Front apron panel on BJ8
Digger
I am in the process of fitting the front bumper and the apron panel on my BJ8, and I would like to know what is the proper gap between the body and the apron panel. The bumper brackets have a little bit of adjustment in them, but I don't want to get it too tight (or too wide, either.) Thanks.
Bobbydsport
I just did mine a little while ago & bought new brackets (mine were bent), from one of our suppliers.When using the holes provided in the brackets the spacing was a good inch from the front shroud & really looked silly. So I re-drilled the holes in the brackets & closed the gap up to about 1/4" to 3/8" & it looks a lot more normal & more like other Healeys I've seen.
Bobbyd
Digger
Thanks for the info. The brackets have some adjustment where they bolt to the frame. I need a little more movement to the rear, so I think I will also enlarge that slot a bit, and adjust it.
J TR2/3/3A Front apron position Triumph 9
D TR2/3/3A front Apron fitting Triumph 5
F TR2/3/3A Tie member[front apron support tube] Triumph 11
R TR2/3/3A Removal of Small Mouth Front Apron Triumph 4
S TR2/3/3A tr3 front apron body work Triumph 9
K TR2/3/3A The "air vent"on the lower part of the front apron below the grille.... Triumph 5
toysrrus TR2/3/3A "WANTED": TR3 Small Mouth Front Apron Medallian Triumph 14
J TR2/3/3A Hood lift to front apron, what size are the screws that go from bottom up? Triumph 10
J One of you guys had great pictures of front apron Triumph 20
M_Pied_Lourd TR2/3/3A 3A Front Apron Question Triumph 17
B TR2/3/3A Need TR3B front and rear apron, sidescreens Triumph 19
K TR2/3/3A Mounting TR3 Body to frame with front apron on? Triumph 4
M TR2/3/3A TR-3A - Front Apron Medallion Triumph 2
M TR2/3/3A Fitting front apron TR3 Triumph 12
L TR2/3/3A TR3A - Front Apron/Air Duct Triumph 3
L TR2/3/3A TR3A - Front Apron/Bonnet Prop-Assembly Logistics Triumph 4
R TR4/4A TR4A Front lower Apron Triumph 2
luke44 TR2/3/3A TR3A Front Apron - Lower Area Triumph 3
A removing front apron Triumph 10
tlthorne T-Series TD front apron MG 3
T TR2/3/3A TR3 front apron Triumph 6
mountainman TR2/3/3A Tr3 Front Apron Triumph 17
Tinkerman TR2/3/3A TR3A Front Apron Assembly Installation Triumph 1
T TR2/3/3A TR3 front apron removal - tips and suggestions Triumph 11
H TR2/3/3A TR3 Front Apron Removal Help Triumph 26
A TR2/3/3A TR-3 Front Nose Apron Wanted Triumph 4
C Front apron to shroud clearance Austin Healey 21
PeterK TR2/3/3A Just removed the 3A front apron Triumph 23
gsalt57tr3 TR2/3/3A TR2 vs TR3 front apron Triumph 4
56HealeyDan 100-4 Front Crankshaft Seal Austin Healey 7
AngliaGT 1997 Miata - Anyone Have a Picture on How to Mount the Front License Plate Bracket? Other Cars 12
71TR6 TR2/3/3A TR3A Front Bumper Mount Triumph 11
1 TR2/3/3A Rimmer Brothers Replacement Front Wing Quality? Triumph 8
Carlbanan56 MGB Front hub MG 4
J MGB Front Wheel Bearings. Re-grease or replace? MG 19
scottkilpatrick TR4/4A Front Brakes - Basics for Pads Triumph 11
C MGB-GT MGB-GT Front Ride Height MG 0
C MGB-GT Front Ride Height MG 0
J For Sale Bilstein Front Shocks for Jaguar E-Type 727-498-6493 Jaguar Classifieds 0
J TR2/3/3A Mystery knocking sounds at front wheel Triumph 11
E Wanted 1963 Healey 300 mark 2 front grille wanted Austin Healey Classifieds 0
K TR2/3/3A Front brake hub removal to access Vertical Link bolts(screws) Attached pictures. Triumph 1
K TR2/3/3A How to remove the front brake hub from the brake disc? Triumph 11
AUSMHLY Front Wheel Spin Drag Austin Healey 6
mctriumph TR2/3/3A Front Suspension upgrades for the 59 Triumph 10
