Weird idling problem
bcbennett
Hello all,
OK, when I start my TR6 in the garage and let it warm up, it idles great--right at 1200 rpm. As it gets really warm, it adjusts down to 1000.
However, when I take it for a 20-minute drive and bring it back to my garage, it will idle for about a minute at 1000, then start to dip down to 800, 700, and sputter down to die--even though the temp gauge is fine.
Could this be a fault in the temp regulator in my carbs?
DougF
Are you running the car on choke when it idles well at first or is 1200 a warm idle? Is your car stock with all the vaccuum lines etc. in place?
bcbennett
bcbennett
Hi Doug,
I pull the choke out, start her up, wait about 30 seconds, then choke it down fully. It runs at 1000/1200 when warm, fully choked.
Vacuum lines in place, but not emission equipment.
poolboy
I can think of a couple of things, but the first thing that comes to my mind is a Throttle Bypass Valve that is not closing when you come to an idle.
You'll see a small adjustment screw sticking out of the TBV assembly on the right side of the carbs. The next time the idle hangs up, press the screws with your fingers and see if that brings the idle down. It won't move much, less tha a 16th of an inch, but if you can manually close the valve by doing this then, either the diaphram surrounding the brass valve is shot or it needs more tension. You can increase the spring tension on the valve with a CounterClockwise turn or two of the screw.
Another thing to check, particularly since the emission stuff has been modified, is to be sure that the float chamber vent has not been capped off.
It is a brass nipple on the left side of the carbs, very close to the air filter housing.
If it has been capped off, the idle will definitly be affected whereas higher speeds will not be affected.
If that doesn't solve the problem please repost; we'll get to the bottom of it.
To answer your question about the Temperature Compensator, I really doubt it.
When the carbs are cold, the Temperature Compensator port is closed and all the air entering the carbs comes in from the "mouth" of the carbs. When the carb gets to about 100 degrees, the port in the Temp Comp is supposed to be fully open and a small amount of air will be allowed to flow thru a 1/4" diameter hole in the air box mounting flange into the carb's mixing chamber, leaning out the initial warm-up fuel/ air mixture, just that little bit. Not enough of an effect to cause what you describe.
EricJNewman MGB Weird Brake issue finally solved. MG 1
JPSmit Vauxhall question - I know, weird eh?! Lotus 6
Rob Glasgow Weird Lucas Headlight Austin Healey 7
H weird things painted by hand with a brush Austin Healey 6
Jim_Gruber Something weird electrically with Bugsy Spridgets 7
roscoe Distributor problem [a bit weird] Austin Healey 15
Rut MGB OK, I must attract weird MG 5
Rut MGB Weird oil question MG 3
P TR6 Another weird problem Triumph 6
V Weird Brake Issue Austin Healey 18
T TR4/4A Weird starting issue with my TR-4 Triumph 15
D Weird motor mount?? Spridgets 7
aeronca65t Weird things spotted......not cars Spotted 3
aeronca65t Weird Whatzit Spotted 2
Jim_Newman MSD Ignition and weird run-on Austin Healey 4
GBRandy Spot Free! - am I weird??? Triumph 10
rlich8 What was your weird problem today? Triumph 21
RickB Weird DPO wires heating up really hot Spridgets 16
Robert560 Weird "rough" idle problem after ignition changes. Austin Healey 18
Moseso Weird Hydraulic Failure Triumph 8
eschneider Weird oil leak? Triumph 12
I Weird indicators on BN1 Austin Healey 4
M Weird Happenings w/My Speedo Spridgets 2
bighealeysource engine running weird on my BN6 Austin Healey 6
AngliaGT Isn't it Weird ........ Other Cars 12
T weird oil leak - BJ7 - a question Austin Healey 4
P weird thing with midget clutch pedal Spridgets 3
jvandyke weird half top, soft targa? Spridgets 10
healeyboz another weird request Spridgets 1
Got_All_4 Weird R&R the turn signal switch and horn blows Triumph 8
G This may sound weird but.... Triumph 15
aeronca65t Tons of weird cars Other Cars 3
rlandrum Weird block holes Triumph 6
Raymond weird brake light problem MG 4
John Moore Weird Lug Nut Question Spridgets 9
Morris Weird Cooling Problems Spridgets 15
tony barnhill Today's Weird Question MG 57
Morris Weird paint question Spridgets 14
T Weird realization MG 2
aeronca65t Weird Brit Stuff Other British Cars 20
Mickey Richaud Well, This is Weird... Triumph 16
vping Weird fuel pump MG 13
B Weird Fuel Pump Issue MG 1
ronzet Hot Throttle Linkage [I've got a weird one...] Austin Healey 15
GregW Weird timing light readings Austin Healey 8
77MidgetMkIV Rough running at weird intervals-any thoughts? Spridgets 22
D Something weird with the idle/throttle Spridgets 23
Sherlock Weird Mini fastback in Australia [Mini Monaco?] British Motor Corp 22
tony barnhill Weird Little bug eye Spridgets 8
A How weird is this... MG 6
