idling problem
jarrod
My boss has a 1978 jag xjs v12. He says that at idle it will rev up then drop back down to idle speed then rev again. It does this continuously. Note: I'm not doing this for my boss (he left the poor girl in a barn until the interior was covered in mold) But he might sell the car to me cheap and I want to know what will fix it. hee hee hee /ubbthreads/images/graemlins/devilgrin.gif
maynard
It might be as simple as the butterflies being out of adjustment. Disconnect the rods, clean the throttle bodies, and set them to .002.
John S Farrington
This cycling at idle speed is caused by the of the ECU being signaled that the car is coasting at slow speeds and the logic unit then cuts off the gasoline to the fuel injectors in an effort to save gas during coasting in gear. when the idle speed drops to normal the cycle then starts again and the idle speed again goes up. Either your butterfly valves are out of adjustment causing a fast idle or the micro switch at the throttle cable is out of adjustment therefore signaling the ECU that the car is coasting. The units should be checked for adjustment. Also throttle linkages on either side of the engine having loose joints or connections might cause this response. I think that the XJS collection of technial tips, etc., under the Jaguar Lovers Forum covers this phenomenum and the adjustment remedies. Hope this steers you to the solution.
Exotexs
I've been dealing with my 1984 XJ-6 for the last 14 years; The same "idle hunting" symptom can be caused by the air intake hoses leaking air in any of the clamped connections as Jack mentioned, especially at the 90 degree hose to the throtle body/butterfly. a bad vacuum connection (vacuum leak) can also cause the "hunting" up and down. Sure, mine is not a 12 cylinder, but the symptom is the same. 12 cylinder engines are known to require new vacuum hoses frequently.
J
jarrod
thanx guys I'll tell him but he probably will sell it. He doesn't seem to want the cool cars he has anymore. Lucky me.
bcbennett Weird idling problem Triumph 3
bigbadbluetr6 TR6 TR6 idling problem Triumph 4
G Misfire After Prolonged Idling Austin Healey 16
EWD TR6 Idling Triumph 12
T TR4/4A TR4 Carburetors/Idling Triumph 3
KVH TR4/4A Three Questions: Distributors, Idling, Turn Signal Flasher Triumph 29
D smokes after idling Spridgets 2
B MGA mga engine [sounds like a deisel when idling?? MG 6
jerrybny TR6 TR6 Idling Problems Triumph 7
S Trouble with carb tuning, idling Spridgets 15
BigBird Idling too rich... MG 5
L Proper idling RPM MG 22
B BJ8 Idling very rough w/ odd sound - Now w/ VIDEO! Austin Healey 23
T Erratic idling v12 xjs Jaguar 2
P TR2/3/3A rough idling TR3B Triumph 13
K Why is my B engine idling at 2500? MG 1
T TR4/4A TR4 seat buffer problem Triumph 5
Carlbanan56 MGB High rpm problem MG 27
Sarastro TR4/4A Convertible top installation problem Triumph 12
J TR4/4A Strange Problem Fitting Inner Fender Triumph 18
B TR2/3/3A Possible differential problem Triumph 3
S Spitfire Triumph Spitfire 1300 engine SU carb problem Triumph 10
S Carb Problem Austin Healey 13
E Gearbox problem Other Cars 0
A Rivergate slave problem Spridgets 3
Govtslug TR6 Clutch Problem Triumph 21
Writer2022 GT6 GT6 MK3 Alternator Problem Triumph 4
M 1977 MG Midget 1500 Problem Spridgets 8
KVH General TR Transmission Problem Triumph 3
DrEntropy W123 Benz recurring problem Other Cars 16
J MGB Idle problem MG 4
tr6nitjulius TR6 TR6 No 1st/2nd problem/solution Triumph 4
Got_All_4 TR6 Throw Out Bearing Fork Problem Triumph 7
Got_All_4 TR6 2nd Gear Bush Problem TR6 Looking at Steel Triumph 12
E MGB MGB heater motor problem MG 3
K TR2/3/3A Another electrical problem: Park light & 5ignal light on Drivers side are brighter than....... Triumph 3
K TR2/3/3A Problem with the gear lever "anti rattle fix"..... Triumph 10
T TR2/3/3A Help - Cooling system problem Triumph 7
T TR2/3/3A TR3A Fuel Gauge problem Triumph 10
ROARRR Is there any problem swopping in a 3.0 in place of the 2.5 L engine in my Jag X Type? Jaguar 0
T General TR Cluthch problem / challenge Triumph 4
M Europa turn signal problem Lotus 7
T TR2/3/3A TR3A clutch problem Triumph 15
E TR2/3/3A Tr3 a clutch hydraulics problem, again. Triumph 16
S Engine or Tachometer Odd Problem Austin Healey 7
R TR2/3/3A TR3A Coil/condenser problem Triumph 22
G windscreen problem Spridgets 1
Hamish Racing TR2/3/3A Gearbox - can you spot the problem ? Triumph 17
