Help on ball joint - vertical link fit
tdskip
Hi guys - having an issue on my TR4a IRS front suspension. Neither side ball joint is fitting properly on the vertical link. The new ball joints are not able to be tightened to fit flush with the top of the vertical link, which is screwing up my suspension geometry and would appear to be unsafe.
This one isn't fully tightened but I'm getting just very slightly less of a gap before you just cannot tighten them any more. I bought a replacement link from Marvin (thanks!) but am having the same fit issue.
I know / expect it will take some effort to snug it up so that isn't the issue.
I was thinking to <span style="text-decoration: underline">lightly</span> hone the opening on the vertical link to see that makes a difference.
Other ideas?
This is the spare link - it was powder coated but the opening was not.
Ball joint part #
T
tdskip
Update - the ball joints on the car have a pink band on the rubber that holds the seal on the post whereas the new ones have a blue band. Not sure that makes a difference.
Also - I pulled the rubber seal up to show how far down the ball joint post goes.
TR3driver
Great Pumpkin - R.I.P
Do the old joints fit properly?
KVH
I'm not sure anything is wrong. My old ones had a gap, and the new ones slightly larger--I think. But it's been driving great and no issues at all. Are you sure you're geometry is messed up. I got some faith Moss and the others know the clearances and proper seating. I would not hone that vertical link until you get to the clear bottom of the issues. If there's problem, I must have one two. That large gap is the first thing I noticed and it never occurred to me it was wrong--and that the seating of the lower wishbones would be impacted adversely. Curious.
T
tdskip
I wasn't smart enough to save them Randall. Yes, that was quite dumb. And yes, I am reminded of your point that the older parts are often better quality.
Lesson learned. Again.
T
tdskip
Hi KVH. The car is sitting high and I just got her to neutral camber, she was positive (excessively so). Was thinking that the ball joint not seating properly would contribute to that.
I am pretty sure everything else is correct, and she has her original springs. She does have poly bushings and spring packing, but I have that on the other cars without issue.
Edit - good to hear your 4a is driving great!
TR4nut
Well, I've got to admit that looks pretty unusual - can you tell where the threads end on the ball joint?
T
tdskip
Hi Randy - I get good thread coverage with the nut. I'm away from the car now but I'd guess a touch less than 1/4 inch of thread sticking down.
I did notice the ball joint boot will stick up toward the body of the ball joint if you push it up.
I guess the basic question is what gap should there be between the link top and bottom of the ball joint?
HerronScott
Tom,
Just a couple shots of a well-used balljoint and vertical link. Sorry for the poor photos but it was dark and I just had my cell phone with me. Unfortunately, I didn't have anything to measure the distance from the bottom of the ball joint to the vertical link with me.
There is definitely a gap there but hard to really tell how it compares with your nice and clean one. Any particular measurement you'd prefer?
I'll try to get out there tomorrow and measure it for you.
Note that this was the original front suspension on my first car. Not sure if the ball joints had been replaced between 1966 and 1979.
Scott
Darrell_Walker
I measure just under an inch on my car.
PS The wire holding the boot on my joints is green
T
tdskip
You guys are great - thanks for all of the help.
I think it is good to take all the measurements with a grain out salt due t production difference and reproduction parts etc, but my gap is similar to Scott's but I have less exposed thread than Darrell.
Is the vertical link opening tapered as well?
Darrell_Walker
Sorry, my slightly less than an inch measurement was between the top of the vertical link and the bottom of the ball joint housing.
The opening in the vertical link is tapered, to my best recollection.
bgbassplyr
I just looked at my new ball joints and although they are the old style TR4 like the TR3, IMO as long as the nut covers all of the threads, all should be well.
With the suspension at full droop, you will find that there is very little clearance between the ball joint and the vertical link due to the angle at that point. My boot is mashed pretty tightly between the two.
I think you are good to go.
HerronScott
Tom,
One more picture with some of the grease cleaned away. The distance from the top of the vertical link to the centerline of the bolt holes is 1 1/4 inch on mine.
I also thought the hole on the vertical link had a slight taper as well. Assuming your measurement is significantly different, is there any possibility that the powder coating left a ridge around the hole?
Also, I seem to recall that we had touched on this before but what's the length of your front springs and are you using aluminum spacers or not?
Scott
startech47
Do not hone the hole in the vertical link! The angle is critical. It looks like your gap is similar to the pictures furnished by others.
T
tdskip
Hi guys. Scott - thanks for that additional picture, my gap is about the same.
I did run a hone on the vertical link opening for about 15 seconds to make sure the ball joint was not getting hung up.
At this point I think I have a spring issue - which is odd since they are original to the car. (No spacers Scott)
Anyway...
Thanks guys!
HerronScott
Tom,
I measured the ones that came with this suspension while I was there and they were 10" also with no spacers. I'm pretty sure they were original springs as well.
Was this the TR4A where you had to do some lower front suspension repairs and is your problem positive camber? Any shims in the lower suspension?
Scott
T
tdskip
Hi Scott - yes, this is the 4a that had positive camber. I've got some shims in there now and she is not quite neutral now but <span style="font-weight: bold">much</span> better. But the ride height is off.
Trying not to pull everything apart, but heading that way.
HerronScott
Tom,
Was this also the car that we had the discussion on the ride height last year?
TR4A ride height
The distance from the top of the tire to the wheel well arch was 2.5-3" on my older cars with 165R80-15 tires. What's your measurement?
Scott
Tabcon New Ball Joint Install Help Needed. Triumph 2
B TR4/4A Some Help with Setting Distributor Triumph 47
N Wanted Help with car identification Other British Classifieds 2
I MGB Help! What is this part for? MG 13
P Please help identify this tourer Spotted 13
angelfj1 TR5/TR250 TR250 Need Help identifying wires (2 - black) feeding starting solenoid Triumph 6
C MGB More Weber help needed MG 27
V 96 Chimera help needed TVR 1
V Help with identifying morris eight Other British Cars 12
J MGB help, turn signals do not work MG 3
J MGB HELP, my horn does not work! MG 8
I MGB Alternator help MG 0
Southwarks TR2/3/3A TR2 door help! Triumph 2
P General Tech Positive Earth?? Very confused. A little help? Triumph 19
Texas TR3 TR2/3/3A Convertible top webbing installation help? Triumph 5
apbos The next rabbit hole. Help ID the chassis. Racing 27
R Help With Spridget Speedometers Spridgets 4
apbos Help Identify this car chassis Racing 20
tr6web TR6 Sputtering help Triumph 6
R TR6 Help: Brake Part Source or …. ? Triumph 1
B Help for Old Men Restoration & Tools 15
Basil Admn Note Our neighbors need emergency help Triumph 0
Basil Our neighbors need emergency help Spridgets 0
Basil Admin Note Our neighbors need emergency help MG 0
Basil Emergency help requested for our neighbors Austin Healey 0
B TR6 Help with color and color code / paint recommendation Triumph 4
JohnGone MGB Help getting my 1980 MGB to pass CA smog test MG 19
K TR6 Need help with Mimosa Yellow Paint Triumph 1
Bayless Help please installing bonnet release cable Spridgets 8
T TR2/3/3A Help - Cooling system problem Triumph 7
D TR6 Help with tr6 engine diagnosis Triumph 11
H Wanted MK2 - Please, help needed Jaguar Classifieds 60
D Spitfire 1980 California Spitfire, Help Figuring What To Do With It? Triumph 15
I Bugeye oil leak help Spridgets 4
A TR6 Carburetor help Triumph 5
Darwin GT6 Diff Help Please Triumph 2
J TR2/3/3A Need help with a value for this TR3 please Triumph 6
M Need help removing the pinion assembly from a late 1275 steering rack Spridgets 7
V VAUXHALL Astra diesel 1.7cdti loss of power 2012. HELP. Other British Cars 1
jehuie Help...replaced my alternator and now my water pump is leaking. Spridgets 16
algot1901 HELP with wheel bearings Other British Cars 1
K TR2/3/3A The guide bolts to help gearbox install? Triumph 19
S MGB Mgb with nissan cylinder head. I am a new member, introduction and help MG 1
T Lotus 7 - help identifying parts Lotus 5
TheRealDestrux MGB 1977 MG MGB need help putting top down MG 1
6 Electrical Help Please Spridgets 7
B MGB Help MG 2
P Help with torquing bolts Restoration & Tools 3
E GT6 Help electrical guru needed Triumph 4
