I'm in the process of doing a bunch of cleaning, stripping, refurbing, polishing, replacing with stainless, etc. under the hood right now, and wanted to ID a couple of bolts on my 1275 engine. They are just below the spark plugs, circled in red in the picture attached.
Mainly, I just want to pull them, clean them up (or replace) and put them back. But not knowing what they are I'm hoping nothing will fall off inside if I do so - so looking for some help IDing.
The PO of this thing had the engine painted once upon a time, and just painted everything. So lots of stripping (thermostat housing, water pump, and heater valve) and polishing have done a lot to make it look much nicer.
