing Austin Healey 1
T MGB Static timing a MGB w/ a Crane Electronic Ignition MG 5
10musketeer Confused with starting/ignition/timing Spridgets 63
L Spitfire Ignition Timing for my Spit 1500... Triumph 12
O MGB MGB Ignition Timing MG 7
B ignition timing? Austin Healey 7
I Ignition timing help Triumph 22
D BJ 8 Ignition timing Austin Healey 5
I ignition timing n stuff Spridgets 12
P TR4/4A Ignition Timing Adjustment on a TR4A ? Triumph 13
A Rookie Ignition Timing Question - Micrometer Adj? Austin Healey 8
SCguy TR6 Ignition Timing with a timing light on a a TR6 Triumph 16
Earl TR2/3/3A TR3 Ignition Timing Triumph 8
AltaKnight TR6 TR6 ignition timing Triumph 6
B Dynamic Ignition timing BN1 Austin Healey 5
txtr3 basic ignition timing question Triumph 3
bluemiata90 TR4/4A TR4 ignition timing Triumph 6
MGTF1250Dave TR2/3/3A TR3 Ignition Timing Help Triumph 12
rovernut MGB MGB ignition timing MG 1
Y Fundamentals of ignition timing Spridgets 1
K Ignition timing woes - PLEASE HELP! Austin Healey 8
R Pertronix ignition and static timing MG 22
M How Do I Set Timing On 1990 Marelli Ignition V12 after reinstalling distributor ? Jaguar 0
