so friends, I need your help.
Saturday I went for a drive and found the wipers don't work. Today I started investigating. So, first of all I turned the key and turned on the wipers - initially heard a bit of an hum but then nothing.
Checked the fuses - they all have continuity.
Cleaned the green wire connections.
Finally started removing the wiper motor to check if there is power to the motor.
So, questions.
1. Anyone have any ideas what could be causing this? (BTW the manual doesn't seem to show which fuse covers the wipers)
2. When removing the motor - does the "pipe" to the actual wipers slide out or do I have to undo the cover and lift it out?
3. Anyone know where these things are grounded?
4. Any other thoughts?
thanks all
So, questions.
thanks all
