ignition timing mark
Bruce Bowker
On my BN2, the 3 pointer indicator is missing. I am assuming this attaches to the lower front cover bolt.
1) Is that correct
2) Anyone have one sitting around for sale?
Thanks
Bruce
Not sure what the '3 pointer indicator is.' Our BN2 (100M) has an embossed arrow on the timing cover, which points to a small hole in the crankshaft pulley at TDC/1.
Nice collection of cars, BTW.
Bruce Bowker
Bruce Bowker
Bob - thanks. More investigation seems like there is not any indicator as a separate piece.
When you say "hole" do you mean more like a notch or what one might call a filed out line across the pully edge. Hard to explain but I do have a notch in the pully.
Where abouts is the embossed arrow - left side, right side, towards the top etc?
Thanks
Bruce
Healeysince59
Bruce,
Mine has a small hole just away from the edge. I filed a notch on the edge and added a dab or white paint to make it more visible. I have one timing cover with a stamped arrow and another with no mark at all.
Marv J
Bruce Bowker
Bruce Bowker
Found it with help from you all.
Thanks very much.
Bruce
musme
My BN2 cover has an arrow stamped. What I will do is put some white nail polish and works great for timing purposes...!!!!
If you are going to put one of course you will need to have the exact location in order to have TDC....
If you need a picture... my cover with the arrow is sitting of a shelf so it is very simple to take a picture. let me know jvvmusme at yahoo.com
Jose
E Ignition Timing Austin Healey 14
K TR2/3/3A Ignition timing questions while I'm waiting for Spring Triumph 27
Lin Ignition timing question Spridgets 2
Lin Checking static timing for a 1275 with Crane XR700 ignition Spridgets 0
K TR2/3/3A Ignition Timing? Triumph 11
D BT7 ignition timing Austin Healey 5
F TR2/3/3A Ignition Timing - Again Triumph 11
F TR2/3/3A Timing with Electronic Ignition Triumph 14
Jagguy MGB Ignition timing issues....I'm getting confused! MG 16
Lutz Kramer Ignition timing with Pertronix Ignitor and strobe light Austin Healey 67
R Ignition Timing Issue, Phase II Austin Healey 8
R Ignition Timing Issue Austin Healey 37
K TR2/3/3A Setting ignition timing to 4 degrees BTDC? Triumph 1
S Ignition timing - I can't get less than 12 deg at idle Austin Healey 7
K TR2/3/3A Setting ignition timing at 8 degrees BTDC instead of 4? Triumph 9
sundown TR6 ignition timing Triumph 10
C Static Ignition Timing Austin Healey 1
I Bugeye 948 ignition timing help please Spridgets 8
glemon Never Assume [Ignition Timing] MG 1
MGTF1250Dave TR2/3/3A TR3 Static Timing with Pertronix Ignition Triumph 5
S TR6 Ignition timing on TR6 Triumph 3
R TR6 Ignition timing on '72 TR6 Triumph 14
T static timing with electronic ignition? Triumph 10
M Another Ignition Timing Question Austin Healey 8
AltaKnight Ignition timing Triumph 19
H Ignition timing Austin Healey 1
T MGB Static timing a MGB w/ a Crane Electronic Ignition MG 5
10musketeer Confused with starting/ignition/timing Spridgets 63
L Spitfire Ignition Timing for my Spit 1500... Triumph 12
O MGB MGB Ignition Timing MG 7
B ignition timing? Austin Healey 7
I Ignition timing help Triumph 22
D BJ 8 Ignition timing Austin Healey 5
I ignition timing n stuff Spridgets 12
P TR4/4A Ignition Timing Adjustment on a TR4A ? Triumph 13
A Rookie Ignition Timing Question - Micrometer Adj? Austin Healey 8
SCguy TR6 Ignition Timing with a timing light on a a TR6 Triumph 16
Earl TR2/3/3A TR3 Ignition Timing Triumph 8
AltaKnight TR6 TR6 ignition timing Triumph 6
B Dynamic Ignition timing BN1 Austin Healey 5
H Ignition timing and pinging Austin Healey 1
txtr3 basic ignition timing question Triumph 3
bluemiata90 TR4/4A TR4 ignition timing Triumph 6
MGTF1250Dave TR2/3/3A TR3 Ignition Timing Help Triumph 12
rovernut MGB MGB ignition timing MG 1
Y Fundamentals of ignition timing Spridgets 1
K Ignition timing woes - PLEASE HELP! Austin Healey 8
R Pertronix ignition and static timing MG 22
M How Do I Set Timing On 1990 Marelli Ignition V12 after reinstalling distributor ? Jaguar 0
