TR2/3/3A Gearbox cover 60 TR3A
auggie
Does anyone have a picture of the gear box cover they can post? Modifications to cover by previous body man don't seem right, should there be wings where the cover bolts to the firewall?
Thanks,
Auggie
MGTF1250Dave
Aloha Auggie,
If you are asking about the sheet metal cover over the gear box in a TR3, yes there should be a flange at the front with holes to bolt it to the fire wall.
Tr3aguy
hope this helps...
A
auggie
Tr3aguy,
Is the right side that cannot be seen the same as the picture of the left side?
Thanks,
Auggie
TR4nut
JP will have a better answer, but as I recall on the starter side the flange at the firewall is different - there is no flange where the starter bumps out. At least that's what I think without looking at it.
DNK
auggie said:
Tr3aguy,
Thanks,
Auggie
PatGalvin TR2/3/3A TR3a HVDA gearbox cover fit issue Triumph 7
R TR6 Proper alignment of gearbox front cover plate Triumph 3
J Gearbox front cover seal Spridgets 2
D 1962 center shift gearbox cover Austin Healey 7
A TR2/3/3A bottom gearbox cover with HDVA conversion Triumph 14
PeterK TR2/3/3A Saturday Freebie - Gearbox top cover Triumph 3
P Sideshift gearbox - gasket for side cover Austin Healey 14
K TR4/4A Gearbox front cover[Moss 848-000] torque spec? Triumph 1
K TR2/3/3A The round electrical connectors on the OD Gearbox Top Cover? Triumph 1
T TR2/3/3A TR3 Gearbox Top Cover OD Switch Locations Triumph 6
K TR2/3/3A Is the 4A Gearbox Top Cover the same as the TR6 Top Cover? Triumph 2
D BN2 gearbox tunnel cover Austin Healey 1
I Gearbox cover and OD questions Austin Healey 7
T Lessons learned from installing a gearbox cover Triumph 18
tmc Gearbox cover seals Triumph 6
S bj8 gearbox cover Austin Healey 4
bighealeysource Fit of extension panel to gearbox cover & bulkhead Austin Healey 6
sail gearbox top cover non to od Triumph 10
mrv8q TR6 TR6 Gearbox cover TRF Kit Triumph 6
I TR6 TR6 gearbox cover leak Triumph 5
pa297pass TRF Gearbox Cover Repair Triumph 4
vette Gearbox Cover Seal Austin Healey 7
D TR2/3/3A 59 TR3A Gearbox lever will not move. Triumph 11
bighealeysource Leaking Overdrive and Gearbox Drain Plugs Austin Healey 19
F Sprite Gearbox Spridgets 5
E Gearbox problem Other Cars 0
K TR2/3/3A Gearbox clutch adjustment. Triumph 1
K TR2/3/3A Further to changing motor and gearbox mounts. Triumph 1
K TR2/3/3A Replacing engine and gearbox mounts? Triumph 8
BN6_2197 Gearbox/Overdrive Removal Austin Healey 25
AHS Side-Shift Gearbox Austin Healey 3
D Gearbox Dipstick (BT7) Austin Healey 3
K TR2/3/3A A gearbox additive? Triumph 3
C Gearbox oil British Motor Corp 3
JFS Wedge Stripped gearbox filler hole thread Triumph 3
K TR2/3/3A The guide bolts to help gearbox install? Triumph 19
R 100 Motor and Gearbox Available Austin Healey 2
K TR2/3/3A Clutch Slave Cylinder location when TR3 has a TR6 Gearbox? Triumph 16
W BN1 Gearbox First Motion Shaft Austin Healey 0
K TR2/3/3A TR6 Gearbox in a TR3.....Use a TR6 clutch disc and pressure plate or Triumph 7
KellyRob BMC GEARBOX 1960 British Motor Corp 2
Hamish Racing TR2/3/3A Gearbox - can you spot the problem ? Triumph 17
C TR2/3/3A TR3 Gearbox Problem Triumph 10
D MGA with T9 gearbox on a tow dolly MG 9
Got_All_4 TR6 Refurbishing gearbox with A type overdrive Triumph 7
S Add ZDDP to gearbox oil? Austin Healey 29
R TR6 Gearbox slips out of 3rd gear Triumph 14
K For Sale Triumph TR4 & 4A Gearbox anti vibration attachment Triumph Classifieds 0
