Front suspension repair
Lee
Anyone have any tricks for replacing the lower (horizontal) trunnion bushing in the swivel axle assembly? After eliminating all the more usual suspects, it turns out my B's front suspension has excessive play there. The Moss catalog says "must be reamed".
Lee;
It's been a few year since I did my entire suspension using a fully rebuilt kit from The Roadster Factory. That made short work of it. However, you should be able to have the bushing installed and reamed at an automotive supply that has a machine shop reasonable. I put new kingpin bushings in my Healey, and a local shop reamed both sides for $75.00; half of what a specialty British car shop wanted. Clean everything before taking it to them, that will save some time.
71TR6 TR2/3/3A Right Front Suspension Damage Repair? Triumph 50
mctriumph TR2/3/3A Front Suspension upgrades for the 59 Triumph 10
drooartz MGB Front suspension rebuild is next MG 57
Joel Lester TR2/3/3A What final front suspension torque settings needed? Triumph 7
HealeyPassion Kilmartin Front Suspension Gussets Austin Healey 4
Endoscaper TR2/3/3A Lower Front Suspension Overhaul Triumph 2
Dnickels Spitfire Spitfire mk2 front suspension too soft Triumph 2
crispy BJ8 Front Suspension Austin Healey 9
R TR6 Front suspension fulcrum pins Triumph 6
Upland Mark IV front suspension Spridgets 3
S TR2/3/3A Front Suspension Triumph 6
J Front Suspension Rebuild Austin Healey 16
Jayplum TR2/3/3A Front suspension / springs Triumph 5
TRclassic3 TR4/4A Help with deciphering front suspension problem Triumph 11
F TR4/4A Front Suspension Triumph 3
warwick-steve Front suspension rubber trunnion bearing question Austin Healey 4
K TR2/3/3A Front suspension inner Lower wishbone bush area? Triumph 3
T TR2/3/3A Is there a reason for this large pointed piece on front suspension? Triumph 14
R TR2/3/3A Replace Rubber bushings in front suspension Triumph 11
DrEntropy MGB Results of renewing front suspension MG 7
Gerald_Gordon TR4/4A Preferred front springs and suspension bushings for mild driving in a TR4 Triumph 3
D Front suspension question Austin Healey 0
D back to the front suspension Austin Healey 4
D Front suspension half moon cotters Austin Healey 6
D front suspension Austin Healey 7
S TR4/4A TR4 front and rear suspension Triumph 8
M TR2/3/3A FRONT SUSPENSION: Rusted lower control arm fulcrum Triumph 17
M TR4/4A Front suspension Triumph 4
I TR6 Broken front suspension bracket Triumph 3
Scotsman TR4/4A Front Suspension Strengthening Kit assembly Triumph 2
mcmillal TR4/4A Front Suspension Re-assembly Triumph 7
K TR2/3/3A Greasing the the Idler lever on front suspension? Triumph 3
Scotsman TR4/4A Front Suspension Vertical Link Triumph 2
Popeye TR4/4A TR4A front suspension quesions Triumph 19
G TR2/3/3A TR6 Front Suspension A-Arms on a TR3A? Triumph 5
C TR2/3/3A Question on assembly of front suspension Triumph 3
W TR2/3/3A TR2/3 Front Suspension Upgrades Triumph 13
R TR2/3/3A Front Suspension Polyurethane Bushings Triumph 2
maxwedge5281 front suspension or braking improvement Austin Healey 25
M TR4/4A TR4A - Torque the Front Suspension Trunnion Bolt! Triumph 5
M Adjusting Front Suspension Austin Healey 11
B TR2/3/3A Your Opinion of TRF Rubber Bushes for Front Suspension Triumph 6
Got_All_4 TR2/3/3A Tr3 front suspension re-bush, what's good out there Triumph 15
BN6_2197 Reassembling front suspension of BN6 Austin Healey 31
bugedd Front suspension and oil pan Spridgets 17
aseriesspares Front Suspension & Disk Brake Kits Spridgets 3
bugedd Front suspension springs Spridgets 4
M front suspension rebuild parts list Spridgets 22
BN6_2197 How to adjust the front suspension of a BN6 Austin Healey 52
