Help for Old Men
bammons
This old man is learning to use a multimeter. I have three 2 digital and 1 analog (which I just discarded). They are cheap ones. My problem which I understand some others have is I can't hear the low frequency noise it makes when on audible checking continuity. Can someone name a multimeter that has a buzzer that is not a low frequency buzz?? Another words LOUD. Thanks Bruce
JHaydon
I have a 30-ish year old Blue Point (entry-level Snap On) digital meter which has a rather shrill beep to indicate continuity. It's not piercingly loud but it's no buzzer.
NutmegCT
Actually I've never found a MM with a low sound. Mine have always had a high pitch screech!
Here's a cheap one I have. Unless they've recently changed it, continuity has a high pitch blast.
mezy
I have the same problem, Having worked in car body shops for most of my life using all maner of air tools, I have lost my high pitch hearing, I cant hear the multimer as it is too high of a pitch, i just look at the readout for continuity.
B
bammons
It is the high pitch Nutmeg which we can't hear. My wife can hear mine from 8 ft away but I can barely hear it when I hold it up next to my ear. I know I can look at the display but having spent a decent amount of time under my dash and often needing two hands it is sometimes difficult to see the display while paying attention to what you are doing. I was going to buy a HF Ames auto ranging for $45 but I asked the manager if I could return it if I could not hear it. He said (surprisingly) that I would have to pay a restocking charge and they only took items back that were defective. And of course it came in a clamshell pack that I would have to destroy to try it out. I may have mistakenly called it a low pitch noise but really it is a high pitch that both of mine make and sounds like what all of you are describing. Bruce
JPSmit
why not just get a cheap continuity tester with a lightbulb? My multimeter has a continuity testor but I pretty much always just grab the one with the light. Actually I have two - one with a battery and one without.
(Looks like $6 at harbor freight for three)
mezy
I find one of these a must have when tracing wiring faults on cars, you connect to the batery and you probe away, will tell you if a wire is live or if it is going to earth.
you can also put power to somthing or earth something out depending which side of the something you are, and not a lot of money either, unless you buy it off the snap on van.
NutmegCT
sorry 'bout that. I thought when you wrote "I can't hear the low frequency noise ...", that you can't hear a low frequency noise!
I like JP's idea of just using a light bulb system:
Tom M.
mezy
problem with a light bulb system it an only test for power to an item unles you keep running back to the batery to swap it to the positive terminal.
the tester i have shown does that automaticaly and will test for live and ground just by probing one side of a bulb and then the other. you can also power things , or ground things
You realy need to try one of things just to see how great they are at tracing wiring faults
Popeye
Bronze
My Fluke is pretty loud. Not sure if loud enough and the right frequency, though. Not sure how to solve the problem… go to all your friends’ houses and try them out might be the only way??
B
bammons
Popeye - I live way out away from others with British cars and am pretty much a hermit but I will ask when I go to the next meeting of the club. Mezy - I am not familiar with the item you are showing. Does Harbor Freight have it? You did not say how it indicates continuity - does it make noise (what kind of noise) or flash or what? But I like what you are saying about it. I do have and use a tester like Nutmeg shows but you can't test continuity with it can you? Bruce
NutmegCT
Hi Bruce - you're right. The tool I showed tests for voltage, not continuity. I still suggest trying a multimeter at Walmart (they're really good at letting you return things), or Harbor Freight, or a hardware store you know.
Tom M.
LarryK
I have the light like Tom, but I also have the snap-on light with three lights. Hook to pos and neg and as you probe you get green light for hot or red for grounded. But, also have a fluke meter for with a loud beep.
mezy
It will test continuity of any wire that has 12 volts going into it, simply by probing the other end of the wire, if there is continuity the tester will light up. simple one handed use, great if you cant get two arms somewhere with test probes,
It will tell you if a wire is 12 volts live or if it is going to ground. simply with a red or green light,
if you want to test a fuse for instance, just probe one side then the other, if it lights one side but not the other fuse is dead, no need to remove the fuse.
B
bammons
I am sort of new to actually using a multimeter for anything more that "is my battery dead". I am new enough and dumb enough to have burned a major wire on my new wiring harness. On the TR4A (different than a TR4) the wiring in the headlight switch is difficult because the existing wiring diagrams don't cover the proper wiring there and some harness's seem to be made slightly different in this area. Yes I had a thread on this recently. One of the contributors was kind enough to tell me how to test continuity with my multimeter with NO power supplied so I could trace wires and determine if wires went and did what I thought they did. These seems very useful and I have already used this feature. To test wires and test switches. So I want the ability to test without 12V power supplied before I burn stuff up. So Mezy from what you just said the unit you are talking about would not work in this instance. I literally just need a multimeter that has a loud (not high frequency) audible function but if one can't be identified without spending big $$$ then I will have to continue holding my ear to my multimeter. Bruce
mezy
Sorry bammons wasnt aware yu needed to test when the circuits are dead,
have a look at this continuity tester designed for factory use,
if you cant hear this mate your not deaf your dead :ROFLMAO::ROFLMAO:
The loud 85 dB buzzer makes it ideal for use in noisy environments
anarchy99 Help with new [old] Sprite hardtop Spridgets 17
T Old Man needs help MG 11
soren_ak All u OLD CAR fans out there - help me out wuld ya Austin Healey 13
B TR4/4A Some Help with Setting Distributor Triumph 47
N Wanted Help with car identification Other British Classifieds 2
I MGB Help! What is this part for? MG 13
P Please help identify this tourer Spotted 13
C MGB More Weber help needed MG 27
V 96 Chimera help needed TVR 1
V Help with identifying morris eight Other British Cars 12
J MGB help, turn signals do not work MG 3
J MGB HELP, my horn does not work! MG 8
I MGB Alternator help MG 0
Southwarks TR2/3/3A TR2 door help! Triumph 2
P General Tech Positive Earth?? Very confused. A little help? Triumph 19
Texas TR3 TR2/3/3A Convertible top webbing installation help? Triumph 5
apbos The next rabbit hole. Help ID the chassis. Racing 27
R Help With Spridget Speedometers Spridgets 4
apbos Help Identify this car chassis Racing 20
tr6web TR6 Sputtering help Triumph 6
R TR6 Help: Brake Part Source or …. ? Triumph 1
Basil Admn Note Our neighbors need emergency help Triumph 0
Basil Our neighbors need emergency help Spridgets 0
Basil Admin Note Our neighbors need emergency help MG 0
Basil Emergency help requested for our neighbors Austin Healey 0
B TR6 Help with color and color code / paint recommendation Triumph 4
JohnGone MGB Help getting my 1980 MGB to pass CA smog test MG 19
K TR6 Need help with Mimosa Yellow Paint Triumph 1
Bayless Help please installing bonnet release cable Spridgets 8
T TR2/3/3A Help - Cooling system problem Triumph 7
D TR6 Help with tr6 engine diagnosis Triumph 11
H Wanted MK2 - Please, help needed Jaguar Classifieds 60
D Spitfire 1980 California Spitfire, Help Figuring What To Do With It? Triumph 15
I Bugeye oil leak help Spridgets 4
A TR6 Carburetor help Triumph 5
Darwin GT6 Diff Help Please Triumph 2
J TR2/3/3A Need help with a value for this TR3 please Triumph 6
V VAUXHALL Astra diesel 1.7cdti loss of power 2012. HELP. Other British Cars 1
jehuie Help...replaced my alternator and now my water pump is leaking. Spridgets 16
algot1901 HELP with wheel bearings Other British Cars 1
K TR2/3/3A The guide bolts to help gearbox install? Triumph 19
S MGB Mgb with nissan cylinder head. I am a new member, introduction and help MG 1
T Lotus 7 - help identifying parts Lotus 5
TheRealDestrux MGB 1977 MG MGB need help putting top down MG 1
6 Electrical Help Please Spridgets 7
B MGB Help MG 2
P Help with torquing bolts Restoration & Tools 3
